Question about Electronics - Others
My laptop won't turn on when I insert the charger!
  • 67 Answers
If you want help you need to give more information.
Posted on Oct 15, 2013
My Asus LaptopModel X205Ta is fully dead and won't charge or turn on.
MF. Could be the new charger is faulty, return charger for exchange or refund. Battery could also be faulty, have it tested if you can by a computer tech. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My laptop notebook will not turn on
my asus laptop wont even charge or turn on after it shut off mid windows...
Laptop Won Come On Even When Connected To Charger
Why Won My Laptop Turn On Even Though It Plugged In
Jul 09, 2016 | ASUS Computers & Internet
My Acer Aspire 4750G-2312G50nbb does not turn on, Whenever I insert the charger adaptor to the power jack, the charger adaptor led light turns off.
One of two issues will cause that.1/ The socket is damaged and presenting a short circuit to the charger or 2/ The protection diode has blocked an incorrect voltage/polarity and provided protection by going short circuit.
Jan 11, 2014 | Acer Aspire Computers & Internet
My eee pc netbook won't turn on I need help
1-remove the battery and put it again
2-turn it on from the power button
3-if it doesnt work press F1
Jan 27, 2013 | Computers & Internet
My battery won't charge even if I replaced it with new battery.
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
http://www.chargerbuy.com/laptop-battery.html
Jan 14, 2013 | Computers & Internet
My asus laptop won't turn on and so I have it
may be the wire of the charger has got defect in it. check thoroughly. If your charger is OK it is problem with your motherboard.Replace it to get rid of the problem.
Feb 08, 2012 | ASUS Computers & Internet
I bought a new charger for my laptop as my charger broke, and the little blue light comes on but the laptop won't turn on. I have the right charger, but it still won't turn on. The power light...
The first thing to do is check that the charger is putting out the correct voltage, which should be ~18 volt. Then try to start it without the battery.
If your voltage is OK and the battery out makes no difference, then I would suspect that you have a motherboard problem that must be fixed. If the computer starts up if you wiggle the DC plug where it goes into the computer, then it's the DC jack that is looks and must be re-soldered.
Sep 11, 2011 | Compaq Presario CQ60-220US PC Laptop
I have a problem with either the battery or my charger on my laptop compaq presario 1692. i would like to know which one of them is the problem?
Remove the battery from the laptop
Connect the charger and turn on the computer
If you have a bad battery, your computer will turn on
If you have a bad charger, your computer won't turn on
Jul 24, 2011 | Compaq Computers & Internet
My hp compaq turned off by itself and won't turn on now, it won't even show the charging light when the charger is plugged in
Remove the PC labtop battery then re insert it again.
If still not charging check the charger connector if its connected as well.
If there was no problem in the charger connector,Check the charger itself.
These all what you need to check only,no problem in your labtop.
If still not charging means one of these :
1- The BATTERY may needs to be changed .
or
2- The charger may needs to be changed.
Jun 13, 2011 | HP Compaq 6720s Notebook
Hp dv68x1us screen on laptop won't turn on
Remove battery and charger, when pc will be without baterry and charger, press turn on buttom , then put battery, connect charger and turn on.
May 31, 2011 | HEWLETT-PACKARD PAVILION DV6871US LAPTOP...
Electronics - Others Logo
21 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
