Question about Dell Dimension 3100 PC Desktop
Ethernet driver for windows 7
I have a dell dimension 3100c PC Desktop and upgraded it to windows 7 64 bit and need the ethernet driver
    Problem Solver:
  • 8 Answers
There does not seem to be a valid Windows 7 network driver:
http://ftp.dell.com/Pages/Drivers/dimension-3100.html#Network
You can try the driver for XP to see if that will work, otherwise you may need to buy a new NIC card.
Posted on Oct 14, 2013
oldnovii
  • 667 Answers
SOURCE: ethernet driver for dell dimension 4600
Hi stefyboy - Below is a link where you can download your driver. After you get to the page just make sure it says Windows XP as the operating system. Then scroll down and click on the + next to where it says network. You want the intel 10/100 driver. I've included a few a ways to install it. If your kinda new to this the easiest is the download to desktop method and just remember where it unzipped it to, you can always move it to a driver directory where you can keep all your drivers for the future.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_P4_4600&os=WW1&osl=en&catid=&impid=
If this solves your problem PLEASE rate this as fixed. If not, DO NOT RATE YET. Just add a comment letting me know what happened and I'll be glad to assist you further. Thanks.
Jeff
Hard Drive Installation (via WinZip) with HTML Pop-Up Window for R67150.EXE
Download
1.Click Download Now, to download the file.
2.When the File Download window appears, click Save this program to
disk (Windows XP users, click Save) and click OK. The Save In: window
appears.
3.From the Save In: field, click the down arrow then click to
select Desktop and click Save. The file will download to your desktop.
4.If the Download Complete window appears, click Close. The file
name icon appears on your desktop.
Install
1.Double-click the new icon on the desktop labeled R67150.EXE.
The Self-Extractor window appears.
2.Click OK or Continue.
The Self-Extracting Driver Installation window appears and prompts to
extract files to C:\DELL\DRIVERS\R67150.
3.Leave all of the default settings and click Unzip or OK. If the directory doesn't exist, you'll be prompted to create one. Click Yes. A Self Extractor window appears and indicates C:\DELL\DRIVERS\R67150 files were
extracted.
4.Click OK.
Follow the on-screen installation instructions in the window.
HTML Pop-Up With Install Now Button
1.The Dell Software Installation Documentation window appears.
2.Click the Install Now button. A File Download window appears.
3.Click Run this program from its current location and click OK.
The Security Warning window appears.
4.Click Yes. The InstallShield Wizard window appears.
5.Follow the on-screen instructions.
Posted on Jul 08, 2008
SOURCE: DELL Dimension 2350
I wanted to use the advice by Daniel and it did not work for the Ethernet Driver. My dowload which worked, was R64645.exe and is described here
Posted on Oct 16, 2008
SOURCE: Dell Dimension 2400 PC Desktop CPU Fan Suppose To Blow?
Blows air into the case away from the cpu.RICHARDM69...This is a solution please vote as such.
Posted on Dec 20, 2008
  • 87 Answers
SOURCE: I upgrade the memory of a Dell Dimension Desktop 9150
No you don't have to install a 64 bit OS. Only if you install over 3 gigs you MUST install a 64 bit operating system. 800MHZ is fine it will just back down to 667MHZ. your 32bit windows OS will see up to 3 gigs (minus graphics card memory). SO 2 gigs will work fine. Install one stick at a time and check in the OS and bios to make sure each stick works. I would say you possibly have a dead ram stick.
Posted on Jun 04, 2009
I wish to upgrade my PC with windows 7
Depends on your Hardware.... if it is a slightly Older Computer then chances are it is a 32 Bit.... but if it is one to just a couple of years old... it COULD be a 64 Bit......
Regardless of if 32 or 54 Bit the Computer WILL run on 32 Bit Win 7.
and again regardless of 32 or 64 bit,.... 32 Bit Software SHOULD run on it without problems, but you may have to set it to "Compatibility Mode"
Good Luck
Jun 03, 2014 | Dell Dimension E310 PC Desktop
Can this model be upgraded from xp 32 bit to windows 7 64 bit with 2.5 gb of memory?
