Question about Dell Computers & Internet
Using HDMI on my t.v. to my computer with VGA, what is the best way to do this?
  • 281 Answers
You are connecting your TV to the computer instead of using the computer monitor, you mean?
Posted on Oct 15, 2013
Testimonial: "Yes"
VGA to HDMI converter connection and set up
Use VGA adapter to HDMI works for video
Sound is carried over stereo cable
What you are doing needs 2 cables
Video cable for video
Sound cable for sound
Using TV for monitor VGA to HDMI 32" at 120 refresh is best dot pitch .
over 32" dot pitch is lower may become grainy resolve place monitor away more from you when using over 32" TV 120 refresh is important
Jul 15, 2016 | Computers & Internet
I have HDMI laptop and Dell 1706FPVT 17" VGA monitor. I have VGA to HDMI cable and I connected the cable between these two machines but it is not working. Solution, please.
First of, a little bit of explanation.
VGA = analogue
HDMI = digital
The answer seems to be in your question.
it reads "VGA to HDMI". These cables or adapters doesn't work the other way around. I am guessing your cable can only support vga output to HDMI input. And your setup is HDMI output from your computer to vga input to your monitor.
Solution:
Try and find HDMI to VGA cable or adapter. This is expensive.
If your computer has a vga output, use this with vga to vga. You won't get a better resolution by using HDMI to vga.
Or are you stuck with only HDMI output?
There are adapters for USB to VGA too. This could be less expensive. I have one for my friends Apple Air. I am not a "i" fan so I do not have much experience on Apple.
Hope this helps.
May 04, 2014 | Dell 1706FPVT 17" LCD Monitor
Computer not recognizing HDMI, but recognizes VGA
i would try go to - graphic properties(options) and try to browse for display options, if nothing's there than browse for update for your graphic card drivers on laptop producer website or hdmi drivers
Feb 11, 2014 | HP Computers & Internet
Need to use my HDMI t.v. as my computer monitor. Computer has: VGA T.v has: RCA, HDMI, Y, Pb, Pr What is the best way to do so?
you can buy a converter to convert Vga to whatever you want.... or buy a more updated video card that has HDMI
Oct 14, 2013 | Dell Computers & Internet
WHAT TYPE OF CABLE DO I NEED TO CONNECT HP NC6400 LAPTOP TO HD TV TO WATCH MOVIE ON TV FROM LAPTOP? VGA TO HDMI CABLE? THANKS
Hi.
The best way is to get a s-video converter to connect your round s-video computer output to your HDMI port on your tv. This is the best you can do according to your laptop connections. You will need a s-video cable, HDMI upscale converter box and HDMI cable.
The other way is to plug a VGA cable to your tv VGA port if you have one.
VGA to HDMI is also possible with a converter. A standard VGA cable with a HDMI plug on the other side will not work because your computer sends out an analog video signal and HDMI is digital only.
Hope it helps!
Feb 08, 2011 | HEWLETT-PACKARD HP NC6400 Core 2 DUO T5600...
How do you connect LG W2261 VP Monitor to HP Pavilion 6310uk Desktop
The computer has VGA, DVI-I (dual link) and HDMI ports. The monitor has VGA, DVI and HDMI but only came with a VGA cable. Some computers have recently come with shielding covering all of the ports except the one that is currently live. Thus, check your hardware; the computers I've seen with only one active port, the HDMI port was active before resetting the video options. So get an HDMI cable (it will provide the best signal in addition). If the DVI-I port is currently live, you should get that cable as well and then change the settings to enable the HDMI port.
I hope this helps.
(you do not need to get the super-expensive cables; the low end ones will be fine. However a single link DVI cable is not the same as a dual link cable; sometimes using the wrong cable leads to no signal to the monitor.)
Oct 12, 2010 | LG W2261V 22" LCD Monitor
Want to use my tv as a monitor for my pc
Yes!
You need to look what ports your TV has and what ports your computer has.
If its a newer TV it will look better.
the Ports on a PC to connect it are VGA, HDMI, DVI and S-video
http://www.microsoft.com/library/media/1033/windowsxp/images/using/setup/hwandprograms/67360-video-card-annotated.jpg
HDMI:
http://www.360drives.com/images/xbox360-hdmi.jpg
Now that you know what they look like look at your computer and look at your TV and see which ones you have in common. A adapter might be required.
Use the best one! From Best to Worst:
HDMI, DVI,VGA, S-video.
Apr 25, 2010 | HP Pavilion dv1000 Notebook
How do you hook up the tv thru dvi out with a sony pcv-rs620g
There are several ways to do this. The two best are:
1. Get a DVI to HDMI cable. This will allow you to plug directly from your computers DVI to your TV's HDMI.
2. If your computer has an analog (rgb (vga) 15 pin) input, you can simply get a dvi to vga adapter and plug into that port.
Currently, I am using option 2 for my own use.
In the photo below, I point out the HDMI, RGB (VGA), and audio inputs. You must use the audio input but you have a choice of using the HDMI or RGB for video input from your PC. If you have the extra HDMI slots, I would use that. If not, the RGB is fine.
Mar 05, 2010 | Sony PCV-RS620G PC Desktop
What kind of connector do I use to connect a dell laptop to a Hitachi 42'' plasma display? HDMI to DVI or HDMI to VGA?
If the TV has a VGA connector then use a VGA to VGA cable from your laptop as most laptops have a VGA output. Otherwise use one of the other combinations that work HDMI to DVI or HDMI to HDMI..
Nov 11, 2009 | Televison & Video
Trying to get computer to display on my tv
you mean your tv doesnt recieve signals from your computer try using a monitor and a tv first at the same time then go to the graphic video to change it from monitor to lcd tv.
Apr 29, 2009 | Computers & Internet
Computers & Internet Logo
16 people viewed this question
Alun Cox
