Question about LowerPriceUSA.com Motorola Droid X MB810 Trans. Protective Case Faceplate Cover
My 2003 Kia Rio gets hot the clutch slips in fourth gear is an automatic transmission Any suggestions on what I can do to fix problem?.
    Master:
  • 359 Answers
Sounds like your clutch is wearing out. You will have to get it replaced. You should try and keep your automatic in the lower gears most of the time. Usually the L setting on the automatic will keep it in lower gears.
Posted on Oct 15, 2013
Hard to shift into first gear, second gear....... What to fix / replace
Manual or automatic transmission? Manual, synchronizers are bad. Automatic, could be a solenoid or clutches.
Mar 27, 2016 | 2005 Kia Rio
My 2005 Pontiac Bonneville GXP will not shift into 4th gear I was to it was a fourth gear band but is that the only problem that will cause itI'notto shift into 4th gear
Which transmission does yours have 4T65-E or 4T80-E ?
4T80-E
No Fourth Gear
Checks
Causes
1-2 Shift Solenoid Valve
Inoperative
Debris
Pinched wires
3-4 Shift Valve Bore Plug
Misassembled
4th Band
Burned, slipping, missing
4th Servo Cover
Cracked
4th Servo Pin
Broken, seized
4th Servo Piston
Damaged
4th Servo Seals
Rolled, cut or damaged
4T65-E
Slipping or No Fourth Gear
Slipping or No Fourth Gear Checks
Cause
DEFINITION: A large engine RPM increase is noted in fourth gear, Drive range, with little or no vehicle forward speed increase. First, second, and third gear operation are normal. Shifts into fourth gear are soft or do not occur. Fourth gear ratio is 0.705:1.
Automatic Transmission Fluid Level
Low fluid level
Transmission Main Line Pressure
Low transmission main line pressure
Oil Filter Assembly
• The oil filter assembly (100) is missing, plugged, or damaged.
• The oil filter seal assembly (101) is missing or is damaged.
Control Valve Body Assembly
• The 3-4 shift valve (362) or the 4-3 manual downshift valve (360) is stuck or binding.
• Debris is found in the passages of the control valve body (301) or of the control valve body spacer plate and gasket assembly (396)
Case Cover Assembly
Distortion or damage occurs at the manual valve (404) or at the case cover (401), causing PRN oil leak.
Driven Sprocket Support Assembly
A plugged third clutch oil passage in the driven sprocket support assembly (609)
Fourth Clutch Assembly
• The clutch plates (500-502) are worn, damaged, or misassembled.
• A missing or not seated fourth clutch spring retaining ring (601)
• A damaged spring assembly (602) or piston (603)
• Worn or damaged fourth clutch piston seals (604, 605)
Third Clutch Sprag Assembly
• The sprag (720) was misassembled or backwards on the inner race (661).
• A damaged third clutch sprag assembly (653, 661, 719-721)
Dec 06, 2015 | Pontiac Cars & Trucks
How to fix a clutch for a kia rio 2003
What is wrong with your clutch first of all? Is slipping or smells like it is burned?
Most manual transmissions cars have a clutch adjustment to compensate for the wear on the clutch , some cars have a hydraulic adjustment.
Depending on how bad is the wear on the clutch you might need to replace it especially if the clutch overheated and is glazed.
May 10, 2014 | 2003 Kia Rio
03 Kia Rio will not engage into drive when cold (Automatic)
This is a situation of low pressure,as you warm up the vehicle the transmission fluid is warmer which allow the torque convertor to produce pressure to collapse the clutch pack and transfer power for a shift gear,your solution is a torque convertor and a front pump
Mar 27, 2012 | 2003 Kia Rio
NO THIRD OR FORTH GEAR AVABLE ON MY 2006 KIA RIO RECENTLY REPLACED SLAVE CYLINDER
Rebleed slave cylinder if you had third and fourth strong before. Do they catch when you're sitting with the car off and moving gears into position?
Nov 22, 2010 | 2003 Kia Rio
2003 Kia Rio manual transmission, stick is stiff g...
I would check the operation of the shifter cable. It may need lubricated.
May 20, 2010 | 2002 Kia Sedona
2002 Sedona: 2003 Kia Rio manual transmission, stick is stiff g...
I have the same car, the only solution to this problem is to tighten the clutch cable nut just as necessary until you feel that you are able to shift smoothly without forcing it, make sure you start the car to test for that.
You might have to remove the air intake in order to access the clutch cable.
If you tighten the nut too much, your clutch will feel light and you will have clutch slips. So basically keep trying until you're there. You can loosen or tighten the nut while the car is running, I'd recommend.
Source: Experience.
May 18, 2010 | 2002 Kia Sedona
I want to know what type of enigne oil i neeed for my 2007 kia rio
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......API*
100% Synthetic 0W-20 Motor Oil
SAE 5W-20 XL Synthetic Motor Oil
SAE 0W-30 Synthetic Signature Series Oil
Above 9°F......15W-40
Above 0°F......10W-30
Above 19°F......20W-50
All Temps......5W-20
Manual Transmission,.....GL-4
75W-90
Synthetic Manual Transmission and Transaxle Gear Lube 75W-90
Automatic Transmission,4 Speed AT.....SLF[1]
Synthetic Automatic Transmission Fluid
Fluids
Power Steering Fluid.....PS
AMSOIL Universal Synthetic Power Steering Fluid
Brake Fluid.....HB
Series 500 High Performance DOT 3 Brake Fluid
Clutch Fluid.....HB
1. Kia automatic transmission fluid, SP-III.
PLEASE DON'T FORGET TO RATE!!!!!
Mar 14, 2009 | 2007 Kia Rio 5 Sx M/T Hatchback
LowerPriceUSA.com Motorola Droid X MB810 Trans. Protective Case Faceplate Cover Logo
42 people viewed this question
Top LowerPriceUSA.com Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a LowerPriceUSA.com Cell Phone Expert? Answer questions, earn points and help others
