Question about Capcom AK-300 Battle Rifle Controller with Resident Evil PlayStation 3
This thing dont let me play, just spin around all the time, already check the configuration but still just spin
  • 364 Answers
I find that a 12 lb hammer works best for these, followed by a size 12 boot. bet ya it spins then. On a more serious note... go buy a new one then take this one back for a refund with your receipt. cheers.
Posted on Oct 14, 2013
We dont know how to play the sorry spin I need instructions
Hi Monica:
The goal is to get all four of your pawns around the board and into your home space. You move around the board by drawing cards and following the instructions on the card. If you land on the same space as another player's pawn, you send it back to start.
The main difference in Sorry Spin is that the board is made up of 5 gears (a large center gear and 4 smaller home gears) and sometimes you draw a card or land on a space with allows you to "spin" the gears 1/4 of the way around. Doing this may move you closer to your home gear or send another player right past their home, making them go all the way around again.
Here is the instructional guide: GAMES/SORRY.html
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 16, 2011 | Hasbro Sorry Spin Game
Hi I have an Aqualtis AQGMD149 which is getting noisier and noisier on the spin cycle, the instructions say to check it is level, is there anything else I can check?
Yes you can check the play in the drum bearing, by '"rocking" the inner drum up/down against the outer, there should be very little play. If it moves a lot your drum bearing needs replacing. Also take lid off and physically wobble/apply pressure the outer drum and inspect to make sure the springs and dampers are not allowing excessive movement which would allow the drum to 'crash' around as it tries to spin. A bit like checking car suspension. DISCONNECT MAINS BEFORE REMOVING LID
Easier to do all that than explain!
dont forget to vote thanks
Feb 03, 2011 | Hotpoint Washing Machines
When playing a DVD, we experience frequent stops and starts..
It may be a dirty lens, or perhaps the drive is getting stuck.
The first thing to try, if you feel up to it, is to clean the lens. First, you'll need rubbing alcohol (peroxide isn't the same thing) and a Q-tip. Add a tiny amount of alcohol to the Q-tip and gently rub it against the lens of the laser. After a few times around the lens, use the dry end of the Q-tip to pick up any excess alcohol lying around. Put the player back together and try playing a disc.
If it still doesn't fix the issue, then the following steps can be taken.
Have a disc in the drive and while it's off, open it up. Start the drive and see if it's spinning freely. If not, then onto the next part.
Use some WD40 on the shaft of the drive motor that makes the disc spin. Just use a little bit at a time and work it in by manually spinning the spindle (what the disc rests on). Once that's finished, put the disc back in and reassemble the drive, plug it in, turn it on, and see if it spins better.
Jun 05, 2010 | Zenith DVD2381 DVD Player
Scratches a ring around the game after long play time
The disc is spinning too close to the laser head. This is a common problem with people moving their consoles while the disc is spinning, but it can happen while it is stationary if the tray isn't keeping the disc at the proper distance from the laser.
You can install spacers. More detail on this process can be found here. They want to sell you foam spacers, but I'm sure you can find something around the house that can do the same thing.
Dec 10, 2009 | Microsoft Xbox 360 Console
Cd does not spin
the motor will need to be replaced
Apr 15, 2009 | Fisher SLIM-1500 CD Shelf System
Maytag atlantis wont spin cycle
this could be one of three things, 1. Rinse hold (an option to save the washing sitting crumpled when you are out) release the rinse hold button and it will spin.
2. You have a blocked drain or uneven load (if a washing machine spins with a full load of water in it it would dance around your kitchen and eventually break apart the weight is too much, it has to remove the water to a level within a set time or it will stop, or if its a uneven load it will attempet 3-4 times start a spin.
3. your motor brushes are worn (brushes last around 2-3 years depending on use) or board failure, first signs of this can be it will not spin, then it will not rotate at all try to spin it with no load (no washing) then add a couple of wet towels. if no spin it could be either of the two best way to check the brushes is to remove them and check the length they start around an inch long.
Always isolate the electrical supply when removing things from the machine.
Nov 12, 2008 | Maytag Washing Machines
Please help me with my sony playstation slim line console
i cant play online,and its saying yur network configuration file was not found. to create edit or delete your network configuration file, please use the net work adapter star up disc. i dont know what that is, and if it something i need, can you xplain how i can get a start up disc, and how to install it.
Sep 14, 2008 | Sony PlayStation 2 (PS2) Console
Won't play discs
means there is some thing over the lens and the runner is chocked up due to use after along period of time or rought use so please get it serviced
May 20, 2008 | Sony PlayStation 2 (PS2) Console
My xbox 360 game keep getting scratched when i play
http://www.llamma.com/xbox360/news/Xbox-360-Game-Disc-Scratched.htm
Jan 14, 2008 | Microsoft Xbox 360 Console
Dont know what to do
Probably not much help. but the 1st thing I would do is check to see if the disc is even turning...put it in with label straight up, then when it fails, eject...odds are severely against the disc being oriented the same way if it spins, so if it hasn't moved, the main drive motor is bound up or dead. Either way, return it.
Dec 29, 2007 | Coby DVD-233 DVD Player
Capcom AK-300 Battle Rifle Controller with Resident Evil PlayStation 3 Logo
282 people viewed this question
Top Capcom Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
Piyal Perera
Piyal Perera
Person On the...
Level 1 Expert
Are you a Capcom Video Game Console and Game Expert? Answer questions, earn points and help others
