Question about Gateway Computers & Internet
HOW to the underscore key on a gateway laptop
HOW CAN I USE MY UNDERSCORE ON MY KEYBORD
Press Control and U keys at the same time to turn on and turn off underscoring.
Feb 22, 2015 | Computers & Internet
Where is the underscore key on my new hp laptop
Numerical key "0" ( use Shift Key for Underscore) after it'll be there for HP laptops and others mostly...
Sep 01, 2013 | HP Computers & Internet
Gateway keyboard kb 0817
Is the "Hyphen" key working?
May 21, 2013 | Computers & Internet
Where is the underscore key on the hp pavilion g4
Hello,To create an underscore, hold down the Shift key and press the " - " (hyphen) key to the right of the 0 (zero) key on the top row of your keyboard.
Apr 12, 2013 | HP Pavilion G4 G6 G4-1000 Series...
Can I dl or burn to disc the factory reset for my gateway nv5105u laptop? I have lost that CD
If you have lost the CD you can try to do a factory reset from the recovery partition. Make sure you haven't formatted or deleted any partition in the computer since your purchase.
Using the Recovery Partition to perform Recovery.
First turn off your computer
Turn on the system and keep tapping the F11 key
system will boot into recovery partition. Follow the instructions below:
  1. Boot into Gateway System Recovery - Press F11 to Start Recovery.
  2. On the System Recovery Menu screen, press the ALT+D keys.
  3. At the command prompt, type: D: and then press ENTER.
  4. At the D:\ prompt, type: CD Windows\i386 and then press ENTER.
  5. At the C:\Windows\I386 prompt, type: dir filename.* and then press ENTER.
  6. Verify if the file name has an underscore ( _ ) in the extension. Example: appwiz.cp_. If the file has an underscore, it has to be expanded. If it does not have an underscore, the file can be copied without expansion.
  7. If file has an underscore, expand the file to the destination. At the command prompt, type: Expand filename.**_ C:\Destination. Example: Expand appwiz.cp_ C:\Windows\System32
  8. If file does not have an underscore, copy the file to the destination. At the command prompt, type: Copy filename C:\Destination. Example: Copy atmadm C:\Windows\System32
  9. At the command prompt, type: Exit.
  10. Once back at the menu, click Quit. The computer restarts.
It should be reset to Factory settings.
IF YOU DO NOT HAVE ANY RECOVERY PARTITION OR HAVE DELETED THE PARTITION THEN PLEASE REVERT SO THAT I CAN HELP YOU TO GET A RECOVERY DISC.
Thank you for using Fixya..!!
Aug 05, 2012 | Gateway nv5105u Notebook
Where is the underscore key on my laptop
The minus key (-) to the right of the zero key (0) at the top of yuor keyboard, is what you're looking for. If you hold down the Shift key and then press that Minus key you will create an underscore (_).
I really hope this helps, but if it does not, please post your laptop model name so I can better answer your question!
Dec 18, 2010 | Computers & Internet
Underscore key doesnt work on laptop and I need to use it :(
To use the underscore once straight away, just copy from here "_" and paste it wherever you need it.
To fix the key on your keyboard, whatch this tutorial which is for HP laptops
Dec 09, 2010 | HP Computers & Internet
Keyboard key not working
have you use the cobination of shift key when using this dash and equal key
dash+SHIFT PRESS BOTHE THE KEY TOGETHER.
Sep 16, 2009 | Gateway 2520796 Keyboard
After post test black screen with underscore blinking
I had a computer that done that once, turned out to be memory. Mine wasn't a Gateway though but might be the same problem. Just something I have seen, maybe that will help.
Feb 27, 2009 | Gateway e-4200 P2 400MHz Tower...
How do I underscore
The key combination can vary depending on what language and keyboard files you're using. However, the easiest way might be to use Windows own Character Mapper to copy the underscore to the clipboard.
Run CHARMAP (in XP, from Start menu -> Run and in Vista from Start button -> start search)
Find the underscore character, and copy it to the clipboard. Go to where you need it and use CTRL-V to paste the copied underscore into wherever it is you need it.
May 26, 2008 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
29 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