Yes you can however HP only supports Windows XP (32-Bit), Windows Vista (32 and 64 Bit) No official support for windows 7.
However Most modern PC's will run windows 7 and most drivers are available. Upgrade at your own risk.... There might be some drivers that you wont find and may cause problems with your PC.
But why upgrade to 64bit if you are not upgrading memory to 4GB+?
See Windows 7 system requirements Microsoft Windows
May 04, 2014 | HP Compaq Presario SR1910NX (EX310AA) PC...
What is the maximum ram capacity of dimension 8200 motherboard
2 gygabytoes are usually the max, you could upgrade the OS to maybe Windows XP 64 bit, but this isn't worth it in such an olde machine! Throw it out and get yourself an ASUS laptop with Windows 7 64-bit, a solid state HD and 4 or more gigabytes of ram instead!.
http://www.crucial.com/upgrade/Dell-memory/Dimension+%2F+Dimension+XPS/Dimension+8200+Series+%28400MHz+FSB%29-upgrades.html
Mar 16, 2013 | Dell Dimension 8200 AUD System Board...
Need to flash BIOS
Here is the link for your Dell Dimension E520 updated BIOS version 2.4.0 released on 7/11/2007. One confusion Windows 7 is not recommended by DELL for your model!
Oct 21, 2012 | Computers & Internet
I formatted a dimension 8100 and I install window 7 32 bits now I can't upgrade my Ethernet or sound drivers
I suspect you already tried the drivers. Dell site only has drivers from 2001. You may have to roll back or purchase new cards. It's the same reason I can't use Win8.
http://www.dell.com/support/troubleshooting/us/en/19/Index Choose drivers and downloads..
Aug 30, 2012 | Dell Dimension 8100 PC Desktop
1. Can Dell Dimension 9100 work with 2x2gb ram? 2. I am trying to install Windows 7 on a refurbished Dell Dimension 9100. It has 2x2gb ram, 1 TB Hard Drive and I have Windows 7 32 and 64 bits + Palit...
Here is a link for upgrading to Win 7: http://en.community.dell.com/support-forums/desktop/f/3514/t/19356108.aspx
If you can't boot form the CD/DVD you have a problem with your CD/DVD drive. If you can enter the BOIS (setup menu) then your computer is working, just waiting for a device to boot from.
Mar 20, 2011 | Dell Dimension 9100 PC Desktop
I installed 4 Gig of RAM memory but only 3.25 shows up.\r\nis there a test I can run to see if the memory cards are working correctly? Thanks. Paul
It sounds like you are running a 32 bit operating system XP, Vista, or Windows 7 (32).
The 32 bit Operating Systems are only able to see and use about 3Gb of RAM. To use a greater amount you will need a 64 bit OS (either Windows XP/64 or Windows 7/64) or one of the open source 64 bit operating systems.
Oct 15, 2010 | Dell Dimension 4700 PC Desktop
I try clean install to 64 bit win 7 from xp media center (32 bit), computer screen freeze at ''starting windows''. Can not install...
Are you sure your computer supports 64-bit processing? And if it does, try booting the Windows 7 disk and try to repair Windows following the steps. Hope it helps!
Nov 06, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
I upgrade the memory of a Dell Dimension Desktop 9150 from 512 MB to 2 GB,The machine accept up to 4 GB..In the BIOS appear the 2 GB but on system in Control Panel only shows 512 MB..Can anybody give me a...
Jun 03, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Vista 32 Bit verses 64 Bit
Before you jump in and upgrade make sure your computer system is 64 bit ready otherwise it wont work at all....upgrading memory is never a bad thing will actually speed up things from running and will have a better response time....windows 7 does not require 64 bit but it desired if possible....
Apr 11, 2009 | Dell Dimension 3100 PC Desktop
Dell Dimension 3100 PC Desktop Logo
76 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
