Question about Jenn-Air Refrigerators
When filling a water glass the water sputters everywhere but the glass dribbling down the front of the door.
    Champion:
  • 210 Answers
Check the water tube.
Posted on Oct 15, 2013
2 Suggested Answers
woodchuck789
  • 4059 Answers
SOURCE: water dribbling out of dispencer whirlpool american fridgefreezer
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Posted on May 10, 2010
Inside water dispenser pumps water out really slowly on GE Profile PFS22MISBBB
It is possible that your water filters are getting plugged. Have you changed any filters lately?
The meat pan lever may also be turned to the coldest position and on units that have a low water usage, this will also cause the tank to freeze. You will want to lower the meat drawer setting or use more water from the door. This does not apply to Top Mount water dispenser models, because they do not have a reservoir. Problem requiring service, glass fill time.
View a short video about troubleshooting water dispenser issues :
Play Video
View a short video about slow water dispensing issues:
Play Video
  • Dispenser drips water constantly will be a water valve problem, and should be checked by a service technician. If you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737 or schedule a service appointment on-line.
  • Dribble as defined as a small amount of water (few drops) that may miss the glass ONLY AFTER USAGE. This is due to a delay in the overall system.
    Dribble can be minimized by the following actions:
    - Purge the tank, by holding down the dispenser for 2 to 3 minutes, to remove any trapped air that may be building pressure and causing the dribble.
    - A few drops is normal, but you can also prevent water from missing the glass and dripping down the cradle area by moving glass slower when removing it from the cradle.
    - You may need to periodically empty the recess grill and clean out underneath it to prevent overfilling and water dripping down the front of the refrigerator.
  • Also, remember the dispenser in the door will not operate unless the door is closed
  • Apr 10, 2012 | GE Refrigerators
    Just had a new part # 241734301 installed, because the old one broke during a move. It appears to work fine although the water continues to dribble for a while after filling a glass. Also, the water will...
    It seems as though the water hoses are reversed, Ice maker line and water dispenser line are probably switched, this would explain why the water comes out the door intermittently. It's probably trying to dump water into the ice tray but its coming out the door.
    May 22, 2011 | Frigidaire FSC23F7D Side by Side...
    The water tap leaks
    Good Day,
    If the water dribbles from the outlet after filling the glass normally, then the cause is the dual water valve located in the bottom rear of the machine. The diaphram inside the valve is not sealing completely when power is removed.
    The valve is a dual unit for the ice maker and water in the door.
    It is none servicable and must be replaced with a new one.
    It's a common problem and replacing it is not difficult and the valve would be carried by any decent sized appliance parts house.
    Jul 17, 2010 | Kenmore 53092 / 53094 Side by Side...
    Water dribbling out of dispencer whirlpool american fridgefreezer
    May 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
    Water leaking out of door , seems like it might be a problem with the door hinge ?
    Not likely that you have a hinge problem, but it can happen, especially if water has been dribbling down the back side of the front panel from the dispenser area, getting on the hinge, and causing it to bind up. Replacing the hinge is a pain because the screws are put in with thread lock, requiring heating or even drilling in some cases. If you have water dripping down the front of the machine from the door, the most common reason is that there is some lint or hair on the bottom side of the glass door, preventing a complete seal to the gray rubber gasket. Generally, just cleaning off the bottom of the glass door will fix it. If that does not do it, you can try moving the spring clamp (which holds the front of the gray tub seal) from the bottom (6 O'clock position) to the hinge area (9 O'clock position) Sometimes, the leak is caused because someone pushed the washer into place by placing their hands just below the door and actually deformed the metal front panel inward, preventing a seal between the door glass and the gray tub seal. If that is the case, it may be corrected by removing the spring retaining clamp, taking the front of the gray tub seal off, pulling outward a bit on the metal panel at the bottom of the door openings, and replacing the seal and retaining band again.
    May 09, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
    Fridge water filter replaced now flows very, very slow
    Hi .. first I would try and eliminate the filter as the problem. Remove the filter and try the water again. If the water flows strong, then the filter is the problem. If the water stills sputters and is low flow, then there is a partial blockage in the internal tubing , or a problem with the supply. If you roll the fridge out to get at the suppl. you could shut it off and disconnect the supply tube from the fridge, then turn the water on slowly to check the flow at the supply. If the flow is good there , then the blockage is internal.
    May 03, 2010 | Kenmore 21.7 cu. ft. Side-by-Side...
    Water filling while door is open
    if water is constanty dribbling into the machine then there is a leaking water valve on the machine, if not leaking in all the time then exessive water pressure at some time, dont thing it is the control
    Apr 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Food behind the glass front
    upper oven will not heat after going thru cleaning cycle
    Jan 18, 2008 | KitchenAid KEBC208 Electric Double Oven
    Dribbling water when trying to fill up
    Turn off faucets for hoses to washer. disconnect hoses at washer, noting which one went where first.. Hold end of hose in washer tub and turn on faucet. If it comes out strong, check the filter screens in washer inlet valve where hoses connected. DO-NOT remove these screens. If you do it can cause flooding by allowing grit to hold open valve. Clean screens without removing them by scraping with small screwdriver and flushing with water.
    Nov 21, 2007 | Washing Machines
    Refrigerators Logo
    53 people viewed this question
    Top Jenn-Air Refrigerators Experts
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    jasbo
    jasbo
    Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
