Question about Frigidaire GLTF2940ES Front Load Washer
The washer will go through all of the cycle , except at the end with 1 minute showing, the machine keeps running and does not shut off.
  • Official Brand Answer
  • 4,342 Answers
Good Afternoon Patricia, thank you for allowing me to assist you!
Often when a washer does not shut off, it is because it is either experiencing a communication error with the control board or the unit has a faulty timer. Before replacing parts, I would first recommend resetting power to the unit for about 30 seconds. If the issue persists, it is advisable to contact an appliance repair tech to accurately diagnose and make the appropriate repairs.
Posted on Oct 17, 2013
2 Suggested Answers
miket756
  • 2702 Answers
SOURCE: washer stops running with 7 minites left in cycle
this is a program fault,,, needs new program bord,,,pricy that is?
Posted on Nov 28, 2010
My 15 yr old Bosch d/w starts at 13 min & runs to 1, doesn't gets to CL. No water in or drain out.
IF IT ENDS UP WITH WATER SHOWING AT THE END OF EVERY WASH THEN THE DRAIN PUMP IS JAMMED OR FAILED THE DISHWASHER PROG WILL JUST KEEP LOOPING BACK TRYING TO DRAIN THE WATER.
Mar 04, 2017 | Bosch Dishwashers
UL keeps coming on the screen, will spin for 1 or 2 minutes and then UL shows up again
Hi, UL means Unbalanced load in Whirlpool Cabrio....
UL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load. Display clears if mini-cycle successfully rebalanced the load. If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load....
Oct 05, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer does not work well on spin cycle admiral aav7000aww
No you need to check ur clutch, u can check it by running the spin cycle for a few minutes then shut it off and turn machine up so u can look under it. get a spray bottle with cold water and alil soap detergent, then spray the clutch with it, if it shows or steams up or sizzles then the clutch is slipping and bad. the cluth is in the center near the tranny, should look like a round siver pc of metal about 5 inches in diameter
Jul 18, 2009 | Admiral AW22 Top Load Washer
Kenmore HE2 won't finish spin cycle
you have blockage in you drain plug. to solve this problem you'll have to remove the lower front panel of your machine by removing the 3 (1/4") screws on the vary bottom of the machine. once the panel is removed you'll see a 1 1/2" white PVC drainage plug. turn the inner plug to the left in till open. (WARNING ALL THE WATER IN THE DRUM WILL DRAIN THOUGH THIS PLUG) remove debris likes socks or everything that's there replace the panel and your all set.
May 28, 2009 | Kenmore HE2 Plus Front Load Washer
Maytag neptune MLG2000AWW does not turn off at end of spin cycle
d sounds as if your having a timer issue here. not recognizing the end of cycle and entering a new one ( bad timer).. as far as time of unlocking this is normal, theres a wax motor holding the door shut for i believe 3 min's.. and the water sloshing sounds is also normal they use a "water filled" balance ring around the perimeter of tub to help with the overall balance of machine
Mar 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
MAYTAG Mah4000 front loader washer
HAVE YOU CHECKED THE MOTOR CONTROL BOARD?IT IS LOCATED INSIDE THE FRONT RIGHT BOTTOM OF WASHER BEHIND FRONT PANEL,LET ME KNOW IF YOU FIND ANYTHING-MIKE
Nov 01, 2008 | Maytag Neptune MAH5500B Front Load Washer
Keeps filling up with water
Hi, the water valve is defective, to make sur unplug the washer 117 electrical corde from the wall and look if it still fill up, if yes then u can be sure that the inlet valve is defective, juste replace the valve and ur home free.. wish u well, Alain
May 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint WD860 problem
washer wf860 showing f07 error. why
Mar 04, 2008 | Hotpoint Washing Machines
Washer will not restart.
unplug it wait a few mins---- that should solve it sometimes these machines go in to a a "soft lock" condition
Sep 30, 2007 | Whirlpool GHW9100L Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
