Question about Dynamo MartinLogan Subwoofer Speaker
My subwoofer will not work the power light is on
Stopped working. Power light is on. Could it be a fuse? Can I change it myself? Is there a lifetime warranty?
Amp has power, but no sound! - ecoustics.com
www.ecoustics.com > ... > Archive through November 13, 2007 Forum
Nov 5, 2007 - The other night my fiance's amp stopped pushing the subwoofers. ....also, it was working fine for however long- and then just stopped working. if that were the case, it wouldn't have worked in the first place. .... lastly before u go saying but the amps power lights on i'm sure the amps ..... Car Speakers Forum WHY DOES MY AMP POWER LIGHT TURNE RED ON PROTECT ...
Sep 11, 2011
Please someone help me! I am dying without my music!!!
Aug 4, 2011
Subwoofer stopped working all the sudden
May 26, 2010
More results from www.ecoustics.com
Jan 18, 2016 | Audio Players & Recorders
HTS14 subwoofer (Harmon Kardon)powers off after 10-15 minutes
Yeah, it sounds like it's over heating. Are you driving it way loud?
May 23, 2014 | Audio Players & Recorders
Protect subwoofer showing on power amplifier
Check your owner's manual for a Factory Reset, or Return to Default. Try that first. If it still doesn't work, try disconnecting the sub completely, and see it that resolves the issue.
Feb 03, 2014 | Sony MUTEKI HTDDW1600 Theater System
Subwoofer not working
The subwoofer is normally the main power supply for the other speakers. When setting up the system, there is a set up guide which allows you to control the power supplied to each speaker. You may have inadvertently set the subwoofer to have 0 output.
Nov 10, 2013 | RCA RT2870 Theater System
The lights are off
Do you have a 12 volt power running to the lighting plug? That enclosure requires a seperate 12 volt power line in order to make the lights come on.
Jul 16, 2008 | Dual XINBP-210 Car Subwoofer
Subwoofer
You have the subwoofer plugged into ac and you see a light? parhaps the RCA cord is bad. Try another one.
Jun 09, 2008 | Sony STR-DG800 Receiver
Onkyo subwoofer not working
I fixed my subwoofer. The resistor at R16 (right next to the fuse) was the fried component. I removed it and replaced it with a 13K ohm 5 watt metal oxide resistor (from Mouser Electronics if not available locally). Works fine now. I got the solution and the circuit schematic from an audio hobbiest at diyAudio.com. This is, evidently, a fairly common problem.
Sep 17, 2007 | Onkyo HT-S780 System
you have to reset the receiver, i had the same problem, works now, it's great, should be in the instruction booklet. I think it was, hold the power button while you disconnect it from the wall, not too clear but check the booklet in resetting system
Nov 01, 2006 | Kenwood VR-406 Receiver
Dynamo MartinLogan Subwoofer Speaker Logo
43 people viewed this question
Top Dynamo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Dynamo Audio Player and Recorder Expert? Answer questions, earn points and help others
