Question about KitchenAid Architect® KEBS277S Electric Double Oven
Kitchenaid KEHC309 -oven stops working just after starting, and 'insert probe' warning appears. I ran a cleaning cycle to remove any moisture from the oven, but that did not solve the problem. My oven is now unusable, as any attempt to use any cooking mode, causes the probe warning to appear, and the oven to shut off.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 92 Answers
I had another brand with that fault from new. We disconnected the probe wiring from the control board and it stopped looking for it.
Also, could be a setting has been changed inadvertently.
Posted on Oct 18, 2013
4 Suggested Answers
ginko
  • 19396 Answers
SOURCE: replace inner oven door glass on kitchenaid wall oven
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Posted on Apr 08, 2009
  • 291 Answers
SOURCE: Our Superba (what a joke) Model KEMS308 / KEMS378
Common Problem, design defect allows moisture or corrosion on terminals, to cause this problem. Two ways of repairing this. 1: Plug probe in, hang probe out the door, input 160 degree probe temp, turn convection bake to 450 degrees and let it bake for a while. Turn unit off, unplug probe and test to see if the problem is resolved. If it is moisture, the high heat bakes out the moisture and resolves the issue. We have also had some luck with a hair dryer blowing on the probe receptacle to dry out the receptacle. 2: You can pull the entire unit out of the wal with the power off at the circuit breaker, remove the backing panel, and disconnect the wiring to the probe. Some units you have to remove a side panel instead. You won't be able to use the probe in the future if you do this, and you do have to insulate the wires terminals or plug. As always, if you don't know what you are doing with electricity, call a technician to do this repair, it is better to be safe. Also as an aside, I work on all brands of ovens and we find that the Kitchen Aid models have the fewest repairs and the greatest reliability, everybody has design defects and most of the other brands have deliberately built in these defects for faster replacement. The only advice on the Kitchen Aid units that I recommend is that when you do replace it that you buy a separate oven and seperate microwave oven. Most microwave ovens are only lasting 8 to 15 years before major repairs, yet the ovens last 30 to 40 years. Good Luck, Appliance Specialists
Posted on Jan 03, 2010
SOURCE: kitchenaid display reads insert temperature
We just had this problem with our Kitchenaid Superba electric oven. It started beeping for no reason and showed the probe symbol. I actually never used this probe, ever! Call to the tech people: go get a service man! right...
My husband, smarty pants, lol, put a bowl of water into the oven, plugged the probe in and dunked it into the bowl with water, set the temperature to 85 C (that would be 200 F, I believe, but better check it in the manual) and let it heat up. (In any case, set it lower than water boiling temperature!)
That actually did the trick! Once it reached the set temperature, it shut itself off and the probe light went off! Yeah! good hubby!
Posted on May 01, 2010
Kleenmaid Oven TO901X F13 error
I suggest you contact this appliance timer repair company
They can tell you over the phone whether this is likely something that they can repair. If it is repairable, you just remove the timer, send it to them and they repair it and send it back for $106 plus shipping. There is no charge if they can't repair it.
Feb 02, 2013 | Ovens
Temperature probe icon persists on the display and cannot be extinguished. Seems to be locking out other oven functions. Tried removing power overnight - no change. Followed protocol to turn off "Sabbath...
If the probe is not connected, then the actual connector in the oven is faulty. If you don't use the temperature probe, you can take the front control panel off and disconnect the probe connector. I did this 8 years ago
Jan 10, 2010 | KitchenAid KEBC107 Electric Single Oven
Our Superba (what a joke) Model KEMS308 / KEMS378 has the exact same temperature probe problem where the plug where the probe is inserted is supposedly getting dirty BECAUSE THERE ISN'T A COVER OVER IT...
Jan 03, 2010 | KitchenAid Architect® KEMS378S Electric...
How do I use the thermometer in my Kitchenaid Superba?
I found the answer by checking the Kitchenaid website to find the manual. My model is KEMS308sss04, this is found on the right door frame. Website is: http://shop.kitchenaid.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10162223.pdf
You can preheat oven, but then turn off to set thermometer. Put probe in food. Put food in oven and plug in probe. The digital light asks for the temperature you want, type it in. Then the cooking method. I used convection bake at 325. Hit START. (The first time I didn't stop the oven and it didn't work. After stopping everything and starting with the probe before turning on the oven, it worked perfectly. Good Luck.
Dec 05, 2009 | KitchenAid Architect Series KEBC107KSS...
Superba convection oven probe display problem
I had a similar problem today with my KitchenAid Superba wall convection oven (2002 model). I was roasting tomatoes at 225 degrees F for 3 or 4 hours when the control pad changed and showed that the probe was in use (never have I used it and had to look for it). I, too, tried to plug in the probe and take it out, but nothing changed. My worry was that I could no longer use the timed bake function. After trying to reset by turning off the oven at the breaker, with no change, I turned on the oven to 400 F and left it on for 10 - 15 minutes hoping that the high temperature would dry out whatever moisture that must have gotten in the place where the probe connects. Then I turned it off and just waited. After a half hour or so the control pad cleared and nothing showed (that is what you want when the oven is off!). Everything is back to working now.
Sep 08, 2009 | KitchenAid KEBC107 Electric Single Oven
Kitchenaid single oven, error code is a picture of a push pin
its a "meat probe" not a pushpin. somehow the unit thinkd you hae a meatprobe inserted, soundslike a short in the meat probe jack( usually happens in high moisture areas, the wires swell and make contact with eachother, the replacement jack, has better insulation around the wires, you could also disconnect the wire harness from the main board assy(behind the console, if you never use the function!
Jan 29, 2009 | KitchenAid KEBC101 Electric Single Oven
KEMS377 Lower electric Convection Oven - no probe, won't work!
"I get a "Door" message when I try to start it. The Message only shows when I try to set the time with one of the function buttons, like and dosent work
Aug 07, 2008 | KitchenAid Architect® KEMS378S Electric...
KitchenAid Architect® KEBS277S Electric Double Oven Logo
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
