Question about Charging & Starting Systems for Oldsmobile Custom Cruiser
I removed a shorted out climate control module now my 2006 Nissan maxima will not start.2 codes are poping up po183 and po462 whats the problem please
    Problem Solver:
  • 8 Answers
P0183 is set when an excessively high voltage from the fuel tank temperature sensor is sent to the engine control module. Possible causes are the sensor circuit is open or shorted or the fuel tank temp sensor is malfunctioning.
P0462 is set when an excessively high voltage is sent from the fuel level sensor to the engine control module. Possible causes are the CAN communication line is open or shorted, the sensor circuit is open or shorted, or a malfunctioning fuel level sensor or unified meter and a/c amp
Posted on Oct 15, 2013
Testimonial: "you described my problem to the t and now I have an idea how to fix it"
Po462 nissan mini van
Hi Barbara,here's a link to your code,it says to erase code and fill up with gas and see if code comes back,if it does then sensor is bad.Autozone may be able to remove code for free,they have scanners,call first.
Jul 09, 2013 | 2007 Nissan Quest 3.5 Minivan
Climate control fan stays on after jump start, cycling from low to high
Blower motor resister is bad.Easy to remove,it's located by blower motor,click here to see what it looks like.
Jan 17, 2013 | 1998 Nissan Maxima
Po325 code on 97 nissan maxima
P0325 NISSAN - Knock Sensor Circuit Malfunction
Possible causes- Faulty knock sensor
- Knock sensor circuit short to ground
- Knock sensor circuit short to power
- Knock sensor circuit open
- Faulty Engine Control Module (ECM)
Read more: http://engine-codes.com/p0325_nissan.html#ixzz29K4BM3th
Oct 14, 2012 | Cars & Trucks
All my lights tcs abs slip and brake are on and the brakes feel like the hand brakes are on smells like it burning.....help what can I do.....
Another thing to check is that the climate control module/a/c auto amp part number 27760 7y01a (later 2006) or 27760-7Y000 or 27500-7Y000 (2004-2006) can also affect the CAN/OBD2 system and produce a code of U1000 as well as affecting the dash gauges (will trip the SLIP,TCS,ABS and cause the dash gauges to not function) and cause a no start issue with headlights turning on regardless of switch position and cooling fans will run as soon as key turned to "on position". it is located under the center dash above the radio. This is a PAIN IN THE *** to diagnose without someone letting you know of it. Problem usually caused by coins (or other small metal objects) falling through dash assembly an going through slot that looks like it belongs on a piggy bank on the climate control box... then shorting it out. This greatly upsets the CAN system. If you are replacing or have easy access to this component suggest mesh tape over that hole to preclude future issue.
Dec 21, 2011 | 2006 Nissan Maxima
What are the fuses attached to the positive battery cable on a 2006 Nissan Maxima?
These are fusible links.
(1) 50 Amp - wire color W/B - to BCM (Body Control Module) lead 55
(2) to lead 1 ABS/TCS Control Unit
(3) to lead 15 ABS/TCS Control Unit
Sep 05, 2011 | 2006 Nissan Maxima
Were is the transmission control module on 2006 nissan maxima
behind the glove box there are two modules. The smaller of the two is the transmission control module.
Aug 16, 2011 | 2006 Nissan Maxima
Where is located the engine compuer on 2006 maxima
computer is bolted to the fire wall inside at center of dash at the top ahlf to remove the dash to even get to it
Aug 01, 2011 | 2006 Nissan Maxima
U1000
U1000 - CAN Communication Line Signal Malfunction
Causes:
- Harness or connectors (CAN communication line is open or shorted)
Solutions:
- Poor harness ground connection
There is a service bulletin for the following Nissan models with U1000 code:
2002-2006 Nissan Maxima
2004-2006 Nissan Titan
2004-2006 Nissan Armada
2002-2006 Nissan Sentra
2005-2006 Nissan Frontier
2002-2006 Nissan Altima
2005-2006 Nissan Xterra
2005-2006 Nissan Pathfinder
2004-2006 Nissan Quest
2003-2006 Nissan 350Z
2003-2006 Nissan Murano
The service bulletin suggest cleaning engine and body harness ground connection to repair problem.
Feb 14, 2011 | Nissan Versa Cars & Trucks
How repair replace part for code p183,p420,p430,p462
PO183--Engine Fuel Temp Sensor,Verify PID Value
PO420---Catalyst System Efficiency Below Threshold (Bank1),O2 Sensors,Coolant Temp Sensor,Misfiring,etc
PO430--- Catalyst (Bank2)
PO462---Fuel Level Sensor Circuit Low Input,pump module,etc
Well----Codes do not tell you what part to replace,Just that a possible system failure has ocurred
Unless you have a scanner,not a code reader and a trouble chart,your done.
No experience,done
I would speculate, that you only have a couple of, not too serious issues,but wouldn't guess,it doesn't work that way.
Always test,and only replace things if they fail a test.
Is the battery okey and alternator output good ?
Oct 21, 2010 | 2004 Nissan Titan
98 nissan maxima climate control fan cycling
good start, try leaving a charger on battery on trickle for at least 4-6 hrs. if that doesn't help battery may be toast.
Apr 24, 2010 | 2005 Nissan Maxima
Charging & Starting Systems for Oldsmobile Custom Cruiser Logo
79 people viewed this question
Top Oldsmobile Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
George Agios
George Agios
Robert Swatek
Robert Swatek
Are you an Oldsmobile Vehicle Part and Accessory Expert? Answer questions, earn points and help others
