Question about Frigidaire FRS26R4A Side by Side Refrigerator
The freezer drain flows into a receptacle in the fridge which drains to the pan. Periodically this receptacle freezes and water then flows to the bottom of the fridge and onto the kitchen floor. I can clear the blockage but a few months later it happens again. The food in the fridge does not freeze and the fridge thermometer shows the temp above freezing. I have also raised the fridge temperature, but it still periodically freezes.
    Champion:
  • 210 Answers
Flush out drain line and tilt ref. back a little.
Posted on Oct 15, 2013
Testimonial: "Brilliant. Thank you very much. I am a bit embarrassed that I didn't think of that, but I wasn't thinking outside the box as it were. I have raised the front with the adjustment bolt and I expect that will be the end of the problem. Thanks you very much for such an insightful answer."
  • 256 Answers
SOURCE: Water pools and freezes at bottom of the freezer.
I am uncertain as to what you mean by "when tray is full"? However, you probably have a clogged drain in the freezer compartment. During the defrost cycle, which usually occurs every eight hours, defrost components (defrost thermostat & heater(s) ) melt the ice that has accumulated on the evaporator coil in the freezer compartment. The water from the melted ice drains through a hole in the freezer compartment (behind the freezer's rear panel) and accumulates in a drain pan below the refrigerator. This water should evaporate over time, whereby you should not have to regularly empty the drain pan. If the drain hole is clogged (usually from algae or other debris, etc.), the water finds another path to flow (which is inside the bottom of your freezer compartment). This water will usually freeze. Water will then flow toward the front of your freezer compartment and out of the door on to the floor when you open the door.
Contact an appliance service company to unclog your freezer drain. Also have them check your defrost components (thermostat & heater(s)).
Posted on Feb 15, 2010
awcforever
  • 359 Answers
SOURCE: Frigidaire side by side - fridge side temp too low
It sounds as though your thermostat is not cycling your compressor off causing it to run until the point of freezing. If you sit and listen, you will hear it hum. If it never stops humming, 9 times out of 10, the power outage shorted your thermostat.
Posted on Jan 30, 2009
applianceboy
  • 77 Answers
SOURCE: FRIGIDAIRE FRS22ZRGD2
you may need to clean the drain tube again. the only other place that water may come from is the ice maker if it is over flowing. this however would be very obvious. use some thing like a length of cloths line cable to "snake" the drain after you defrost it. the fastest way to defrost it is to use hot water and a turkey baister. good luck.
Posted on Sep 26, 2007
  • 4 Answers
SOURCE: ice in bottom of freezer FRS26ZNH
unkink drain hose...I just opened up the back of my Frigidaire Side by Side counter depth to find the drain hose was bent and collapsed coming right out of the bottom of the freezer and the pan was dry as a bone. It doesn't look like my drain hose has ever drained a drop of water. The freezer bottom is full of ice And the rust and chipping paint under the bottom of the freezer door along with the mysterious puddles of water every morning means the drain system definetely never worked. Frigidaire should be responsible for this. This, along with the ice maker rebuild I had to do,... after ice was spilling all through the fridge. I actually had warrantty left on that one and called customer support in India to find out I could make the repair myself. Yep I had to do it. Frigidaire you failed.
Posted on Oct 25, 2010
  • 2468 Answers
SOURCE: Frigidaire Fridge Freezer forms huge iceblock
the defrost drain pan is plugged up,you need to defrost it and run a wire down the drain tray hole so it can drain to the bottom as it defrosts otherwise it defrosts and runs everywhere else and re freezes
Posted on Jun 05, 2011
The freezer compartment of my F & P Model E522B Fridge/freezer leaks water but the seal appears OK. Why?
draining tube plugged which normally would drain defrost water to a evaporating pan under fridge
Jan 18, 2016 | Fisher and Paykel Active Smart E522B...
My freezer is freezing food fine but my refrigerator seems to be warm and not cooling like it should. The temp control has been adjusted to a higher setting but does not seem to help.
if your freezer is working your fridge is fine
Your problem probably started a couple weeks ago when the drain that allows defrosted ice (water) to drain into the drain pan at the base of your fridge became plugged for some reason. Then everytime the fridge went on defrost more water melted but did not drain which in turn froze. Now ice has built up and caused the air that flows into the fridge to be blocked, causing a warm fridge.... my advice is to leave fridge unplugged for 48 hrs to thaw it and find the cause of the water not to drain... could be a corn niblet or pea from the freezer... the tube should be visible from the inside or the back
Jul 21, 2011 | Amana ABB1927DE Bottom Freezer...
HOTPOINT Refrigerator HSS25GFPE WW - Freezer has some frost and cools but do not freeze. The refrigerator is not cooling at all. Can not ifind the mannual or ifnormation of this particular model in any...
