Question about GPX D200B Player
It will not read dvd
It keeps saying wrong regional disc with any disc
4 Suggested Answers
  • 3 Answers
SOURCE: DVD Player D1816 shows Wrong Regional Disc message
Many DVD players are preset to one region and if you use a DVD destined for any other region, the player will refuse to play. Some players have the option to change this to universal mode. Check your player's manual if yours has this facility.
Yes. You can play VCD movies and and Audio CDs on most players.
Posted on Mar 18, 2009
jdvillanueva
  • 2098 Answers
SOURCE: dvd player wont read any discs cds and i just
No disc error can be a DIY like the following steps.
Assuming that the disc is good.
1.Cleaning the lens. - Sometimes because of dust the lens can't read any disc.
Try clean the lens by soft cotton buds. Be careful while doing this.
2.Replacing the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser.
If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Checked the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.
Good motor - reading should be fairly high and it will spin.
Bad motor - reading will drop to low resistance and will not spin.
Hint : 50% of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
If you already cleaned the lens, and confirmed that the ribbon is good as well as the motor then I've advice you to send it to repair shop because the next step should be done with an expert because it is quite technical diagnosing the fault between the pick-up lens and the main board.
Please rate my help.
Posted on Jan 18, 2011
vinceisaac
  • 2432 Answers
SOURCE: region
the disc is not compatible in your player not the same region.
Posted on Sep 08, 2012
I have a belson BSV 0661 car DVD player and it won't read the DVDs it keeps saying wrong region how do I fix that
Check an other known disc. If it play well, the the disc you're trying to play is region protected. Electro help
Nov 20, 2014 | Televison & Video
Why when loading a disc it says wrong region
This only happens with DVD. This invented to keep copyright protection different in some regions of the world.
There are programs that rip a DVD and then you can burn it free of any region code. Some brands do sell DVD players without region code limitation.
Read the article on wiki about region code. The disk you try to play, comes from another country.
DVD region code
Jul 10, 2014 | Sylvania Televison & Video
My old dvd player will not play some discs it says wrong disc what is the problem?
the reason why your old dvd player doesn't read the new dvd's is that might not compatible format or not the same region.
Nov 15, 2012 | Televison & Video
Our dvd player is saying wrong disc all of a sudden.
IT could be 2 things : check the region of dvd , or clean the OPTICAL LENS directly with a dry Q tip gently , if it still reads " wrong disc" then replace the optical lens , AJ
Jul 09, 2009 | Coby DVD-514 DVD Player
Sony dvd wont play certain discs
yes the sony dvd players is made for certain regions it wont play other discs that are not either region one or two new zealand i think is region 3
Apr 15, 2009 | Sony Televison & Video
Dvd keeps reading no disc
It can be several reasons
1. Disk is upside down
2. Lens is durty. You will need to use CD/DVD cleaning disk for that
3. Disk is having diffrent region code or recorded in diffrent formate (for instance player playback disk recorded in NTSC, and you trying to playback disk in PAL formate)
4.Disk is recorded at higher speed (for instanse player markered X16, but disk is recorded at X24)
Good Luck
Dec 24, 2008 | Televison & Video
Wrong Regional Disc.
DVDs are ecoded with region codes to indicate what area of the world they are made for. These codes may be 1,2,3, etc depending on which region they are made for.
DVD player read these codes and if the disc region code does not match the region the device is made for, the player will not play the disc.
Region 1 is for USA so most DVDp players made for use in USA require region 1 discs.
Some DVD players called multi region DVD players can be set to play different region DVDs but they are typically more expr=ensive then one region players and the code must be changed each time a different region disc is played.
Aug 27, 2008 | Audiovox D1710 Portable DVD Player with...
Wrong Region code error
http://www.amazon.com/gp/cdp/member-reviews/AGHZ9UF25BLCU/ref=cm_cr_dp_auth_rev?ie=UTF8&sort%5Fby=MostRecentReview
Click on the link and read the review of your product.
The region is set at the factory for your market for DVD movies in your area. Phillips says the warranty is void if you change the settings, but if you read the review he will tell you that you can make it region free.
Proceed at your own risk.
Mar 23, 2008 | Philips PET710 Portable DVD Player
GPX D200B Player Logo
19 people viewed this question
Top GPX Televison & Video Experts
Bill T
Level 1 Expert
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
