Watches Logo
A
Anonymous Posted on Oct 14, 2013
Woods timer td2200a manual - Watches
2answers
I need to know how to set timer for Adidas Ad0297107
There is single manual for all adidas watches. You can find procedure for your watch.
ADIDAS-ORIGINALS-TIMEPIECES_CARE-MANUALS_EN.pdf (adidaswatches.com)
Steve Madden LED touchscreen watch
To change the date and time on your Steve Madden LED touchscreen watch, you will need to follow the instructions in the user manual that came with the watch. If you do not have the user manual, you may be able to find information on how to set the time and date online or by contacting Steve Madden customer support.
To set the time and date on most LED touchscreen watches, you will need to press and hold a button on the side of the watch for a few seconds until the time and date display appears. You can then use the buttons on the side of the watch to set the time and date. The specific buttons you will need to use and the sequence for setting the time and date may vary depending on the make and model of your watch.
As for the timer, you will also need to refer to the user manual for instructions on how to use it. The timer function may be accessed through the watch's main menu or by pressing a dedicated button on the side of the watch. Again, the specific steps for using the timer will depend on the make and model of your watch.
If you are unable to find the user manual or are unable to set the time and date or use the timer function, it is recommended to contact Steve Madden customer support for assistance. They will be able to provide you with specific instructions for your watch.
Dec 25, 2022 • The Watches
I have a newly purchased (from private party)Citizen World timer model CB- 0000-57E Cal H144 mvt; I had it in the window where all my g Shocks sync just fine last nigtt; this one wouldn't sync,...
I have a new Citizen watch with World Timer. I want to set the time manually and turn off the world timer. I never want to receive the signal..... The book is no help.
5helpful
Minute timer hand zeroing
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all WENGER watch manuals.Rate me, please..
Mar 28, 2010 • Watches
4helpful
Help Me set the watch please
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps.
R/
David
Need manual
Timer Setting
1. In timer mode press and hold "reset" to enter setting mode; hour will begin flashing
2.Press "st/stop" to increase hours;
3. press "mode" to advance to next setting value
cheers!
Apr 21, 2009 • Watches
Timex Men's Digital Expedition Chrono Alarm Timer Watch battery
hi
please follow the steps to change the battery
  1. Step 1 Make sure the little arrow on the back is aimed to the right. Then, insert a small flat head screwdriver into the notch on the edge, and lever the back open. Place the back to one side.
  2. Step 2 Unscrew the clip holding the battery (if your model has a clip), and remove the battery.
  3. Step 3 Use plastic tweezers to put in a new battery. Do not directly touch the new battery. Screw the clip (if it has one) back on.
  4. Step 4 Replace the gasket that seals the watch. Then lightly coat the gasket with a silicone-based grease.
  5. Step 5 Align the back with the little arrow aimed to the right again, then carefully press the watch between two pieces of wood that are being held by a small vise, until the back seats itself.
thank you....
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
