Question about Bosch Dishwashers
My DW takes over 3 hours to finish and dishes are not even that clean. could replacing the control module correct this? i'm open to suggestions.
    Champion:
  • 210 Answers
Use 'Finish Quantum' soap with a solid rinse aid.
Posted on Oct 15, 2013
4 Suggested Answers
SOURCE: Bosch SHX46A dishwasher
I have a Bosch SHX46B05UC/14 and it stopped functioning right. It filled, it ran, it drained, it sounded okay, but I finally determined there wasn't enough circulation pump pressure to swing the spray arms. Turns out the problem was a pump pressure adjustment screw, accessible under the kick plate, had backed off--now if I can only figure out how to set it properly, low enough to clean the glassware, high enough not to break the pots and pans--or is it the other way around. I also found some beans in the drain sump (easy to remove cover plate from inside with a torx driver, large object trap not locked down properly and a riser for the upper spray arms not press fit sufficiently into pump outlet (I wonder if I blew the line while setting pump pressure. I AM looking for guidance on how to properly set the pump pressure, for the moment, I simply turned it into its spring loaded range and cranked it down a few turns.
Posted on Dec 02, 2007
  • 677 Answers
there is a new product out that actually filters the water going into your dishwasher. I use to have ugly,white and cloudy looking glasses until i installed this product. after the first load my glasses looked fantastic!!!! its affordable and you can get it at dishwasherfilter.com.
Posted on Apr 10, 2008
erpaalai
  • 999 Answers
SOURCE: Whirlpool Dishwasher GU3600XTSB 3 - 4 hours to complete washing
Wash time is determined by the cycle you select, the incoming water temperature and the installation location. The new machines will heat the water to a predetermined temperature and it takes roughly 1 minute for each degree of rise, If the incoming water is at 120 deg and the wash cycle wants 165 than it will take 45 minutes just for that one cycle to complete, Factor in an outside wall with poor insulation or lower water temperature and it could take even longer. Eric
Posted on Dec 30, 2009
Testimonial: "I understand what you have said. However, My previous dishwaser never took this much time. There was nothing wrong with the previous Kitchen Aide. "
Dish washer not advancing to the next cycle
This is usually caused by the heating circuit not heating the water. And most of the time, this is NOT caused by a bad heating element, but instead, by a bad controller. A solder connection to the heater relay has gone bad. You can see this easy enough if you take the control module apart. (Depending on the model, the controller is located EITHER in the door, or else on the bottom right-side of the DW.) It is possible to re-solder this connection and get your dishwasher working again, but this is only a temporary solution because the problem is actually in the relay - the contacts have gotten pitted, causing resistance which causes heat which travels down the leg of the relay, causing the solder to melt. The correct solution is to either replace that relay or the complete control module.
Mar 23, 2015 | Bosch Dishwashers
Why does my dish washer not advance to the next cycle?
This is usually caused by the heating circuit not heating the water. And most of the time, this is NOT caused by a bad heating element, but by a bad controller. A solder connection to the heater relay has gone bad. You can see this easy enough if you take the control module apart. (Depending on the model, the controller is located EITHER in the door, or else on the bottom right-side of the DW.) It is possible to re-solder this connection and get your dishwasher working again, but this is only a temporary solution because the problem is actually in the relay - the contacts have gotten pitted, causing resistance which causes heat which travels down the leg of the relay, causing the solder to melt. The correct solution is to either replace that relay or the complete control module.
Steam coming out of dishwasher
Sounds like the drain hose is partially plugged restricting the water to completely pump out.
Mar 28, 2017 | Dishwashers
Kemore 17509 wont clean glasses are always dirty and some bowls as well. we pre clean dishes before they go in dishwasher
There can be a multitude of causes to a dishwasher not cleaning well. First, check your wash arms - make sure the holes or nozzels are clear (not blocked), and make sure they are free to turn. Make sure you are not over-loading the dishwasher and stacking bowls on top of bowls. Next is to check to see if enough water is going into the DishWasher (DW). This varies with different models, so it's hard to tell you how much is enough. Also, what kind of detergent are you using? We find that powders seem to work better than liquids and gels , and tablets sold by Finish Corporation and Cascade work better than powders. Next thing to check is to make sure the heater is working to heat the water during the wash cycle. (Listen for the soap dish to open, then open the door 10 or 15 minutes later and see if the water is hot.) If your dishwasher has a removable filter, you need to take that out and clean it at least once a month. And finally, if your dishwasher is all encrusted with calcium and hard-water deposits, you probably need to run a dishwasher cleaner in the machine. (Use Dishwasher Magic, or Finish Corp's Dishwasher cleaner, or Glisten, or even Lemi-Shine detergent-booster powder or their dishwasher cleaner.
Hope this helps!
