Question about Air Tools & Compressors
21 gal vertical Model 94667 will not fill tank.
  • 1 more comment
  • Brad Alvey
    Brad Alvey Oct 16, 2013
    It will only build up to 20 lbs then just keeps running without a pressure increase. I think it might be the intake valve. Where can I get the valve/gasket assy?
  • Brad Alvey
    I mean the part numbers. This is a Central Pneumatic from Harbor Freight, who is no help.
  • Brad Alvey
    Brad Alvey Jan 29, 2014
    It turned out to be the reed plate. I replaces it and everything works just right. Thanks guys for your ideas and help.
  • 10,291 Answers
Could be piston rings too. Have you looked here? http://www.centralpneumaticaircompressors.com/buying-central-pneumatic-air-compressor-parts/
Posted on Jan 29, 2014
4 Suggested Answers
SOURCE: Ingersoll rand compressor oil leak (Model DD2T2, 4.5 Gal.)
The brass fitting that goes into my DD2T2 seems to have a hole in it and it looks impossible to remove without ruining a major gasket due to the close tolerance in replacing the fitting. Am I missing something?
Posted on Sep 15, 2009
  • 18 Answers
SOURCE: Craftsman 1 HP 8 gal vertical compressor.919
Sounds like the unloader valve is not working properly. The unloader typically is at the end of a tube going to the pressure switch. The unloader is tripped when the pressure switch cuts off. The purpose of the unloader is to bleed the pressure from the cylinder when the compressor cuts off so the next time the compressor cuts on it will be starting in an unloaded condition.
when the compressor cuts off you should hear a discharge of air for about 3 to 5 seconds if the switch is working properly. The unloader can be adjusted if necessary by loosening the jam nuts and adjusting the unloader towards the lever on the pressure switch.
Posted on Jul 10, 2010
  • 28 Answers
SOURCE: i have an ingersoll rand
Hi
I'm not sure but I operate my'n at about a 145/150 top and about 110/120 min.
However others my have a differant perspective
Cheers
John
Posted on Jul 09, 2011
Hi I have model 94667 21 gal the pressure is at max,will not go past 60 psi & if I set it 60 the compressive will not stop running but it will hold pressure no leaks.can you help. Thanks Jay
The reed valves are worn. Replace along with gaskets and valve plate. Part #38, 48,58. good luck finding pats. unfortunately the air compressor is disposable, You probaqably never find parts., HF does not have them. Maybe Ebay.
v37sysaytalc8dyukjc4v8blo9prznzf6saaaaasuvork5cyiia
https://www.about-air-compressors.com/support-files/94667.pdf https://www.about-air-compressors.com/support-files/94667.pdf
Mar 30, 2018 | Psi Air Tools & Compressors
Chevrolet Suburban 2500 8.1L runs out of gas with gauge reading 1/4 tank full. I refill tank with 25 gal ( fills tank) then it runs out of gas again after using 25 gal. secondary tank in rear doesn&
Get manual online under $10-15 and get complete guide on whether to repair or not, service it, and how to repair etc
you can get it from reliable-store or manualslife
really good plus instant help also availabel
Feb 12, 2018 | 2005 Chevrolet Suburban 2500
I have a 1986 Ford F-250 with duel tanks and I don't recall what the capacity is or how many gals will each tank hold ?
Most of the standard Ford and Chevy tanks the 1980-1990 for pickups was 20 gals with long necked fills - so you could fit 21 gallons per side.
Jun 16, 2011 | 1986 Ford F 250
The tank fills with air, but the motor doesn't shut off. It continues to run.
Pressure switch is stuck on, dont use this until its fixed!!!!!, you could overfill the tank with excess air, it could be adjustable or the switch may need cleaning/replacing.
Mar 09, 2011 | Craftsman 25 gal Air Compressor 3 12 hp...
How many literes does it take to fill my envoy from empty
If you have the standard wheelbase Envoy, you have an 18.7 US Gal. tank, if you have the XL model, it has a 22 US Gal. tank. Don't know off hand the conversion to liters.
Sep 11, 2010 | 2002 GMC Envoy
Porter cable stand-up air compressor starts but air won't fill up
Might be the unloader valve is stuck. if so there will be hissing noise from switch assembly and you may have to get a new one.
Jun 04, 2010 | Porter Cable C6110 150 PSI 25 Gal OilFree...
Craftsman compressor
They put this under vacuums, relist it in the right place.
Dec 16, 2007 | Porter Cable 7812 Wet/Dry Vacuum
Air Tools & Compressors Logo
143 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
