Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Water is not coming out when in motion to clean carpet
    Sergeant:
    Champion:
  • Hoover Expert
  • 357 Answers
Take it to a vac repair shop. Most likely a bad release valve under the clean water tank.
Posted on Oct 21, 2013
Detergent doesn't dispense.
Water will clean carpets but not very well. For the best results don't put any cleanser in your machine. Soap can clogged up the lines in your machine. When you have soap dispensed or or in the water in your machine you are squirting it onto the carpet and sucking it back up at the same time...the soap and water isn't on the carpet long enough to clean well unless you keep going over the same area many times. To clean better it's really important to vacuum thoroughly going slowly in multiple directions to get as much dry, gritty soil and hair and dust out as possible, it's easy to get these soils out when the carpet is dry if your vacuum is working properly. Vacuum, vacuum, vacuum.
Get a spray bottle or sprayer and put hot tap water in it, add the cleaning solution to the hot water and spray enough on the carpets to get the face fibers damp...let the hot water solution sit on the carpets 5 or 10 minutes and then use your machine to clean and rinse the soap, water and loosened soils from the carpet fibers. Repeat if necessary. Your carpets will be cleaner because you allowed adequate dwell time for the soap and water to work on the sticky greasy soils attached to the carpet fibers and stay clean longer because the soap is rinsed out of the carpets. Your carpet cleaning machine will last longer too because the water lines, pumps, spray jets, heaters, etc can't get clogged with soap gunk if you don't put soap in it. The method I'm describing is how the best professional carpet cleaners clean carpets. Hiring a quality carpet cleaner cost more up front but the carpets may stay clean two or three times longer, saving a lot of money in the long run. If you clean your carpets using this dual process method you may do a better job with a small portable home or rented cleaner than hiring the average carpet cleaning professional who is trying to give you the lowest price.
Mar 06, 2017 | Vacuums
What is the best way to clean a fresh blood stain from a wool carpet?
Cold water on a clean cloth, blot with damp cloth, then with dry cloth, repeat, repeat, repeat until you do not see any red coming out. If you have a carpet cleaner flush it with lots of cold water sucking it up with your carper cleaner or extractor. A good professional carpet cleaner can prevent your spot from becoming a stain. Often you can use enzyme cleaners to remove blood but NOT on wool carpets.
Apr 07, 2016 | Vacuums
I have a Delonghi Multi Vac M31 and have never used the wet part...I would like to clean my carpet using the wet vacuum...can you please tell me how I can do this? Many thanks
A good place to start is the owner's manual. If you don't have one, you can google the make and model of your multi-vac to get another copy.
Most wet-vacs work off the same principle. Pre-vacuum the carpet to make sure there is not normal surface dirt and dust. Next Squirt on hot soapy water, scrub it in - then suck up the dirt and collect the dirty water.
So after vacuuming the area to be wet-vacuumed and you are lucky enough to have a separate reservoir on the wet-vac unit - add pre-mixed carpet cleaner into hot tap water (with carpet cleaner mixed into it by the ratios described on the carpet cleaner soap bottle) to the multi-vac water reservoir (from a quick look, the Delonghi doesn't have one) . With the settings for wet vac (per the owners manual), squeeze the trigger for applying the carpet cleaner. Typically, you will go slower than normal vacuuming. Give it a chance to soak in and dissolve/lift the grim and dirt. Come back slowly to pull the dirty water out of the carpet.
There are multi-wet vacs (like the M31) that don't have a reservoir for the carpet cleaner. In that case, you need to pre-mix a couple of gallons of carpet clean in a separate container or bucket. Next spray or sprinkle carpet cleaner onto/into the carpet. Try to scrub the cleaner into the carpet to really get at the dirt and lift it. Next is to vacuum up the wet stuff.
Some carpet cleaners do not contain an anti-foaming agent. I recommend you either add an anti-foaming agent or buy a carpet clean product that already contains it - otherwise, it tends to be a big mess that takes a lot more time.
I hope these tips help.
Nov 07, 2014 | Vacuums
How can Berber carpets be maintained fresh and new-like for a longer period of time?
You can clean them with household units but even professionals have trouble with berber carpet because of its tight weave and usual inlaid patterns. Dry carpet cleaning between professional cleanings will help keep carpet looking new without staining. My suggestion is to use a dry carpet cleaning machine and then have a professional come in with hot water extract as often as every year depending on traffic. I sell the SEBO DUO machine you can see by clicking the link provided.
http://vacuummedic.com/product.php?id=511
Jun 28, 2013 | Hoover SteamVac Carpet/Upholstery Deep...
Cant squirt water, nothing is coming up from the carpet
Try filling soap solution tank with hot water and make sure that the red filter in the pickup tank is not clogged, and always run hot water in solution tank after cleaning carpet. steve
Jun 06, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
My Hoover SteamVac carpet cleaner leaks water
i have a hoover carpet cleaner and when it is not in motion it leaks water
May 23, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
How to release and withdraw water solution to clean carpet.
Problem resolved by contacting a local retailer who provided instructions.
Dec 30, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
The water will not come out, indicator not spinning
trash it! I am having the same problem. I am so mad at my carpet cleaner, I have only used it 2 times. JUNK!
Mar 30, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Instructions or manuel was not included.
i downloaded the manual for your machine, but not sure how to access it for you,but i do know about the problem, the tank that sits down on the front of the steamer and it has 2 clips that you push in to lock the tank is where your dirty water is put in when you are cleaning your carpets. the tank above ,the one where you put your solution and water in is what is used to shampoo your carpet. on the handle is a trigger (black) button ,this is the button you push in to release your solution onto your carpet. release the button to extract the water from your carpet,moving your steamer in a back and forth motion. the trigger button is the only button on the machine and is only used to put the water /cleaner located in the upper tank on your carpet, releasing this button and moving your steamer back and forth over the shampooed part with extract your dirty water into the tank that sits below the solution tank. go on www.hoover.com and click on carpet cleaners ,scroll down to find yours and click on manual. and the owner manual will download and you can print it out for future reference, i hope this will solve your problem, sandy
Nov 29, 2008 | Hoover F5810 SteamVac Upright Vacuum
Changing from carpet cleaning to hard floor cleaniang
If you are looking to floor cleaner then don't go anywhere, Our experts helps you to clean your floor and the best thing is that you are never feeling regret after taking our services.
Taking fast services call us anytime 3105441028.
Commercial Floor Cleaning Services Waxing Los Angeles CleanerImage
Apr 23, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