Nov 21, 2011 | Kenmore Dishwashers
Bosch built in dishwasher shu4302uc The dishwasher appears to run through the cycle but the cycle takes over three hours. When the cycle finally finishes the dishes are not completely dry. Is there a way...
There are no adjustments for cycle timing. What does affect timing is temperature of the water coming into the DW. The hotter your supply water, the shorter the time to cycle, BUT if your water is too hot, the cycle time may become too short to light the NSF 'Sanitize' indicator. But since the cycle is taking so long, this is an indication that the DW's water heater is not heating the water hot enough to advance the countdown timer in a timely manner. The control logic is waiting for the temp to come up to an appropriate level to ensure adequate washing, rinsing or drying times. Likely your display is showing '1' for a long time as a symptom of this problem, as well.  - This link http://www.applianceaid.com/boschDW.html has procedures to run self-tests on various Bosch models. I suspect that you can confirm a 'heater fault' on your unit by running the self-test.  - This problem invariably relates to a 'heater fault' which has usually been traced to an open solder joint on the control board located behind the switches/indicator lights on front door. If you have a Torx driver, soldering iron & bit of solder, you can effect a repair yourself in about an hour. Otherwise, a replacement control board is required.
If you'd like to attempt replacing the control board yourself, refer to this link for part & DIY information. http://www.appliancejournal.com/appliance-parts/bosch-appliance-parts/bosch-dishwasher-control-module-266746-37/
- Else, place a service call to the tech of your choice.
Feb 22, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishes not getting clean, left with gritty residue. Could the filter be backed; if so how do I fix it?
Had the same problem with a GE Nautilus 3400 series.
Solution:
- In their manual, GE recommends not stacking tall dishes on the bottom right tray - this prevents the dishwashing powder from fully dissolving. Are you using the right detergent and rinse-agent ?
If your upper arm is not turning during wash (DW leaves residue on top-shelf items), do the following:
1) Empty the DW.
2) Pull down the rotating arm on the DW ceiling. Thoroughly clean the passageways (I had to tap it on the counter to break-down the sediments).
3) Inspect the mesh-screen filter located on the floor in the back - if it's backed up (ours was backed-up from the inside), you'll need to clean it by removing 4, 1/4" screws holding it to the DW floor and throughly cleaning it (I also unscrewed the plastic valve located on the bottom of the filter compartment). While you're at it, remove the plastic mesh on the DW floor (2 screws) and fish for any objects and sediments blocking the pump.
4) Replace filter and bottom mesh and operate the DW in "Rinse" mode.
5) Press the rotating arm back in and operate the DW in "Rinse" mode. Check rotation.
- Good Luck !
Feb 21, 2009 | GE Nautilus 24" Built-in Dishwasher
I actually don't know what type of Bosch I have. I know that is a problem, but maybe you can still help. It has a simple panel that says: Pot Scrubber, regular wash, quick wash, rinse and hold. When I turn...
On a Bosch dw, it has a light sensor to sense soil in the water.. if the control feels that the water going through the sensor is not clean/ or clean it will add or minus time..one thing you can do is make sure that your drain line from dw to sink drain is cleared of debris.. also, make sure you clean the filter at bottom of dw and make sure its reinstall correctly if you haven't already do so.. if your dw finish the cycle and come out clean, then the time on your dw is fine,, but if it don't finish and come out dirty.. then, it could be something other, but don't know til I get the full details on problem.. help this will do it for ya.. good luck.. mike
Jan 23, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
My SHU53 only starts on 2Hr Delay and water is not getting hot
Bosch dishwashers run the heating element directly from the control module, which usually causes the solder joint to go bad.....solution, replace the control module, or take the old one out, and repair solder joint
Dec 27, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Keep running at one minute?
well lots of times there is a mylar ribbion on the control panel that you can un hook and gently clean it with a pencial eraser as they are sensitive to resistance and lots of times this will fix it try it before the control panel im in the usa and havnt had a lot of hands on with bosch
Mar 24, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Soap film on dishes
Rodney B if you are sure that the white film is detergent and not hard water deposits, then look at how you are using the detergent. When you watch the TV ads for dw detergents, they are showing baked on/extemely dirty dishes being put in the dishwasher and coming out clean. Well they do this as the dw detergent is designed to break down protein based food products. Fats, oils, and such. If you are prewashing your dishes before putting them in the dishwasher, then there is nothing for the detergent to attack and attach to, so it ends up staying in the dishwasher. If you are going to rinse your dishes, then you need only 1 tablespoon of detergent. Dishwashers are designed to clean using 4 parameters, hot water of 130 degrees, water, detergent,& pressure of the water jets. That is how they clean dishes. Now if this is hard water deposits, switching to an enviromently friendly detergent which is high is Citric Acid (What gives Tang drink its tartness) this will reduce this issue. Hope this helps
Jan 30, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
51 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
