Question about Samsung WF337AA Front Load Washer
Samsung washer front letters dissapear
I bought New Front load samsung washer 8 months ago. I dont know what happened to front display letters start disapearing next to front knob and also Start sign from the start button went off. its completly clear, so we cant know what setting needs to choos. Becasuse half of the letters gone. I call the company and they says its not under the warranty because it is cosmetic damage. I don't know what that means..
  • Yael Aldrich
    Yael Aldrich Nov 15, 2013
    I, too, have the writing on the front panel of the washer coming off. I have had this washer for less than six months. I washed the exterior a couple of times with water, no chemicals. This is a good machine otherwise, but you will have a hard time washing your clothes with no way to choose your cycle. I called Samsung and over two hours later, I was told that they will not replace the panel since it is "cosmetic damage". I would not buy this machine, nor any Samsung products. Buyer beware!
    Master:
  • 492 Answers
Just use a marker to put a dot next to the start button and another mark to indicate different settings. You can look up the settings online
Posted on Oct 15, 2013
SOURCE: samsung silvercare washer stopped working, won't unlock
here is the most common cause for this problem, according to the Samsung repair guy that was here to fix mine today.
On these washing machines it is possible for some debris (in my case it was a small screw from my packet) to make its way passed the drum and into the pump. Once this happens then the impeller of the pump becomes restricted or completely blocked which will result in the above mentione symptoms.
On some machines the pump is on the front, on others at the rear of the machine. In my case it was at the rear, removing the rear panel will allow easy access to it. Have a bucket ready, when the hose is removed from the pump the water will be draining from the machine. 3 bolts and a hose clamp on the inlet and another on the outlet hose. Disconnect the electrical plug from the pump and you can remove it from the machine for cleaning. A very easy job, requiring little skills and not much in terms of tools. (make sure machine is UNPLUGGED from AC outlet)
Remove obstruction(s) from pump and reinstall in reverse order of disassembly. The guy says these pumps are really tough so if you hear it buzzing, trying to go while it's jammed it's a good sign it will work. If not, replacement will be necessary.
Cost me $140. Could have been worse I suppose. Advise: Empty pockets BEFORE washing clothes...
Posted on May 26, 2009
  • 1294 Answers
SOURCE: samsung wf337aa front loader
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Posted on Mar 05, 2009
  • 27 Answers
SOURCE: Samsung Front load washer WF-J1254 stops mid cycle
motor control board is bad and needs to be replaced, contact sears or someone like that to replace.
Posted on Jun 14, 2009
SOURCE: filter
I have a vrt ... I hope this helps.... Take of that little door on the front. Have a bucket or bowl ready. Bring down that little black hose, turn the white cap around and pull till it comes off. Drain into the bowl, turn the white filter cap counter clockwise to release some of the suction and wait till the hose stops draining. Remove cap, clean under running water w/ toothbrush. Manual says to make sure that the interior is free of anything (I wiped mine out) and then put it all back together again. Good luck
Posted on Sep 03, 2009
  • 6277 Answers
SOURCE: I have a Samsung VRT front load washer, it was
First is to empty the water out. This can be done by following my (complete) general guidance notes below for checking the drain motor lint tray/filter and the motor.
'nf' means NO FEED and what happened afterward indicates that the water feed control valve is malfunctioning, initially not opening for water to be fed but then sticking open.
So follow these notes, particularly those in capital letters, to find how to empty the washer, and to check the state of the filter which is needed on a regular basis anyway ;-0)
Next will be a call to a service engineer to sort out the suspect valve.Sorry ;-0(
I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
John C
Posted on Mar 01, 2011
My machine stopped mid cycle and displays the letters dc, flashing. What is happening? thank you
I believe The dc code is due to an "unbalanced" load situation. Is this happening when it tries to spin? I know some washers have switches that sense this. Is this in the wash or spin cycle?
Sep 12, 2011 | Maytag Neptune MAH5500B Front Load Washer
Help ! We have an L G front Load washer model # WM2016CW that leaks soap out the front bottom of the dispenser. It is 2 years old and I have followed all the manufacturers instructions on using HE soaps...
You can remove the dispenser and place it in the dishwasher for easy cleaning.
I have included some notes on your washer and I have a service manual for you HERE
Apr 07, 2011 | LG WM-2277HW Front Load Washer
The light is on "control lock". I cant get the
Make sure the front loading door is closed to latch well The limit switch of the door can be faulty as it is necessary to get the washer to start the cycle-- a protect mode.
So use a multilmeter to check the switch, line to the switch from the control panel
Nov 01, 2010 | KitchenAid KHWS01PMT Front Load Washer
The clothes are soaking wet after the run on the machine. It seems the spin function is not working. I have a maytag neptune model front load.
I have the same problem. I have spent about $1,400 in repairs on this damn machine since we bought it about 8 years ago. It works for a bit then something else goes wrong. This is the fourth time I've had this problem.
It's the belt, it's the motherboard, its this its that $200 a pop. Just enough to say ok, any more I'd buy a new one, then a few months later something else happens.
What happened to Maytag? My mom and grandmother both had maytags for years, decades without an issue. The new ones ****.
Nov 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
Lettering is rubbing off my brand new LG washer and dryer!!!
Go back to your supplier, after 3 months this should not be happening and the machine will definatly still be covered by warranty.
Aug 08, 2009 | LG WM1812C Front Load Washer
Whirlpool front loading washer
I am having trouble starting the washer . I set the cycle on casual and press the start button and the washer sensor showed to " Done" instead of starting. I only bought it three months ago.
Jul 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Samsung wf337aa front loader
Jul 13, 2008 | Samsung WF337AA Front Load Washer
Samsung 306BHW-Error code 7E
I don't know what the problem is bUT I HAVE THE SAME PROBLEM TOO ON a machine 8 months old
Dec 03, 2007 | Samsung WF337AA Front Load Washer
Samsung WF337AA Front Load Washer Logo
1,207 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
