Question about Dishwashers
I messed some with my SMEG ST 1124 dishwasher because it was beeping and repeating the same step. I accidentsllly pressed the program delay button and now it is stuck at 8, beeps and wont reset. What should i do? Thank you
    Champion:
  • 210 Answers
Turn off circuit breaker for a minute.
Posted on Oct 15, 2013
4 Suggested Answers
  • 34 Answers
SOURCE: After selecting a program, the
Basically the dishwasher is telling you there is a fault - Not so useful I know! Plug out the machine and leave it for five minutes and see will it reset. If that does not work, you will need to reset it manually. To do this consult the manual. If you don't have a manual, go to http://www.hotpointservice.co.uk/hs/pages/manual/manualSearch.do and down load one. Good luck!
Posted on Aug 13, 2010
SOURCE: how can i reset diplomat dishwasher it is stuck on
turn it off. switch it back on and immediatley hit the programme button 4 times within 2 seconds. This should clear the programme and reset the controller.
Posted on Sep 11, 2010
SOURCE: whirlpool dishwasher ADG 7550. Starts
high i have the adg7550 and the beeping again and again is the water sensor inside the left hand side.apparentley taking the plug off and cleaning contacts solves the problem this did work for me twice but now its being a pig.hope this helps.
Posted on Oct 21, 2010
Just want to change 4 digit code to new one
Do this, with the door open:
Remove cover from assembly by sliding cover up and off. You will then see the program button.
A programmed code can be from four (4) to eight (8) digits long.
Up to 2 user codes can be entered.
Excess delay in the programming steps once started will cause unit to beep twice and will require you to restart from step (a).
Programming the first User Code:
a. Press the program button on the interior unit once.
b. Enter in 4 to 8 digit code onto the keypad.
c. Press the "LOCK" button to save code.
d. Extend the bolt by pressing the "LOCK" button and re-enter the code to test. The bolt should retract to the unlocked position. If it does not unlock, repeat steps (a) through (c).
Programming the second User Code:
a. Press the program button on the interior unit twice.
After programming in just one new code, the existing old code may still work. I suggest that if this is the case, that you program in two codes to make sure that the old one is over-written. You may try programming in the same new code both times if you don't want to have two codes.
Here is a link to the installation and programming instructions that I excerpted the reprogramming instructions from:
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
For further assistance or warranty information: call 1-800-677-5625 USA & CANADA
or visit, www.kwikset.com
Jul 26, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
Cannot set program
Try resetting it by disconnecting the power cable, but at a glance looks like the programmer is faulty.
Jul 28, 2008 | Smeg 18 in. STX45-1 Stainless Steel...
Beeping sound when cycle is finished just started after 8 years. how do I turn it off?
Welcome to FixYa.
I think can answer your question..."beeping sound when cycle is finished just started after 8 years. how do I turn it off?"
Follow these steps...
**How to Operate the Cycle Completion Signal**
1. Open door, hold down program button (see
Beeper Table below) and simultaneously turn the unit "ON".
MODEL Program BUTTON
SHU 9950 Delay Start Hours
**SHU 9910-9920 Delicate/Econo** should be yours
SHU 8800/8810 Quick Wash
SHV 6800 Delay Start Hours
SHV 4800 Delicate/Econo
SHV 4300 Delicate/Econo
2. Release program button.
a. For SHV 6803 and SHU9950 models:
The display will blink with a code of "0", "1" or
"2". You are in program mode.
? If the display blinks with a "0", you will hear
no signal (indicates OFF).
? If the display blinks with a "1", you will hear a
LOW volume signal.
? If the display blinks with a "2", you will hear a
HIGHER volume signal.
b. For all other models with the beeper
function:
? If the machine beeps, then the Cycle
Completion Signal has been enabled.
? When you push the button again and it does
not beep, it means that the Cycle Completion
Signal has been disabled.
3. To change the program, press the program
button until the desired setting is selected.
4. Turn the Dishwasher off to take it out of
program mode.
