Question about Sharp XV-Z3000 DLP Projector
Put in new bulb but wont light up - Sharp XV-Z3000 DLP Projector
Car failed inspection,bulb was gone for check engine light. put new bulb in,has voltage but the Check Engine light on dash wont come on.
Probably won't pass. The light MUST come on when key is turned to on, or else something is wrong-maybe the engine computer or maybe the wire from pcm to the diagnostic connector or to the dash.
Now I see you say the bulb has voltage? May need to look into possible fault with the pcm.
Mar 05, 2017 | Nissan Cars & Trucks
Side light skoda octavia wont light
ensure the bulb is fully home, check the fuse next
Nov 16, 2014 | 2005 Skoda Octavia 2.0
Brake lights wont work how do you fix that
if you dident put new bulbs in put them in if no success put in a new fuse for the break lights if they still don't work the only other thing can be your break light switch hope this helps.
Apr 23, 2014 | Cars & Trucks
I put a new bulb in my jvc tv and it still blinks red why
take it out and put it back in it may have been put in wrong or something
Apr 05, 2013 | JVC HD-52G886 52" Rear Projection HDTV
My right front turn signal wont work, the dash board light came on telling me i need a new bulb i put one in and it still does'nt work . I checkd all fuses and they are good , me right rear turn l
are you sure that you put the right bulb in? Some of these bulbs look very similar, (like a 3057 and 3157 or 3156) but they are different. A customer came in with this problem and the problem was that they put a bulb with a single filament in when it was supposed to have a dual filament. the bulbs looked the same and they just grabbed them off the shelf instead of asking the parts guy what their vehicle called for.
May 27, 2012 | Cars & Trucks
The license plate lights wont come on new bulbs
Pull the bulbs and check to see if you have voltage going to the socket. If not, check wiring, and check for sany damage to wiring, harnesses, etc.
Apr 17, 2010 | 2004 Hyundai Elantra
Put new bulbs in fog lights, now fog lights wont come on. 98 cadi catera. replaced old bulbs with new halogen bulbs now neither fog light will come on
Halogen bulbs are brighter and generally draw more current than standard filament ones.
Have you check that the supply fuse has not popped ?
Jun 21, 2009 | 1998 Cadillac Catera
Bulb wont come out of fitting
Do you have a NEW bulb? The bulb assy 'twists' out (counterclockwise) and a new bulb 'twists' in (clockwise). Each bulb has a connector to it. Remove the connector, twist out the old bulb, twist in the new one, and reconnect the connector.25d2850.jpg
Apr 17, 2009 | 2003 Hyundai Tiburon
Sharp XV-Z3000 DLP Projector Logo
19 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
