Question about Chauvet Followspot 400g with Stand
The bulb and fuse keeps blowing out at the same time
    Problem Solver:
  • 11 Answers
Verify that you have the correct fuses and lamp. install the fuse(and only the fuse,no lamp) and fire it up.listen for the fan.if the fuse holds and the fan runs, you probably have an issue with the dimmer on the main board. Chauvet may be able to send you a new one, but this model was discontinued in 2012, which may parts hard to get. Good Luck!
Posted on Oct 17, 2013
Mackie profx12 fuse keep blow
Be sure the capacitor was replaced with the correct polarity?
in the beginning of my tech career I have replaced caps back words on accident. ..
Mar 06, 2015 | Mackie ProFX12 Professional Compact Mixer
Hammond organ c2 hook to a 147 leslie speaker it keep blow the 1.5 slo blo fuse how do I fix this
Like all the past answers, make sure everything is clean and lubricated expecially on the Lesley if it's a motorized rotating speaker, the slow blow fuse is telling you there is a problem ?
Feb 22, 2015 | Music
Bm5a blows fuse when turned on
Blowing a fuse means that it has a dead short. The fuse does its job by protecting the other components while the circuit fails. Something is definitely burned out inside.
Mar 24, 2014 | Dynaudio BM5A Active Monitor
One side of my peavey xr86000 power mixer blew a fusework
Any unit that blows fuses needs to be serviced. Do not keep putting in fuses only for them to be blown again. Each time you put in a fuse and it blows, it will create more damage to the amplifier.
Jan 14, 2013 | Peavey XR 8600D Class D Powered Mixer
Peavey Vyper Tube 120 keeps blowing fuse
You are either trying to: (A) push it too hard, (B) using the wrong type of fuse -- should be a "Slo-Blo" type, or (C) it has internal shorting or voltage modulation and requires service.
Jan 11, 2013 | Music
When standby is turned on a loud humm then fuse blows
Replace diodes CR6 through CR9 and test C31 and C33 for short. If all OK and fuse still blows, remove the power tubes and test. Hopefully you do not have a transformer short.
To save fuses, put a 150 watt light bulb in series to act as a reseting fuse while testing.
Feb 01, 2011 | Fender Hot Rod Deluxe Guitar Combo...
Blown fuse
Continued replacement of fuses without fixing the reason for them blowing MAY be doing additional damage to components in the unit.
It needs to go to a repair shop. It is likely there is damage in the power supply section or that of the power amplifier section.
Feb 28, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
I have a KRK Rokit Powered 5 studio monitor and the fuse blew out, so i replace the fuse with the spare they provide and ''bam'' blows again as soon as i turn on the monitor. i have had these for about 4...
Look for a failure in the power supply section. You will need electronic experience or someone who has that.
If the fuse is glass and blows silvery inside thia means a direct short inside. SUSPECT the input rectifier or filter capacitor(s).
Do testing with a 100 watt light bulb in series with the hot side of the power cord to avoid blowing fuses.
Oct 10, 2009 | Music
What kind of fuse does a Peavey PR12N sound reenforcement(PA) speaker take? Blew the internal fuse and cany find one(locally) Looks very similar to a cars interior ''dome'' light bulb
According to the Peaver PR12N Manual which can be viewed at http://www.peavey.com/assets/literature/manuals/pr12p.pdf
This unit requires a ABC Type Fast Blow 5 Amp fuse. The replacement fuse must be of the correct type to properly protect the unit. If the fuse continues to blow repeatedly the unit should be taken to a qualified service center for proper repair.
Aug 22, 2009 | Music
Fuse blowing on start up on Behringer PMH 518M
Try running the amp with no speaker cables connected. If it doesn't blow the fuse you know it's either your Speakon cables or the speakers themselves that are to blame (it's usually the cables)
If it still blows then there is a more serious problem with the power section.
Jan 19, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Chauvet Followspot 400g with Stand Logo
57 people viewed this question
Top Chauvet Music Experts
Vito Vacirca Jr.
Are you a Chauvet Music Expert? Answer questions, earn points and help others
