Question about IBM NetVista A40 PC Desktop
Boot option bios - IBM NetVista A40 PC Desktop
  • 22 Answers
Go to the Lenovo site to download the latest BIOS and update.
http://support.lenovo.com/en_US/downloads/default.page?selector=expand
Posted on Oct 15, 2013
Usb boot drive using bios
You may need to enable USB boot function in the BIOS or change the boot order. In some cases the USB boot function has to be forced from boot priority in the BIOS.
Or goto the boot menu when you first turn the PC on there should be an option to use USB Boot assuming the option is enabled in the BIOS already.
Nov 22, 2013 | Toshiba Satellite C655-S5125
How to change boot options to usb in dell optiplex gx520
Go into BIOS buy pushing F2 when the machine boots. Once in BIOS, look for boot options and make sure to select USB/External Drive is an option.
Alos, make sure that your current BIOS is able to boot via USB. May have to update your system BIOS
Oct 23, 2012 | Dell OptiPlex GX520 PC Desktop
I have a Dell mother board model 0WF887. It has the usb boot option on the boot selection menu. There is no option for this in the BIOS setup. Does this mean I'm SOL for booting from a flash drive? It...
Some BIOS will only give you the option for USB if there is a USB detected upon boot. List all your boot options it could also be listed as something like Legacy USB, USB FDD, USB HDD
Aug 31, 2011 | Dell (0141E) Motherboard
The motehrboard bios doesnt boot from usb to install windows, how can i update the bios to boot from the usb?
Insert your USB jump drive into a USB port on the computer containing the bootable program. Copy the information to your jump drive, then insert the drive into a USB port on the computer you wish to boot the program from.
Power on the computer. When the computer begins displaying its startup information, hit the key indicated on screen to enter the computer's BIOS (the "F1" or "Delete" keys are commonly used to access the BIOS).
Browse through the menu options in the BIOS to locate the computer's startup and booting options to locate the "CMOS" menu, which is where you'll have the option to set which devices will boot at startup.
Browse though the list of bootable option---they'll be ordered as "First Boot Device," "Second Boot Device" and so on. Set the USB jump drive as the first bootable option---your BIOS may refer to the drive as a "USB Removable Floppy Disk."
Save and exit the BIOS. When your computer restarts, your program will boot first before your operating system.
Feb 17, 2011 | Intel QDI P2PE/800 Pro 82845PE Socket 478...
I have inteldotstatin it is creating a problem that is system is not opening please give me the solution thanks&regards ranjith kumar
Ok,
The problem might be the boot device configuration
in first press F2 while your BIOS is loading
When your BIOS software start to load it will ask you for a
password, press enter and wait for the BIOS to load.
When your bios finish to load go to the option called Boot
you can get there using the arrow keys.
When you find the Bios option called boot you will see a boot sequence
at the first boot device option select Ide-Hdd.
If you want to load your OS using a PXE Boot(network boot)
select Intel PXE 2.0 as your first boot device.
If you want to Load the default config of your Dot Station(wich will make you boot from the hard-drive) go to the bios setup opition called exit and select the option Load Setup Defaults.
press F10 to exit saveing the configurations you did.
Hope that it helps you.
Dec 08, 2010 | Intel Dot Station (INTC300AIO) PC Desktop
How to shut off usb drives from booting up in bios?
Go to bios options, and search for the option called "USB BOOT" Disable this option. and in the option "boot device priority" don't keep the first boot device as removable drive.
You can go to bios by pressing DELETE key at the point when switch on the PC
Any Questions you can contact me.
Rate my solution.
Regards
May 25, 2010 | ASUS P4P800E Deluxe (90M8LCW0G0EAY)...
Cannot boot from cd and run setup
When booting, the writing on the black screen should give you a couple of options akin to
Press F2 to edit boot options or
Press "Del" to enter setup. (bios)
You can use either, but you need to set your CD/DVD disk drive as the first boot option.
May 04, 2010 | Microsoft Windows XP Professional SP2
How to set boot priority in bios is thinkcentre lenovo it has no option in bios
when i am enter in the lenovo bios in bios option have four option for first boot device. which i am select.
Oct 21, 2009 | Lenovo ThinkCentre® M55-8810 PC Desktop
Acer Aspire 5100-5674 won't boot. Keyboard won't work, mouse initializes. PXE-E61 : Media Test Failure then PXE-M0F : Exiting PXE ROM I really need some help, I just bought it. And would really like to...
PXE errors are generated by the network boot ROM. In other words, the boot process is attempting a network boot (your BIOS' 4th boot option), which means that your system was unable to boot from a HDD, CD-ROM, or USB device (the first 3 boot options).
PXE-E61 Media Test Failure, System won't boot:
1.Go to Bios Settings
2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
3.Save The configuration
Also verify if your harddisk is detected by BIOS
Jul 30, 2009 | Acer Aspire 5100 Notebook
Boot from CD does not work.
You should definately be given the choice to boot from cd, when you press F2 to get into the bios and go to boot options, what boot options do you have?
If you go into the bios you should have the choice to boot from ide (hard drive), cdrom, floppy disk, network (on some) and try other boot media.
Are you going into the boot option in the bios by pressing F2.
Jan 14, 2009 | Compaq Evo N610C Notebook
IBM NetVista A40 PC Desktop Logo
32 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