* At the end of a wash cycle, the beeper will sound
off two times, and again every 15 minutes until the
dishwasher is turned off.
Hope this answers your question and provides you with what you needed.
Thank you for choosing FixYa and good luck.
Please take a moment to rate the solution provided and a short testimony if you feel it's warranted, but also let me know if you require further assistance.
Regards,
Macmarkus :)
Nov 06, 2010 | Bosch SHU9915UC Dishwasher
How do I turn off the annoying beeping alert after the cycle is complete?
Hello Joanna,
Welcome to FixYa.
I think I can answer your question..."How do I turn off the annoying beeping alert after the cycle is complete? "
Follow these steps for the SHV6800 will be the same...
**SHV 6800 Delay Start Hours**...should be applicable to yours, let me know if not.
LOW volume signal.
function:
program mode.
Regards,
Macmarkus :)
Oct 18, 2010 | Bosch 24 in. SHU66C05 Stainless Steel...
How do you disable the cycle completion signal/beep on the Bosch SHU9915UC dishwasher?
Welcome to FixYa.
I think can answer your question..."How do you disable the cycle completion signal/beep on the Bosch SHU9915UC dishwasher?"
• If the display blinks with a "0", you will hear
• If the display blinks with a "1", you will hear a
LOW volume signal.
• If the display blinks with a "2", you will hear a
function:
• If the machine beeps, then the Cycle
• When you push the button again and it does
program mode.
Regards,
Macmarkus :)
Oct 07, 2010 | Bosch SHU9915UC Dishwasher
Top draw beeping delay and water not draining
Not sure what you mean by beeping "delay" I am not sure if there is any such light on the dishwasher. The HRS DELAY is displayed on the LCD when dishwasher has been set in delayed start mode. Are you seeing this flashing in an orange background? There could be several reasons for water not draining. Does the beeping go away if you press the power on/off button? Also does the delay flashing stop. Have you checked to see nothing is blocking the drain pump which is the same rotor that drives the washer arms.. What about the kitchen down pipe - is it clear? If you think you have to take the drawers out to reach the drain hose then follow instructions on page 7 step 2 of the installation manual. It is for a later model but your one should be similar. Make sure you turn the mains power off when working inside the dishwasher.
Jul 06, 2010 | Fisher and Paykel 24 in. DD-602 Built-in...
How do you set up the scanner to scan police and ems channels
First you'll need a list of frequencies to program. For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Once you've selected your frequencies, power the scanner ON and
1. Press E/PGM to enter the program mode (the scanner turns on the
PGM icon).
2. If the current channel is not the one you want to program, enter the
memory number then press HOLD.
3. Enter the frequency including the decimal point, then press E/PGM.
4. To program the next memory, press  or  and repeat step 3. To
program a different memory, repeat from step 2.
5. To exit program mode, press HOLD or SCAN or change the scanner’s mode.
Notes:
• Any frequency you program replaces the previous memory contents.
• If you enter a frequency you have already stored in a different
memory in Step 3, the scanner beeps and displays the channel
where you have previously stored the frequency. If you want to store
the frequency anyway, press E/PGM a second time in Step 3.
• To clear the contents of a memory, enter “0” in Step 3.
• Channels you program are automatically unlocked (see
“Locking/Unlocking Memories) and have Delay turned on (See
“Setting Channel Delay”).
If you would like to download/print the operating manual for you scanner, visit:
http://uniden.com/pdf/BC340CRSom.pdf
BillB
Jan 11, 2010 | Uniden BC340CRS Base Scanner
Lost manual book dishwasher smeg df612se
The program will not move when you press the button.
May 23, 2009 | Smeg 24 in. DWF612SS Free-standing...
Smeg Dishwasher ST 663 sometimes won't work
My dish washer stops after i5 minutes, don't know what the problem is, water is going in but just suddenly stops, i changed the hose but still the same. Any help welcome
Feb 22, 2009 | Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
Dishwashers Logo
120 people viewed this question
Top Dishwashers Experts