There is a drain that carries water from the freezer to a drain pan in the base of the fridge. It has plugged preventing water from draining and in turn the water has froze blocking the flow of air to the fridge. First you must find the drain line in the rear of the fridge and unplug it as well as thaw the fridge out overnight to allow the water to drain... be patient as there will be a lot of ice to be thawed out, let me know if it works! good luck!
Jul 20, 2011 | Hotpoint Refrigerators
Leaks water inside from the ports or vents under freezer but in fridge
Your problem more than likely is a plugged defrost line in the freezer...The freezer goes through periodic defrost cyles to keep the coils from freezing up. The water catches in a trough pan in the freezer and flows through a drain hole to the bottom of the fridge where it evaporates. This drain hole perodically freezes up and the water accomulates under the freezer bottom until the water level reaches your vent ports to the fridge section. Open your freezer and on the bottom floor of your freezer you should see two screws near the front on either side. Remove them and then take out the bottom tray....this will expose the drain hole near the rear of the freezer compartment. You will more than likely have to remove ice under the tray in order to see the drain hole. Remove the lower back panel on the back of the refrigerator and you should be able to see the drain line coming from the freezer. Unplug the refrigerator before you begin work. It will take a little while for the drain line to thaw to allow liquid to flow to the bottom. I find a hair dryer pretty handy in speeding up the process. To verify you have unplugged the drain line you should be able to pour hot water in the drain hole in the freezer and see it come out at the rear of the fridge in tube line just above a little catch pan
Feb 08, 2011 | Kenmore 64802 Top Freezer Refrigerator
6 yr old side by side inglis fridge/freezer. water
can be from an obstruction (i.e. food or debris) or incomplete defrost. water forms around the drain during defrost cycle and ices up when cooling cycle comes on. defrost the drain and try installing a heat probe part#819043 made by whirlpool.its a metal rod that wraps around the heater and goes into the drain opening to prevent the drain from icing up. hope this helps.
Oct 21, 2009 | Kenmore Refrigerators
Freezer drain tube clogs causing water to drain
drain tube is clogging with debris or freezing? is there a pan under your fridge with a float valve on it, these pans are usually heated and the water evaporates, except when the factory doesnt hook up the wires, because it wont pass the eer rating, you can hook up after you, the consumer has purchased it , i know it sounds dumb but thats what viking does as well.
check that pan under your fridge and see if there are extra wires that are unplugged , plug them together(2) and good luck.
initially you will have to shut your fridge down for a couple of hours to defrost, but once you restart you should be good,
empty that pan under the fridge for now as well
Oct 10, 2009 | Kenmore Refrigerators
Water leaks from top mounted freezer area into the refrigerator
Remove the food from the freezer and the icemaker if equiped . Remove the air tower at the rear of the freezer section and remove the rear panel inside the freezer . Using a hair dryer to the drip pan , below the coils ( probably ice ) , starting at the center , defrost until you see the drain hole . Keep defrosting the hole ( hot water helps ) until water starts to flow down . Using a short piece of hose , insert it into the drain hole and blow . This should blow out any debris inside the drain hole . I would use a short piece of solid ALUMINUM wire ( 14-16 guage about 8 " long ) striped of all insulation , and insert it into the hole as far as possible , without any force . Wrap the other end about 1--1 1/2 turns around the black tube ( defrost heater ) above the hole . When the heater comes on , heat will transfer to the aluminum wire and keep the drain from freezing up again . Reasemble back panel , air tower , and , icemaker . Reinstall the food and its FIXYA'd .
Sep 02, 2009 | Refrigerators
There is water dripping filling up the bottom under the salad container. The model is a LRTN22311TT.
Remove contents of fridge and check the drain line running down the top back of the back of fridge and follow to lower section of fridge (usually a back ledge or under the crisper sections) and locate a small round drain hole. Also, check to see that the drain collector (funnel looking thing at top back of fridge section) is located under the freezer defrost drain opening, to allow water to flow through the fridge into the drain pan under the fridge.
If something has obstructed the drain funnel, path, tube, or lower drain hole, remove the blockage to allow water to drain into underneath of fridge into drain pan for proper evaporation of water produced from the usual daily defrost cycle of fridge/freezer.
If that is not the problem, it could be that you have a leaking water supply line for your ice maker and you'll need to see if the freezer is allowing excessive water to flow out of the ice maker into the fridge section.
Another simple check/solution is that the fridge is not properly leveled, meaning that the front of the fridge should be slightly higher than the rear to allow for proper drainage and self closing of the front doors. This will help keep the water flowing in the built in channels and drains.
A perfectly level fridge isn't the right way to install most moveable refridgerators, while built in fridges (Sub Zero, etc.) are designed for plumb and level installations for proper functioning and use.
Apr 09, 2009 | LG LRTBC1825T Top Freezer Refrigerator
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
186 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
