Question about Whirlpool duet Dryers
Whirlpool dryer wet status flasher 3 times pause then 1 time
  • Official Brand Answer
  • 346 Answers
Hello Dave Morton. While we cannot assist with repairs I can offer links to our troubleshooting, use and care guides, replacement parts, parts lists, and service line should that be necessary. We hope this helps. Sincerely, Ashley
http://bit.ly/zkfnZd
http://bit.ly/112Lu7q
http://bit.ly/LrNZiS
http://bit.ly/yLv4Z5
Posted on Oct 15, 2013
4 Suggested Answers
  • 2920 Answers
SOURCE: Whirlpool Senseon Dryer-drum doesn't spin & stuck on sensing mode
the belt on the drum could be broken
Posted on Feb 16, 2009
aasc
  • 1606 Answers
SOURCE: I have a Whirlpool gold Ultimate Care II gas dryer
I would suggest the coils on the gas valve . Also check the vent to make sure good air flow is getting out of the dryer . Try disconnecting the vent hose and drying a load to determine if maybe the vent is the problem .
Posted on Jul 19, 2009
SOURCE: my whirlpool duet dryer will not start. Power
Mine isn't stacked and I had the same problem. My husband and I just bought ours last week. I had to close the door and then press on the top of the door to hear another click and it then would start the cycle. I don't know if this is correct or not. I have searched whirlpool web site and not found mention of this. I am calling the department store we purchased ours from to see if this is normal. Hope this helps!
Posted on Mar 01, 2010
I have asked this question 3 times! my whirlpool washer dryer, Model WET 3399XQO needs to be cleaned under the dryer vent. How do I get to it?
normally...one could take the whole dryer apart its..fairly easily put back together but at the same time you maybe able to clear all the lent out of the dryer even out of th heating element as well....done this before with a dryer that had an issue with the rollers being ruined...
Jan 06, 2017 | Whirlpool Dryers
My washer will run for a short time and them stop and just beep repeatidly
Frigidaire washer beeps for no reason, driving us crazy ...
? 1:03
https://www.youtube.com/watch?v=gP51k2bhbbg
Nov 6, 2011 - Uploaded by NatalieJonathan
Our Frigidaire washer keeps giving us ridiculous beeping issues, and for no reason. ... Mine stack dryer above ...
My washer pauses during wash cycle and will not restart ...
www.shopyourway.com > Manage My Life > Questions
The washer will stop during wash cycle and just beep. Sometimes we can turn it off and it will run again. Getting worse ... My washer is a Whirlpool 3.5 cu. ft.
FIXED Whirlpool Duet Washer Stops and Beeps - ApplianceBlog
www.applianceblog.com/.../48786-Whirlpool-Duet-Washer-Stops-and-B...
Jan 16, 2015 - 6 posts - ‎2 authors
It's a front loading Whirlpool Duet Washer 4.0 cu ft, with Tumblefresh ... wet it stopswashing and starts beeping (three beeps, pause, three beeps, pause, etc). ... The clip that holds them into the CCU (I think that's the right term) has a ... with my fingers so I could get a couple loads of laundry done until I can .
Jan 05, 2016 | Washing Machines
Error code 13 on mitsubishi wd52628
wait for the light to go out then press power. Then if it doesnt power up hold the menu and the Device/input buttons on the set both in together for 5 seconds the light will blink a series of blinks pause briefly then blink another number of blinks then pause then it will repeat the same two digit blink sequence a few times . Let me know the two digit blink sequence.
Aug 29, 2012 | Mitsubishi WD-52628 52" Projection HDTV
I have a Whirlpool Dryer model GEW9200LW1. I have to push the start button 10-15 times to get it to start, then it may run 1 second to 20 min and just shut off with time in the display. then if i push...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 10, 2010 | Whirlpool Dryers
How do you turn off the control locked key?
To enable the Control Locked feature when dryer is
running:
Press and hold the END OF CYCLE SIGNAL button for
3 seconds. The control is locked when a single beep is heard and
the Control Locked status light is on.
 When the dryer is off, it is not necessary to press the Control
On button before activating the Control Locked feature.
To unlock:
Press and hold the END OF CYCLE SIGNAL button for 3 seconds
to turn this feature off.
NOTE: When the dryer is running and Control Locked is on, the
dryer can be stopped by pressing the Pause/Cancel button, but
can’t be restarted until the control is unlocked.
May 29, 2010 | Whirlpool GEW9250 Electric Dryer
My whirlpool dryer model- ygew 9250 pwo will not power up when I control on button. If I push the power on button and the pause button at the same time some times it will start and run and sometimes I may...
When this problem occurs are the small lights on very dim? If so I would turn off the power and remove the top off the dryer. Then re-seat the 4 ribbon cables on the display board. Alot of people replace the front panel or control boards when the problem really is the ribbon cables. If the LED's are not lit dim then you may need to replace one of the two boards.
Jul 24, 2009 | Whirlpool GEW9250 Electric Dryer
Need a manual for whirlpool washer/dryer awz410 1000
Make sure the half load / drying button is pushed in also and the drying time set.
Do you know whether the temperature dial controls the washing or drying cycle. Have shrunk too many jumpers. Thanx
Feb 20, 2009 | Whirlpool AWZ410 Front Load Washer/Dryer
Error code e10
Communication failure =E10
1. Rotate the CYCLE SELECT KNOB to the 3 O’clock
position.
2. Press and hold the Select and Pause Cancel
buttons simultaneously for (6) seconds.
3. Immediately after, press and hold the START and
Pause Cancel
buttons simultaneously for (4)
seconds.
4. Rotate the CYCLE SELECT KNOB to the 2 O’clock
position.
The STATUS indicator lights will flash the number of
times for the first digit of the code and the START indicator
light will flash the number of times for the second digit.
The code is obtained by counting the number of times
the lights flash. Example E24: the STATUS indicator
lights would flash twice indicating the 2 and the START
indicator light will flash four times indicating the 4. The
STATUS indicator lights and the START indicator light
will start flashing at the same time. The control will then
pause for 2 seconds, then repeat the code.
Troubleshoot the problem by using the chart on next
page.
To move to the next code, press the OPTIONS button.
To clear code, press the Select botton.
To exit this mode, simultaneously press and hold the
Select and Pause Cancel buttons for (6) seconds to
reset.
if this does not work need to replace control
Sep 07, 2008 | Frigidaire Washing Machines
Dryers Logo
57 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
