Question about Watches
Centurion 35 day pendulum wall clock - Watches
  • Randy Mattson
    Randy Mattson Apr 18, 2016
    my clock keeps good time but only chimes on half hour
cmcduncand
  • 714 Answers
SOURCE: pendulum in beat but stops running after a few
CLOCK OILING TIPS * NOTE: Many Master Clock Smiths and Hobbyists used many different oils and as many different techniques.
* It is only good sense to use only the best in quality when selecting clock oils and grease. A number of fine oils are made especially for clocks. The oil used should stay in place and not evaporate easily and have no tendency to gum or get sticky as it ages. Most clock oils meet these standards. [CAUTION: Never consider using non-clock lubricants, as they tend to not really work well in clocks. Some are too light and cause unnecessary bushings wear, while others are too thick or can evaporate, over time will gum up and stop the clock prematurely.]
Oiling Procedures
-Main-springs are oiled after cleaning and before they are recoiled.
-Teeth and pinions are never oiled.
-Normally, the dial train of gears, hour wheel, minute wheel and minute wheel post are not oiled. However, oil is used between the center shaft and cannon pinion where slip friction is present in setting the hands.
-All points of friction such as train wheel pivots to bushings are oiled. Verge faces are oiled directly.
-Oil is always used sparingly and should never run all over the plates.
Hope this tip helps.
R/
DAvid
http://antiqueclock.clockstop.com/oil.htm
Posted on Feb 08, 2010
RixsFixes
  • 2200 Answers
SOURCE: I have a Regulator "Centurion
By your description the spring is already wound up tight and what happens is that friction is keeping the clock from unwinding and starting of its own accord.
The solution is to manually use your hand to move the pendulum back and forth for a while. It may take a few minutes, but this will force the spring to gradually unwind and kickstarts the mechanism.
Eventually after a few minutes the friction will release, and the clock should begin to work on its own.
To test this after a few minutes - once you have the pendulum started, let it go and it should continue to tick of its own accord.
Thanks for using FixYa. Please do leave a vote for the solution.
Posted on Aug 16, 2010
bobshaw356
SOURCE: I have a 1983 reproduction
Hi Petah 920...I have also aquired the same clock, with the pendulum and other parts missing. I intend to fabricate the missing parts ( I am a clockmaker) and engineer. My problem is not knowing the exact parts, I have contacted Thwaites
Posted on Sep 03, 2010
mcnishl
  • 62 Answers
SOURCE: metal pendulum wall clock run
Hi! the movement must be bad, you can actually have a battery clock movement replaced easily at a watch or clock shop! We charge about $30.00 to 50.00 if the movement is available, you did not mention what type of clock? if you can let me know i may be able to help further. thank you!
Posted on Sep 21, 2011
SOURCE: we have a Acctim barrery
Press the red button at the back and go through all the hourly chimes until you get to the next chime due i.e. if its 3.15 whebn your doing this, only go through the chimes until 3 o'clock and no further. Then turn the hands clockwise ONLY never anticlockwide and she should be fine.
Posted on Oct 10, 2011
Tip
REGULATION TIPS FOR THE 400-day and 1000-day clocks
CLOCK REGULATION TIPS FOR THE ROTATING REGULATOR
These Regulations tips are useful for regulating the rotating regulator. This is to include most 400-day and 1000-day clocks.
The following information is copied from SCHATZ (tm) OWNER'S HANDBOOK.
Time Regulation Tip:
On the top of the pendulum is a disk on which numbers are engraved 1 - 16 and two arrows marked F - S. The small indicator hand will be pointing to a number on the disk at which the clock was regulated before leaving the factory. Should you find it necessary to regulate the clock, observe the number to which the indicator hand points. The distance between each number is equivalent to 1/2 minute in 24 hours + or -.
FRROM MY PERSONAL SHOP NOTES:
If your clock loses two minutes per day [24 hours] and the indicator hand points to number 8 on the disk - move the disk in the direction of the arrow marked F until the indicator hand will point to number 1.
NOTE:
Before attempting adjustments to the regulator disk, first lock the pendulums by using the lever located on the front of the base. By so doing, you will avoid damage to the delicate suspension wire while turning the regulating disk.
