Question about Jura Capresso Jura / Capresso IMPRESSA J5 Espresso Machine
Where is the fuse
My Jura Capresso impressa J5 Machine display does not light up when plugged in and turned on? Is there a fuse that can be checked and replaced?
5 Suggested Answers
  • 13 Answers
SOURCE: Where can I find an Jura Capresso Impressa F9 replacement lid
The only sources I have been able to find are in Europe. They do not always wish to ship to the US however. In the US the dealers always want the repair, but seldome wish to sell parts outright. Try this website for parts.
Mike
www.juraprofi.de
Posted on Jul 05, 2009
SOURCE: Jura Capresso Impressa S9- no steam
I had a similar problem. I took off the side and rear cover, followed the hose that comes from the steam wand to the rear of hte unit. It enters a solenoid made by ACL Italy. I dismantled the solenoid unit by disconnecting the two hose ends, removing the relay, and unscrewing the plunger unit (vertical pipe). The plunger unit internals should move freely up and down like a piston in a cylinder , powered by a small spring. In my unit, this plunger was calcified and seized. I soaked it in boiling water and pressed on it gently several times and it unstuck. I put it all back together again and presto! Good luck
Posted on Mar 30, 2010
taran_2005
  • 10515 Answers
SOURCE: My Jura Capresso Impressa S9
This error is due to the coffee sludge built up in the system and needs you open the machine and clean it.
Note - Capresso recommends that you unplug the unit, wait a minute, and then plug in and turn on. Try twice if the first time doesn't work. If you still have a problem, call Capresso, and if your machine is under warranty they will repair it for you free of charge and even pay shipping both ways.
For cleaning instructions, let me provide you with a generic link that would help you :
http://www.buessert.de/Technik/Jura-IMPRESSA-S95/Cleaning.htm
Good Luck!!
Thanks!!
Posted on Aug 19, 2010
espressonist
  • 1711 Answers
SOURCE: Describe your Jura Capresso Impressa E9 Espresso
You can find some detail procedure in this tip below
http://www.fixya.com/support/r5713182-jura_capresso_impressa_f9_malfunction_8
Try it since it have help some other with same problem.
Posted on Aug 23, 2010
Jura j5 keeps indicating beans need filling once a button for coffee has been depressed. then indicates ready again. Beans are full and I have tried blocking off the sensor (beans full) but still the...
Sometimes certain beans do not move freely throughout the grinder. Oily beans, which is not necessarily a bad thing, do not fall into the grinder easily and tend to stick. It is necessary to sometimes to just poke or stir the beans around with your finger to make sure they fall into the grinder. For a safety measure do this while your machine is turned off.
Apr 20, 2011 | Jura Capresso Jura / Capresso IMPRESSA J5...
Cannot install tray with ground basket installed, after removing. Mechanism is blocking the ground basket when the tray is slid back into the unit after emptying.
Try putting a container under the coffee spouts and pressing the rinse button. This will usually free any coffee grounds that may not have been expelled into the grounds basket from the last time the machine was used. The grounds can get stuck and block the slide path of the grounds basket.
Dec 23, 2010 | Jura Capresso Jura / Capresso IMPRESSA J5...
My dispay on my jura E8 says error 5.
Simple fix - got the machine serviced, needed a new thermoblock apparently, could also have been one of the couple of sensors they replaced. Total cost including box, bits and carriage - £180 plus change.
Expensive but now I have it back, it all seems worth it!
Nov 30, 2008 | Jura Capresso Impressa E8 Espresso/Coffee...
Jura Capresso Jura / Capresso IMPRESSA J5 Espresso Machine Logo
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Jim Goldsmith
Jim Goldsmith
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
