Question about Electrical Supplies
Insinkerator cover control problems
We have a dual swith on to turn on a light over the sink, the other to turn on/off our insinkerator. The switch is dead, which had one wire running to each switch at the top of the switch, and one on the bottom that went to a screw wire holder that is marked Line +. None of the new switches I tried worked and I can't find a new dual switch with a Line + on it. Any suggestions will help
    Master:
  • 483 Answers
Sometimes there are 2 places to attatch wires on a switch, there are the screw connections, and sometimes there is a hole in the back of the switch. if nothing else, attatch a jumper wire from your hot wire of light switch, to hot terminal of insinkerator.
Posted on Oct 23, 2013
  • 4234 Answers
SOURCE: how to connect light switch
Nope, you have the wrong type of switch. The old one is what is called a 3-way switch. You need to purchase a replacement 3-way. The switch you currently have is a standard on/off switch and can not be used in that situation.
Dan
Posted on Dec 31, 2008
  • 19 Answers
SOURCE: Connecting Leviton Decora light switch.
At the switch you have a feed wire coming in this brings in power which originates in the electric panel. You also have a feed or feeds goings out to other lts or switches, this you seem to have on the switch. instead of the closet switch loop.undo all the wires. find the only hot this is the one wire you can touch to the others and make different lts come on i reccomend getting a electric tester to do this. FInd the wire that goes to the closet lt. Once your sure put it to the side. wirenut all other wires together with the hot wire. this makes all other switches independantly hot. connect the hot to the switch and the closet lt to switch. I HOPE THIS MAKES SOME SENSE TO YOU . let me know if i can help
Posted on Jan 04, 2009
  • 323 Answers
SOURCE: Wiring Bathroom light/vent/heater switch with 3 separate controls
Wiring a bathroom combination vent, heater, light 3 way switch means more wires. In brief, you need to run two cables - one a two wire and one a three wire from the switch to the fan.
Incoming power will have white black and ground.
The two wire cable for the switch to the fan will have wht, blk, and ground.
The three wire will have red, blk, wht, and grnd.
The switch will likely have 2 blacks and a red coming from it, with two blacks and a red on one side, and a single black on the other.
The fan should have a red, blue, green, black, and white.
On the fan end: Group all green/copper grounds together and use a wire nut to fasten them together. Tape the nut to the wires.
There will be five white wires coming through. For ease of handling, using wire nuts, connect two on one nut and three on the other.
connect the blue to a blck. Connect one red to one black, and the other red to the other black.
The switch will have one red going into the 3 wire cable, a black going to the 3 wire cable, and a black form incoming power to the side opposite the 3 wires, and a blck going to the two wire cable.
There. Confused?
Posted on May 28, 2009
woobie dog
  • 1273 Answers
SOURCE: my insinkerator wont run at all...
Hi, W/D here.
Your disposer is jammed. Locate the wrench that is with the disposer. Mine is in the flip out tray under the sink. It should look like an allen wrench. You can see what the wrench needs to look like by opening your cabinet, and looking at the very bottom of the disposer. Insert your wrench into the socket, and move it forwards and backwards until you free the jam. Then, run a pot of water and ice through the disposer (with it running) to further clean it out.
Best regards,
--W/D--
Posted on Aug 12, 2009
jyackle5
  • 8197 Answers
SOURCE: I am replacing a single pole switch that contains
You have the hot wire on the wrong side of the switch. The side of the switch with the fin is where you put the hot wire. On the other side of the switch where there is no fin is where you put the other two wires one on each screw. When you have it wired that wat your switch will work like the old one. Also if you would like the lights to come on with the top part of switch. But works with the bottom switch you just need to switch the two wires from top to bottom.
Posted on Jan 20, 2010
Testimonial: "Thanks for the radid responseI will give that a try tomorrow. Cheers Peter"
Insinkerator disposer causes water to drain slowly from sink
The pipe from the disposer outlet to the sink drain Tee is partially plugged. Remove the drain pipe from the disposer to clear the obstruction.
Apr 11, 2014 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Insinkerator magnetic switch bypass
I never suggest bypassing anything when dealing with garbage disposal but I do suggest contacting the manufacture and get free parts to repair that include step-by-step written instruction.
Mar 13, 2014 | Now Evolution In-Sink-Erator COVER CONTROL...
How do i turn on an insinkerator
There are two different types, those that have the switch built into the top, and those that have a separate switch mounted on the wall or maybe inside the cabinet under the sink. It is possible that you have the type with the built-in switch that was installed with the separate switch too - in that case you would have to turn on the swithch AND turn the top.
Sep 04, 2012 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I need a new sink basket for my In Sink Erator, Model 5-81. Where can I get just the sink basket?
Disposal sink basket is not sold separately.
Go to local hardware and home center for returned defective disposal and then see if they will sell the basket assembly.
Be sure to get all the parts. Parts are generally universal, but the clip-on ring is sometimes missing and the old one might fit or not.
Contact insinkerator, and see if they have a box of spare parts at their factory in China:
http://www.insinkerator.com/service/index.shtml
Jul 14, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
HOW TO FIX MY LEAKY SINK STRAINER THATS CONNECTED TO A BADGER 5 1/2 HP IN-SINK-ERATOR THANKS FOR ANY HELP REALLY APPRECIATED
You have to take it apart and re-apply plumber's putty ... some specialize sink materials require different type of sealer, but stainless and porcelain use regular plumbers putty from hardware or home center.
I wrote EZ to follow steps that cover sink strainer basket leaking:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Feb 18, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
After cover is removed the disposal remains on. Must unplug or flip breaker to stop. Understand that the cover activates some magnetic devise in disposal. What should I try?
It sounds like the disposal is not working.
These electronic devices sometimes have a shorter-than-you-want lifespan.
I am pretty handy at keeping stuff operable around the house.
Personally, I would wire a switch to the receptacle where disposal plugs in.
If receptacle is under sink, put switch where you can open cabinet door and click it on-off.
Some older homes, the disposal switch is inside the cabinet.
If you're more gizmo oriented, the Woods 32555 keychain remote control.
http://www.amazon.com/Woods-32555-Weatherproof-Outdoor-Converter/dp/B001Q9EFUK
Plug disposal into
Nov 16, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Our disposal will not turn on and we think it is a switch. How do we fix an insinkerator switch?
Underneath the motor is a red reset button. Push up on it to reset. If it clicks, it is the problem. Unit sjould work with wall switch, if not make sure unit is plugged in under sink andno GFCI outlets are tripped.
May 23, 2010 | Emerson InSinkErator STC-BLK Sink Top...
Insinkerator badger 5 runs sink wont drain
Properly piped, your arrangment should look similar to this picture so that there is a separate trap for the disposal and the other sink basin.
Mar 05, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
IN SINK Erator/ Badger Not Grinding waste
if the InsinkErator is least than 2 years old, you should call the service.
there is 2 year In-Home Parts and Labor Warranty by InSinkErator.
if not you have to disaemble the unit and see what is keeping the blade from turning.
let me know if that is what you need.
Nov 23, 2008 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Electrical Supplies Logo
53 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