Keep A Regulation Record:
Keeping a short Record of regulation and maintenance on your clock will make it much easier for you to keep it well with in its optimum time-keeping ability. We have found that using the guideline below helps.
Date: +/- in min: How much adjust in Degrees +/-: Personal Notes:
We recommend logging only the times the clock was wound, and any time the clock is regulated or reset.
Times of regulation will include any time the clock has exceeded a 3 to 5 minute error.
Use only ONE form of time references for this, a QUARTZ clock that is known for keeping good time is recommended.
Over time you may find the clock needs only slight regulation; for example, if it has run for approximately 3 weeks and the error rate is under 3 minutes adjust regulator only slightly or simply RE-set.
TEMPERATURE and SEASONAL CHANGES
Temperature fluctuation can affect the time-keeping abilities of your clock.
Never allow direct sun light to come in contact with your clock. This will over heat the clock and it will not only affect the time-keeping qualities, but also dry out the oil and cause premature servicing requirements.
SPECIAL NOTES: REGULATION TENDENCIES
It is very difficult to look at the hands of an analog clock and still determine if the clock is running correctly, therefore I recommend allowing the time error rate on the clock to remain UN-touched until the error rate has exceeded + or - 3 to 5 minutes. This is because 1 minute is very difficult to observe and calculate effectively.
One little known fact about the Rotating Regulator: After the clock is restarted it can take up to 3 or 4 hours for the pendulum to settle down into regular beat rate. Example: If the pendulum is under rotated the clock will run fast and will take some time to bring it up to speed. If over rotated it will run slow. RECOMMENDATIONS ARE: Look at the actual clock time and reset it as closely as possible to real time after the clock has run for about 3 to 4 hours but don't disturb the pendulum. ONLY RESET THE CLOCK IF the actual clock time is off by 1 or 3 minutes.
If you must reset the clock every 3 to 4 weeks, and it is FOR EXAMPLE always slow, Slightly RE-Regulate the clock to compensate for this rate of error. Simply reset the clock several times just to make sure that no mistakes are made.
How to Calculate the Adjustment:
Calculating how much to turn the regulating nut on the rotating pendulum by using the following calculations.
Link to data base located at http://antiqueclock.clockstop.com/Regulate.html
r/David
on Feb 17, 2010 | Watches
Tip
Cuckoo Clock Repair
CUCKOO CLOCK
REGULATION AND REPAIR TIPS
REF: 30 hour and 8 day clock
[From my shop notes:]
{FACT}
-1/8 inch movement of the pendulum bob is equal to about 3 min per 24 hours running.
-To increase the time of the clock, move pendulum up.
-To slow down the time move, pendulum down.
Regulation notes:
These novel clocks are at best only a "fair" time-keeper. You can expect 100 to 120 sec per 30-hour winding period. I recommend that if it is within a few minutes per winding, simply RE-set the time.
-The regulation obstacles are obvious:
1. Open pendulum, this allows even the slightest breeze from a fan, ceiling fan or even cross-winds inside your house to affect both time qualities and/or its running ability.
2. The Pendulum material is wooden, and sensitive to climatic condition, during times of high humidity the clock will slow down.
REPAIR TIPS:
1. Recommend regular servicing every 2 to 3 years for these unique clocks, mostly due to the fact that the movement is open to the elements (dust and dirt is easily deposited on the movement).
2. Sometimes the clock is "over weighted", meaning that the actual weight is to heavy for the clock. I have seen some very new clocks with the wrong weights added. Instead of the clock simply stopping after the lubrication qualities are gone it continues to run and ruined the bushings.
-To find the correct weight of a newly serviced clock, you can use a small scale. Anchor it to the floor, connect chain to the top end, wind it until it is more than double the weight of the existing weights, and then start the clock to running after the clock stops running, X's the weight figure on the scale by multiplying 1.25 or 1.35 X's the weight figure on the scale by 25 to 35 % maximum = the amount needed. [Example scale indicator is on 1 lb x 25% = 1.25 lb
BELLOW REPAIR:
-Unfortunately many repair persons have opted to simply replace the bellow, this is unfortunate because it can so easily be repaired.
-I use a "RE-COVERING BELLOWS" kit.
-This kit comes with bellow replacement material, glue, one wooden handling tool and great instructions.
DO NOT attempt to simply patch work this, it is not fair to the customer and it will not work long.
