Question about Saeco Classico Espresso Machine
Water not dripping enough
Hi my machine has problems,Ok the water doesnt seem to drip verry well from the pressurize portafilter, it litely drips the water stays in the filter, then i noticed that water was coming out of the screws under where the portafilter is. could this be the g.h gasket?
  • 2,039 Answers
Maybe our coffee is to fine of a grind
Posted on Jul 31, 2009
How do i fix the Coffee flow from only dripping through?
if it has a filter ,replace. use vinegar through the water resevoir. fill it and turn it on.
May 26, 2014 | Rancilio Silvia Espresso Machine
Temp water from portafilter
you want between 94 and 96C for water temp and you want 13.8 kg tamp pressure you want extraction to commence at most 9sec into button press an to pour like room tmp honey would. Drip drip start is okay at times but should start to flow by about 10 additional secs in you want it to extract with about 9.5bar pressure and you want to stop full shot extraction by the third colour change no longer than 4 sec of blonding or tigerstriping what eva u wanna call it.
sounds like your element needs to be changed out/is shagged or you have a leak in a weld any leeks water or steam take off housing an inspect
Nov 07, 2013 | Rancilio Epoca ST
Air Conditioner not dripping
your relative humidity outside and in is low so it's not condensating on the coils is the only thing I can think of.
Jan 14, 2018 | Amana Heating & Cooling
Coffee sprays from portafilter spouts while pulling shot
Either the group gasket is dirty or damaged. Also check the basket for damage.
Jul 21, 2010 | Gaggia Classic Espresso Machine
I have an Astra Mega I single group espresso machine 110v. I seem to not be getting enough water through the portafilter and it is all clean.
Remove portafilter, shower and screw and run the head. Did you get a nice steady flow or a weak drip. If a weak drip then the solenoid or the metering jet on the head is blocked and needs to be cleaned. If you get a nice flow the adjust the grind on the coffee to coarser.
Jan 15, 2010 | Astoria Divina SAE-1 Espresso Machine
Frothing works perfect....water is extracted just fine. BUT when I put coffee in the basket and tamp it down and put it in the machine it just makes noise like it is about to drip and nothing comes out,...
I have a brand new Via that never worked right out of the box. Could barely get any espresso to come through the portafilter. Got a new portafilter and the espresso now flies out of the machine beautifully. Seems they are shipping2_bing.gif units with faulty portafilter. Bad news is a new portafilter is like $65. See if you can get them to give you a new one. I had the same issue as you, very little espessso comes out.
Dec 29, 2009 | Saeco VIA Venezia
Francis francis x5-espresso splatters all over
1) The coffee you are using may not be ground finely enough to provide a proper extraction time, resulting in water rushing through the ground coffee much too quickly. Think of it like water running through a handful of pebbles as opposed to a handful of sand. You want "sandier" coffee.
2) Your gasket (the rubber part that seals the portafilter to the group head) may be worn/damaged and is leaking water when you are brewing. Attempt to contact FF! or Saeco to secure a replacement gasket. When you are not using the machine, don't tighten the portafilter all the way in to the head, either leave it completely disengaged or only loosely attached. This saves wear on the gasket.
3) Your brew water may be too hot. Purge your boiler right before brewing by running water into a bowl without the portafilter locked in. After a few seconds the superheated water will be run out and you're ready to brew.
Mar 13, 2009 | FrancisFrancis! X5 Espresso Machine
Water hissing at back of brew unit after coffee made
I think you have to replace the steam valve.
Have you descale your machine regulary?
How old is your machine?
Maybe your boiler have to be replaced:-(
Jul 25, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Classico Espresso Machine Logo
219 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
