Question about Apple iPod MA446LL/A MP3 Player
Started a sdram full test which took a while but is now flashing, meaning ''pass'' reset to continue but how do i do that?
    President:
  • Apple Master
  • 688 Answers
Press the Menu and the Center buttons and hold until the ipod reboots.
Posted on May 15, 2009
Can't reset. When I run a sdram full test It says RUN: BL on, PASS: BL blink, FAIL: BL off, reset to continue. What does this mean?
Have you been trying to reset it from backup? If so, you need to set it up as a new device. You may have to use someone else's computer if that still doesn't work. Also, just to make sure you have the right steps...
Apr 12, 2015 | Apple iPod classic MP3 Player
1998 Town & Country Dash Buttons are Flashing on and off
set it on full cold, set it to panel vents, blower motor to high. hold the wash and rear wiper buttons on the control head until all the lights come on. it will run through different tests, different lights will flash and alternate, and when it is done the rear wiper button will flash if everything passed. push it and everything will go out. if other lights still flash when it is done, you have failed the cooldown test because the a/c doesn't work right, or a door calibration did not pass.
Jun 07, 2013 | 1998 Chrysler Town & Country
Older ipod classic blinking : SDRAM FullTest Please wait...... Run: BL on Pass:BL blink Fail: BL off Reset to continue. Cannot do anything to stop it or reset it????
switching the power buttong from off to hold a few times and then simultaneously pressing Menu and Select buttons worked! omg thank you so much! =D
Nov 20, 2010 | Apple iPod MA446LL/A MP3 Player
It says sdram full test reset to continue and is flashing
make sure your ipod is in the on position push the middle button & the menu button @ the same time for about 5-10 seconds you will see and apple appear just let it reset itself
Jan 08, 2010 | Apple iPod MA446LL/A MP3 Player
My ipod ask for a reset so now it stuck on the screen that says sdram full test reset to continue
press the MENU and CENTER buttons together for about 10 seconds, while connected with the USB cable to your PC.
Aug 29, 2009 | Apple iPhone 3G
Code error problem
THIS IS TEMPORARY FIX, NOT A TOTAL SOLUTION. jUST TO GET WATER TO DRAIN AND RESET WASHER. , WITH WASHER POWERED OFF, PUSH AND HOLD START BUTTON FOR 4 SECONDS, RELEASE FOR 4, PUSH FOR 4 RELEASE FOR 4 UNTIL THE FRONT ALL LIGHTS UP AND DISPLAYS 88. sOON YOU WILL SEE YOUR CODES FLASHING, PRESS START BUTTON AS MANY TIMES NEEDED TIL NO MORE CODES FLASHING. tHEN WASHER WILL GO INTO DIAGNOSTIC TEST. aFTER THAT I DO NOT KNOW, BUT YOU CAN WASH 1 LOAD OF CLOTHES AND THEN PERFORM DIAGNOSTIC TEST AGAIN. THAT IS WHAT I AM DOING JUST TO HAVE A WORKING WASHER TOO MUCH TO FIX FROM WHAT I AM READING, SO GOING TO BU A NEW ONE ANYTHING BUT KENMORE. gOOD LUCK, HOPE THIS HELPS FOR IMMEDIATE RESCUE.
Jul 24, 2009 | Kenmore HE2 Plus Front Load Washer
Blinking panel button lights
That has to do with your computer for your body controls, such a/c, heater, wipers, etc...
Most common problem is drinks spilling into the computer which is right between the cup holder. It will eventually cause a problem with a/c most likely.
Jun 24, 2009 | 1998 Dodge Caravan
E:91:01
contact me @ mike@digitalcamrepair.com repairs on this issue start at 35.00 and can go up to 85.00 depending on the full issue it is ether a flash circuit or a cable or a main board.
Nov 26, 2008 | Sony Cyber-shot DSC-W35 Digital Camera
Ipod 30GB
There may be 2 solutions for this problem:
The 1st solution:
The first thing you should do is locate the lock button on your ipod. Second make sure it's unlocked, lock it and wait for one second and then unlock it. Finally hold the inner Grey circle button in the center of the ipod until you see the apple logo appear on your screen.
The 2nd Solution:
Plug in your ipod and click on your ipod in your itunes library. By doing so you should be on your contents tab. Click on the settings tab and then click on restore. This should restore all your defaults on your ipod. Before you do all this; make sure you back up1.gif your ipod library if you don't currently have them in your itunes library.
If this solution helps you out please give rate me and leave a comment. Thank you...
Mar 15, 2008 | Audio Players & Recorders
Apple iPod MA446LL/A MP3 Player Logo
371 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