THE CHAIN:
If needed, don't be afraid to replace the chain as they are easily ordered and replaced. Most cost about $3 to $4 a piece.
The problems are:
-If there is a child, pet, or adult in the house, the chain can be stretched. If the chain becomes damaged, it will get hung up inside the clock. "Even one damaged link can stop the clock."
-Wrong size chain {the differences between 72 links per foot and 67 links per foot are easily confused). Recommend actually laying the chain on the chain drive gear and seeing if it fits.
MUSIC BOX GOVERNORS:image008.jpg
Clean and oil only. Check the pivots if worn. Don't waste your time to try and repair, just replace the Governor. Only the actual music drum can be sleeved with a new bushing. Cost for a new governor is about $25. Well worth having a few assorted governors in stock.
-If a complete replacement is necessary, the cost is about $40 to $50.
R/ David
http://antiqueclock.clockstop.com/CUCKOO.htm
on Jan 22, 2010 | Watches
Pendulum wall clock from the 50's stops at 6:21
Needs lubrication in the gearing at that point most likely.
Nov 28, 2015 | Watches
MINUTE HAND NOR THE HOUR HAND NOT ADVANCING AS THEY SHOULD. CLOCK STUCK AT 8:45 FOR DAYS, PENDULUM MOVEMENT OK. WHAT IS THE SOLUTION TO GETTING THESE BACK TO WORK? THIS IS ON A STRAUSBOURG MANOR...
without seeing the clock .....are you sure it isn't something as simple as the hands ( arms) detaching from the centre spindle which continues to turn but without the hands. Alternatively have the hands become stuck on something on the clock face or become intertwined themselves ? Very simplistic but all I have to offer...
Feb 24, 2015 | Watches
Coaster model 900723 grandfather clock doesn't keep time
Everybody should know that the coaster clocks discussed here run on batteries. The timing mechanisms, the chimes as well as the pendulum all are powered by a battery. Changing the speed of the pendulum is impossible because there is no adjustment. Besides, it wouldn't matter anyway. The pendulum has now affect on the clock's ability to keep accurate time. It is purely aesthetic. This is a pretty cool looking clock and even has weights, but those are also purely aesthetic and do not move the way a classic grandfather clock weight would move. The moments with these clocks are not designed to be worked on. These clocks are relatively inexpensive (approximately $300) but do add a nice look to your home. Grandfather clocks snobs would say though; this is not a true timepiece. They're right... Sorry._1513.jpg
Nov 20, 2010 | Watches
Quartz president wall clock, I need to set the chime
I have a pendulum wall clock from the president collection. If yours is the same or similar, the following may help:
*Look at the back for a slide switch labled "start" at the top and "set" at the bottom and move it to "set"
*Look for for small push buttons. They represent the hours and minutes. Push each in turn, the number of pushes to represent the time, ie, for 09:45, ignore the first(0), push the second 9 times(9)-push the third 4 times(4)- push the 4th 5 times(5). When done, push the slide switch back to "start".
If yours is the same as mine - a wall hung pendulum clock with Westminster chimes, made around 1988. I would be happy to scan and send a copy of the instructions.
John
Apr 21, 2010 | Watches
Pendulum in beat but stops running after a few
Oiling Procedures
R/
DAvid
Feb 08, 2010 | Watches
My wall clock runs about 10 min utes fast per 24 hours. I has a pendulum with an ajustable screw at the bottom. Can I turn this screw to adjust the running time. If so, which way (shorten or lengthen)?
You have to lengthen pendulum as this will make watch tick slower. Can not say for how much as for every particular clock there are different adjustments.
Do it bit-by-bit unscrewing the screw thus lowering the bob. Observe time keeping day-by-day and eventually you will reach the right length of the pendulum for precise timekeeping.
Rate me, please.
Aug 21, 2009 | Watches
I inherited a grandfather clock which runs slow
You have to adjust the bob on pendulum. If the clock is slow, the bob on the rod must be pushed up. If the clock is fast, the bob must be pushed down. Do adjustments bit by bit, day by day till the clock is keeping time. If all this does not work, you may need to replace suspension spring (if there is any). If there are no suspension spring, the clock may need proffessional attention.
Mar 23, 2009 | Watches
Watches Logo
546 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
