Question about Samsung WF337AA Front Load Washer
I have a Samsung washing machine , front loader model #WF203ANW or An WF203ANS At this time I have no power at all and the door will not open. I have checked the plugs as well as the circuit breakers in the house and they are fine. Does anyone have any suggestions?
    Master:
  • 492 Answers
Try unplugging the machine for a few hours to rest the code on the board.
Posted on Oct 15, 2013
  • 21 Answers
SOURCE: Front loader door will not open after a washing cycle is finished
call the repair man it is a comp. issue
Posted on Feb 14, 2009
SOURCE: mildew smell in front loader
Yup! I have the same issue with a WE206BNW (Canadian model). Did the same thing - dried the water off the door and leave the door open when not using it. Sort of helped, but then I ran an empty light load with bleach through it - no clothes, just water. Helped a lot.
Henkfish
Posted on Jun 08, 2009
57 varieties
  • 1653 Answers
SOURCE: Samsung Front Load washer has odour
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Posted on Sep 10, 2009
GodBlessU
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
SOURCE: My Samsung Washing Machine (Diamond Drum model) problem
You probably did not save the mode you want. See the information booklet provided on how to set the mode.
Posted on Oct 29, 2010
Washer front loader wont spin or unlock
Find your book that came with the washer, and it will have trouble codes. Your lights are probably flashing a code. Count the flashes then look up your code in the book. That is a good place to start.
Mar 06, 2014 | Samsung WF203ANW Front Load Washer
Washer has load inside and the door will not open.
Possible that the program controller has not released the door link or that the lock is struck up.
Please check on the link below for tips to clear this fault.
click on :
http://www.espares.co.uk/advice/washing-machines/a/7/1294/how-to-open-a-washing-machine-door-thats-stuc.html
Sep 23, 2011 | Samsung WF203ANW Front Load Washer
The door of our J845 wont open. its been 3 hours since the cycle finished
hawe you disconected from electriciti or no. pull door inside- if not helping - time switch is faulty.
Mar 18, 2011 | Samsung WF203ANW Front Load Washer
My samsung front loader washer wont drain. I can't find the drain hole. Is it in the drum?
there should be a kick plate at the bottom of the front panel if not some of the new models you have to remove the front panel to get to it this is probably the case with your machine alternativley you can follow the drain hose back to the pump lean the machine back and look underneath.
Jan 13, 2011 | Samsung WF203ANW Front Load Washer
Water is pouring out of the detergent dispensing drawer from my 1 year old Samsung clothes washer model WF328AAW. When I opened the drawer, it was full of water. Something must be plugged. Is there...
Pull the drawer out you will find detergent has built up in side the dispenser probably from from way too much detergent, modern front loaders work best with a small amount of detergent and liquid detergent normally will wash better.
Apr 17, 2010 | Samsung WF203ANW Front Load Washer
Door wont lock
door won't lock & shows d5 code what do i need to fix it?
Dec 18, 2009 | Samsung WF203ANW Front Load Washer
I have a samsung j1455a front loader that has started leaking water from the draw any ideas?
Soap has blocked the pipes leading from the drawer to the drum and they need cleaning out with a flexi brush
Oct 13, 2009 | Samsung WF203ANW Front Load Washer
Sep 01, 2009 | Samsung WF203ANW Front Load Washer
Samsung WF337AA Front Load Washer Logo
99 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
