Question about KitchenAid 24 in. KUDS01ILWH Built-in Dishwasher
My kitchen aid ultima quiet whisper dishwasher will not come on. No lights nothing.. there is water still in the bottom of the machine like it didn't finish running the first time.
    Champion:
  • 210 Answers
Check thermal fuse in console.
Posted on Oct 15, 2013
Testimonial: "Thank you.. I am not exactly sure how to do it, but I will look it up on the internet and try and figure it out :)"
  • 530 Answers
SOURCE: Kitchen aide won't drain
look in your air gap first make sure there is no debrie in there this will make you dishwasher drain really slow.
Posted on Apr 14, 2009
  • 234 Answers
SOURCE: Have a kitchen aid whisper quiet dishwasher...will
There is probably a problem with your drain hose being plugged or the drain valve/solenoid is jammed or defective.
You would need to check these two problems and repair or replace parts.
Posted on Apr 17, 2009
SOURCE: Kitchen Aid dishwasher model KDC-18 is not filling with water
Under the machine is the water inlet valve. if you take off the front end of that you find a filter which fills up with rust, and you can clean it out. If that doesnt work, repairclinic.com will sell you a new valve for 32
Posted on Sep 06, 2009
  • 246 Answers
SOURCE: Want to replace dishwasher panel with stainless steel
Yes indeed! If you know the measurements, you can buy a stainless panel from www.applianceart.com cut to any size you would like. THey also have a cheaper "faux" stainless option too. Many colors and designs as well.
Posted on Feb 25, 2010
heatman101
  • 43501 Answers
SOURCE: The dishwasher is leaking at the bottom of the
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
b.,f
Posted on Sep 29, 2010
Kitchen aid dishwasher whisper quiet model door stuck closed
I found this on another site hope it works for you.Take a bamboo shishkabob skewer and look were the handle is underneath the plastic console head unit and place the skewer on the right hand side... angle towards the center of the console and wiggle it in and push up...After i thought of the skewer it took me around a minute to push the latch up.
Read more: http://appliancejunk.com/forums/index.php?topic=5096.0#ixzz3Yhgf8Ihd
Feb 24, 2015 | KitchenAid Kitchen-Aid KUDD03DTSS...
I have a Kitchenaide Whisper Quiet Ultima dishwasher. It will come on, but no water comes in. Is there a reset button or something that may be clogged?
Are you able to provide the model no. of your dishwasher please.
NO water coming in could be either due to water inlet solenoid not working, the controller not working or the flood switch being triggered.
Need the actual model no. to confirm likely situation.
Sep 20, 2010 | KitchenAid Dishwashers
Kitchen aid whisper quiet, model KUDI02CRBL1, leaking water from under the door. Changed the tube door seal, the bottom strip of plastic running across the door on the bottom and today a new soap disp....
Suspect the door latch has loosened enough to allow water spray to get into the latch cavity. Look for worn parts or loose adjustable components in the latch area (both door and case sides). Hope this helps!
Sep 18, 2010 | KitchenAid KHWS01PWH Global Horizontal...
I have a KitchenAid Whisper Quiet Dishwasher. Has been working fine. Circuit breaker seem to be working but control board is now not lighting up and buttons do not respond. Seems like no power to...
I may have leaked water into the mother board ciruitry. This can happen when there is a tiny leak or when steam gets in. Check with kitchenaid, that is a good product and kitchen aid will stand by thier equipment.
Aug 07, 2010 | KitchenAid Dishwashers
My kitchen aid whisper quiet dishwasher will not start and the clean button is flashing
The flashing clean light is an indication that the water did not heat properly. Follow the link below to some instructions I put together that will show you how to reset the control so you can use the dishwasher again and what may have caused the error. Let me know if this is helpful.
Clean Light Flashing
May 22, 2010 | Dishwashers
Have a kitchen aid whisper quiet dishwasher...will not drain
Apr 17, 2009 | KitchenAid Dishwashers
Mar 03, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Water leaking from botom of Door
see if float cup is free on bottom of machine so it is not overfilling. take old toothbrush and clear any accumulated soap buildup from bottom of door and gaskets.
Feb 16, 2009 | KitchenAid Dishwashers
Jan 16, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
KitchenAid 24 in. KUDS01ILWH Built-in Dishwasher Logo
231 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
