Casio G'zOne Boulder Cell Phone Logo
c
cody Ball Posted on Oct 14, 2013
Phone wont turn on ... starts to turn on and just keep restarting
Dean Camelo
Level 1:
New Friend:
  • Contributor 11 Answers
  • Posted on Oct 15, 2013
Dean Camelo
Contributor
Level 1:
New Friend:
Answers
11
Questions
5
Helped
2097
Points
24
Is it an android device ?
  • Dean Camelo
    Dean Camelo Oct 15, 2013
    if it is... it means you semi-bricked your phone (boot loop). Just flash a custom rom and it should be fine.
2answers
Kyocera event wont turn on but it will charge
Most likey a loose power supply connector or bad charger.
My cell phone keeps restarting the power screen, what to do ?
mY Dear:
First:
restore your Phone Settings
IF Restart problem not Solved So
Secend Option:
Please Format Your Phone
we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure.
*#7370# or *#7780#
Default security code is 12345
release some memory then it will b opened
your phone or memory card get attack by virus. pls do a format phone and memory card.
If Problem Not Solved So
Very Best Solution:
flash new software install in the phone problem will solved quickly
Oct 16, 2012 • HTC Status
1helpful
Why wont my htc freestyle turn on
my htc freesyle wont turn on like what so ever, so i decided to plug my charger in it & i press the on button & it will turn on but the only thing that happens is it will keep flashing "oops an error has ocurred restarting..." & it will keep popping up & then when i disconnect the charger it will keep popping up for at least 10 minutes & then it will stop. can you help me figure out what to do, instead of getting a new phone?
My samung sgh-t239 just keeps restarting and wont let me do anything ..it just shows T-239 on the screen and starts over i took the battery out and put it back in and the same thing...nothing...it just...
take your sim card out and put the battery back in, than turn your phone on and when everything is on type this *#9998*3323#.and it should reset your phone. after that put your sim card in and see if that works.
1helpful
Engine cuts off while driving
Sounds like a bad MAIN relay, that controls fuel, It may also be a bad distributor, contact for more help. Thanks for using FIX Ya
My phone keeps automatically restarting, it wont get past the greeting message, without turning off and restarting. I took out the battery many times, yet it still does it. How do i get it to stop?
well they could have gave you a messed up phone. the best thing to do is to take it back to them and tell them what is going on, most likely they would give you a new phone
10helpful
I had to reset my phone: http://forums.t-mobile.com/t5/Other-Samsung-Phones/Samsung-T239-Reset/td-p/184573;jsessionid=3AB214FE95DEC1110DEE3FC25C5C7FF3
My phone keeps restarting
mine is doing the same thing right now and it's making me soooooooooooo mad
1helpful
APPS ARENT WORKING
Initially do a cold restart of the phone...hold Home and Top until the phone shuts down even if you see the slide to power down..keep holding.
I would start by restoring the phone through iTunes to a previous version where things were working. Finally if all fails you will want to wipe the phone and start clean.
Phone Restarting
Hi Friend,
The only solution u can do is as follows,
Initially switch off the mobile and then remove the battery and the sim card also
After 30 Sec u replace all the things in the mobile
Restart the mobile after 10 to 15 sec and then check it out,u wont get the problem again.
Regards,
Ayyasam
Top Casio Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Casio Cell Phone Expert? Answer questions, earn points and help others
