Question about Video Game Consoles & Games
My ps3 internet never turns on and I system update but it keeps failing and I try everything please help
Try disconnecting and re-configuring your internet connection.
Are you getting any error messages?
Posted on Oct 14, 2013
4 Suggested Answers
SOURCE: PS3 internet connection problem
i had the same problem, all you have to do is when u set up the router on the ps3, do it as manual instead of automatic, and type in the routers mac, ip, and dns server and it should connect alright
Posted on Sep 01, 2008
  • 9 Answers
SOURCE: PS3 error (80029C77) when trying to system update
what update
Posted on Dec 22, 2008
SOURCE: Ps3 System Update Failed, PS3 boots with error code 8002F14E.
-Open the side of your PS3 where your HDD is. Take the screw out, but leave the HDD in.
-When the update begins, pull your HDD out of the slot. It will tell you an error occured and it tells you to restart your system and try again. Instead, let the count from 60 run out, your screen will go blank for about 30 seconds then it will start back up and tell you that your Hard Drive needs to be reformatted. If you do not get this msg after 30 seconds, do it again until it does! Now, slide your HDD into place again - (make sure your controller is PLUGGED IN) and press the white PS3 button on the controller. It will then ask you to either press start and select at same time OR white PS3 Button - PRESS START and SELECT. Do not agree to user agreements!! Simply hit cancel and it will kick back to the PS3 start up screen.
Posted on May 09, 2009
My ps3 internet never turns on and I try system update but it keeps failing and I try everything please help
Try downloading the update onto your pc from from the PlayStation website. Follow the instructions on how to do the update via thumbdrive. OR Go to network Settings and select automatically detect internet settings. (If you connect wirelessly you will need the passcode to your wireless)
Oct 14, 2013 | Video Game Consoles & Games
I keep trying to download the required system update, it gets to about 17% and then comes up with the error code 80710723, it says reboot the router and ps3 which doesnt help, or to question Virgin about...
You need to remove the cables of the router but you should know how to plug it again. Try to update again. If this doesn't work, your internet has a problem.
Feb 19, 2011 | Sony Playstation 3 (PS3) Console
Connecting ps3 to wireless internet failed because of dns error 80710102
You can try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
But if your problem is not still solved, then maybe you should call sony for further assistance.
I wish you good luck
May 06, 2010 | Sony Playstation 3 (PS3) Console
PS3 Update successful,install failed,systemrebooted,error8002F14E
On the playstation 3 site error code tool says this code is an issue updating the PS3 sytem software. Try to start with the hard drive uninstalled then try again installed. If that dont help i would format the hard drive in a laptop and see if it helps. worst casr scenario you could dissasemble the PS3 and unplug tha battery on the main board and see if that helps. Good Luck
Nov 24, 2009 | Sony Playstation 3 (PS3) Console
PS3 dowloading error
Pls try temporarily disabling your antivirus and/or your firewall. Other than that, you may need to re-install everything and work from scrathc.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 26, 2008 | Sony Playstation 3 (PS3) Console
Wireless router wont connect
Hey mentalmc,
I had this problem at least once a month. Try these things out.
1. Make sure any WEP codes are entered EXACTLY as it is for your router.
2. Set up your router so only your PC connected to it can change any settings.
3. Turn off your PC while trying to connect via PS3 WiFi. The good ole Win update likes to download without you knowing it sometimes.
4. If all else fails, call Sony cause you may have a bad WiFi antenna or motherboard.
Jun 25, 2008 | Sony Playstation 3 (PS3) Console
System update will not finish
On mine it gets to 64% and then says there is an error (8002F1F9) and when i turn it off & on again it goes straight back to the update and keeps failing at 64%.
Jun 22, 2008 | Sony Playstation 3 (PS3) Console
System Update wont work
unplug your internet modem for 15 min, keep the connection to the PS3, of course. do automatic settings, not manual, select easy but DO NOT GO FURTHER until you plug in your internet. Let it cycle, the modem may shut down. if/when it does, turn it on and continue. The PS3 should automatically find everything by itself. Confirm then test the settings. I think that should work.
May 28, 2007 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
20 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
