Question about Home
Briggs 6002 toilet
Installed all new parts. When the toilet flushes the diverter valve is supposed to close when the flapper drops. This isn't happening the diverter seems to be hanging up.
    New Friend:
I GOT NO ANSWER FOR THIS PROBLEM I WANT TO INSTAL A TOILET IN A MOBILE HOME AND GOT NO ANSWER FROM YOU
Posted on Oct 19, 2013
  • 374 Answers
SOURCE: how to replace a commercial flush valve
These used to very simple but have become more complex as technogy evolves. I will give you the standard answer though.
First shut the water supply off to the aplliance (there is a little decorative cover on the valve that is attached to the water line coming out of the wall. It looks like a nut. Pop this cover off and screw the screw in remember right is closed and left is opened.)
Now it is only a matter of unscrewing the couple of nuts that attach the actual valve.
Most valves come with step by step instructions but even without them it is usually a 30 minute job or less. You will need a flat head screw driver, spud wrench, tubing cutters- to cut the chrome trim tube to size, and some pipe thread compound or teflon tape.
Thanks for using Fix Ya and if I can be of further assistance let me know.
Jim
Posted on Nov 10, 2008
  • 659 Answers
SOURCE: flapper will not go down
Troy, the flapper otherwise known as the flush valve is easily replaced. They are also very inexpensive. Sometimes they can become distorted due to the clorine in the water and won't operate in the same way they did when it was new. I bet this will fix your issue and save you money as well.
Posted on Mar 21, 2009
  • 88 Answers
SOURCE: The toilet sometimes will continue to run after flushing
the chain should have some slack to it being too tight it dose let the flapper sit properly so itll keep running because water is escaping
Posted on Aug 26, 2009
  • 54 Answers
SOURCE: American Standard Hamilton Toilet Leaking
You have installed the parts improperly. You must have 3/8 of an inch slack in the chain from the flapper to the handle when flapper is closed.
Posted on Sep 26, 2009
  • 1739 Answers
SOURCE: I need to replace the flapper on my kohler model
Kohler toilets normally have the part numbers on the underside of the the tank lid. I was not able to find the 703 model listed on the Kohler sites; check under the tank lid there for a more complete model number and possibly a specific number for your toilet flapper.
Here is a fairly user friendly site with an illustrated selection of Kohler replacement parts. You may be able to match your model number or measure and visually match a suitable replacement:
http://www.toiletexperts.com/index.php?main_page=index&manufacturers_id=12&sort=20a&filter_id=2
Your other option is to turn off the water supply to your toilet; remove the flapper and pay a visit to your local plumbing supply store. In some cases you will be able to use a universal repalcement part as long as the means of attachment and the size are the same.
Posted on Feb 11, 2011
Toilet keeps running
Just go to Lowes and get a replacement KIT. They are not costly and they are easy to install.
Feb 17, 2018 | Home
Toilet Flapper drops too soon and causes incomplete flush. Replaced with new red Korky, and adjusted chain tighter AND looser.
Try adjusting the water level in the tank. Most flappers close as the water in the tank flows out to a certain level. Try allowing more water to come in to the tank. I doubt the weight of the chain has any effect on it closing too early.
Nov 03, 2016 | Home
My toilet keeps leaking from tank to bowl--replaced all internal parts
If the flapper and all has been replaced. then it must be worn out where the flapper sits. or its not smooth.check to make sure it is smooth where the flapper closes, and make sure it closes fully when flushed. you might be better off with a new toilet, but thats up to you!
Mar 11, 2014 | American Standard Colony 2388.012.222...
Flapper valve closes too quickly
Fill the breather hole (1/8" hole) inside the flapper.This is designed to let air out so the flapper will sink. Now it floats longer letting in more water. 25%percent more in my case.
Apr 22, 2012 | Home
I have a new American Standard Cadet 3 that was just installed. After flushing, the water fills into the bowl. However, after several minutes, the water in the bowl slowly drains away and is nearly gone....
Sorry for problem with new toilet.
You say water is leaking out of the bowl?
Toilets have 2 parts:
1) Tank: where water is stored for the flush and is sealed with a flapper.
2) Bowl: where water flushes down.
a) If tank is leaking water, then flapper is suspect. Replace flapper and see if that works.
Lift up flapper and run finger around rim to see if there is a rough spot that would indicate flush valve is defective, and needs replacement.
See typical flush valve
b) If bowl is leaking, that is very unusual and would indicate a crack in the porcelain.
If installer sold you the toilet, it is his responsibility to make good on product.
All products are guarantee against workmanship flaws.
Feb 26, 2011 | American Standard Cadet 3 Right Height...
I have a 1 year old toilet. The water level drops and fills about every 3 hours. What do I need to do to fix? Thanks. specialeight@aol.com
You probably need to replace the flapper valve in toilet tank. This is the valve that sets in the bottom of the tank and is connected to the flush handle that you push to flush toilet. Look at the flapper and try to find one to match it at the hardware store before you try to replace it. To replace most flappers you should shut off water to toilet and remove tank lid, Disconnect chain from flush handle and remove flapper from overflow tube. Install new flapper. Adjust chain so that there is about two links loose when flapper is closed. Before you turn water check seating surface for any rough spots or scale deposits.If there are any then smoot them out with fine sand paper. Turn water back and check for proper operation. Adjust chain length as needed. Hope this helps you. Thanks.
Nov 29, 2010 | Home
2 new toilets installed. customer complaint of occasional clogs. no apparent problem although i feel the flush valve closes very fast. any changes or adjustments for this
Often I change the flapper to get the toilet flapper to stay up longer, giving a longer flush....
Check for a generic flapper that wiill work with the toilets you installed...
heatman101
Aug 04, 2010 | Mansfield Plumbing Products Home
Kohler two peice toilet the water just circles and will not flush.there is plenty of water in holding tank that run through
These models need to have a flush valve flapper that has a styrofoam float on the lift chaninof the flapper. Go to hardware store or home improvement store and get a 'Korky brand toilet tank flapper with float 'ball". Cut the rubber ring piece away from the flapper and you don't need it (see cut here marks on flapper). Install flapper and adjust the float fairly close to the flapper.
When the water level drops in the tank and reaches the level of the float on the opne flapper, the flapper quickly closes causing the toilet to have a "surge" of siphon action which forces the water in the bowl to be drawn out.
Jun 29, 2009 | Kohler K-3422 - Wellworth Elongated...
Have to flush 2 or 3 times to empty toilet bowl
hello, this is a standard toilet you will need to inspect the flapper that is the rubber flap that holds the water up in the tank it works when you pull the lever it pulls the chain upward and lets the water flow if this flapper is old it may not stay up long enough for the water to flow. open the tank top and flush the toilet see if this flapper is staying up long enough and giving the tank enough time to empty if not change this rubber flapper its inexpensive part.
if this is not the reason then you need to adjust your water filler valve there should be a small screw on top of the pivoting float arm
if you have to adjust it for the water limit line inside the tank this will be the proper amount of water needed to flush once completely
also check that the chain lenth on the pull lever is not pulling the flapper down quicker than its supposed to,
try this let me know your results
hope it helps
Dec 15, 2008 | American Standard Home
Flapper valve
You will need to adjust the chain. They are just clipped at any point when coming from the factory not at the opyimal length. It will take a little effort to find the desired length as sometimes the trick to getting the valve to remain open longer is opposite of what one would expect. I mean there is a point to where there will be more slack in the line than you might expect to get the valve to stay open for the optimal duration.
Sep 23, 2008 | Eljer Aqua-Saver 12" Two-Piece...
Home Logo
69 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
