Question about NAD C541 CD Player
Discs will not play.
My NAD C541 cannot read any disc anymore,not even original CD:s It just keeps on blinking and then it keeps ejecting the CD.I cannot detect audibly that the spinning motor starts.When the CD ejects there is no error message like " no disc " Only the bars keeps on blinking. Kenneth Persson
  • 1 more comment
  • Kenneth Persson Oct 04, 2007
    Thanks for the comment.However,the problems nature was mechanical.The disc was not completely horisontal leveled when engaged.We simply forced the center to be adjusted by slowly manually spinning and pressing the disc and then it was working.
  • docstrat Feb 06, 2008
    Another post on this site described a lubrication process. The transport on my 541 tends to stick as well. Find that post and try lubricating the transport. It may fix your problem.
  • Anonymous Mar 15, 2014
    Cd player keeps reading cd error. It won't let me eject any cds
    Problem Solver:
  • 4 Answers
"My NAD C541 cannot read any disc anymore,not even original CD:s It just keeps on blinking and then it keeps ejecting the CD.I cannot detect audibly that the spinning motor starts.When the CD ejects there is no error message like " no disc " Only the bars keeps on blinking." Sounds familiar to me. As I told in the other posts, simply replace the tray-driver-belt. Worked good for me ;)
(trefwoorden Nederlands: NAD C541 probleem - transportprobleem - CD niet herkend - speler accepteert geen CD - CD ongelezen uitgeworpen - snaar of riempje vervangen - Sanyo loopwerk - SFP101)
Posted on Jan 25, 2010
  • 93 Answers
Could be some dirt on laser lenses. Try to clean it.
Posted on Oct 04, 2007
  • Mico Dukic Oct 05, 2007
    That is something completely different. First, I don't think that's good idea to force CD into place. It could break into zillion pieces (I've seen it before, real mess). If I would you, I'd check mechanism step by step, and find why disc can't sit properly in it's place. Could be dirt, piece of something else, or if somebody close tray with exessive force and caused mechanism skip.
Selective playing of DVD's on Sharp DVD Recorder
Given that the machine will read disks it has written itself but not play regular discs, I suspect the lens assembly is slightly out of alignment and needs adjusting. This is not normally something you can do at home unless you have the correct test gear. It will need to go to a repair shop. One thing you can try before that is to clean the lens. Buy a quality (Scotch 3M, Philips ) cleaning disc and try it. Could be it's only a speck of dust on the lens.....
Aug 01, 2007 | NAD C541 CD Player
Hi, I have a NAD C541i cd player when i turn it on i get three blue line on the display, i open the draw and insert a CD disc but the blue lines stay on the display and the disc don't play. can you...
The blue lines you mention should flash when trying to find
the 'Table of Contents' of your CD, even if a CD isn't loaded.
If when a CD is loaded and these lines flash for a while without
any CD info e.g track no. / disc length then it's more likely that a problem has occurred with the laser.
Various NAD CD players use the Sony KSS-213 Laser unit
and for some reason particularly with NAD CD players, they tend
to drift out of calibration over time so what i usually do when i come across this is very finely adjust the pot trim on the laser itself and testing a CD between adjustments.
Jun 22, 2011 | NAD C541 CD Player
NAD C541 tray does not open.
if i'm right it will have the sony mechanism so if you take the lid off and unscrew the 2 screws, 1 at either end of the cd clamp and remove it, you should see part of a large cog just under the front of the cd tray, try turn this clockwise and the tray should open.
once open, you should be able to see a small plastic cover, loosen this slightly and replace the belt as this is prone to slipping on this mechanism stopping the cd tray from opening and also clamping the disc properly when closed.
hope this helps?
Mar 11, 2010 | NAD C541 CD Player
XPS One will not read CDs or play DVDs
1.use original disc, bcz some brand drives not supported all the discs available in the market.
2.cheak with other disc,if any disc cant read ,then
* Open Your CPU system cabinet,then cheak the data cable and power cable of the Dvd/Cd Drive.(You may change the other power card in your system already had)
* change the data cable
3.if u still have the problem,then finaly replace the new drive.LG Dvd Drive is beswt one.because it can read all discs.
Mar 09, 2010 | Dell XPS One All-in-One TV Desktop with...
My NAD C 541 cd player will not play any discs. I open it put the disc in and it tries to scan and then rejects the disc and opens on its' own. There is the word 'over' in red below the track number...
It could be the belt for the tray mechanism. Tray closes then motor is pushed up to CD. If belt slips or physical mechanism is sticky CD will not spin and tray will reopen.
Nov 09, 2009 | NAD C542 CD Player
NAD C541i CD Player plays but the sound cuts out for an instant every 10-20 secs. It eventually goes away, but it is annoying when you first play a disc. Any help appreciated.
hi, i've had a few nad C541i's and not so long since the sound on one of them cut out for milliseconds and on some occasions the sound would make the noise very much like a severely scratched vinyl record, i thought it was a faulty laser so i tried another KSS-213C laser out of a scrap kenwood and the fault persisted. to cut a long story short, i took the main PCB out and there were various dry joints. once these were resoldered i was blessed with a fully functioning player. hope this helps?
Nov 16, 2008 | NAD C541 CD Player
NAD C541 CD Player
I wouldnt buy another one from NAD.
I've worked on their stuff cant say anything nice, Sorry.
Aug 25, 2008 | NAD C541 CD Player
Won´t read any Disc
I have the same problem since the early beginning after purchase. I'm very upset with NAD for the zero-value technical service in Italy. After 2 months they gave me back my C541 with new defects (the tray now doesn't work properly). They have tried - they said - different optics without fixing the problem. Does anybody know if a compatible optic / tray exists?
Thank you
Marcello
mcl.vlb@tiscali.it
Sep 25, 2007 | NAD C541 CD Player
CD Player will not play all CD-R discs only ones it chooses. But if the CD is bought from a store it will play it.....if it is burned it usually will not.....even if the cd was just brned and plays on...
It might be an older system that can't read computer-made discs, or it could be a disc incapability. Most old players can't read CD-R discs, even if they can play normal/original CDs. You can try another media but i wont think it will help. Sorry.
Jan 04, 2006 | RCA RS2044 Shelf System
NAD C541 CD Player Logo
1,422 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
