Question about Panasonic Televison & Video
P50UT50 8 blinking lights, attempted restart.
P50UT50 8 blinking lights, attempted restart. Pulled back cover and checked all connections and did a visual check of all boards. Everything looks good. Still get a click on and off, back to 8 flashing lights again. Power supply? SS A SC/SU/SD
  • Official Brand Answer
  • 350 Answers
Try disconnecting all HDMI cables and plugging the TV into a new wall outlet. If the issue is resolved, it may have been caused by a small power surge from either your wall outlet or one of your source devices.
Posted on Nov 13, 2013
  • 109 Answers
SOURCE: 50HP95 Toshiba Plasma TV No power but blinking power light
To eliminate power in as a problem get a small battery backup type UPS. This will eliminate power surge spikes, brown outs and for short time periods blackouts. Yes - these TV's are suseptible to power problems.
Posted on Mar 28, 2009
  • 8457 Answers
SOURCE: when power button is pressed,click,click,click
Check all the capaciotors in the power supply board for bulges up or little puffs up.Change these capacitors will get ur power back to normal funsctions.
Posted on Apr 24, 2010
SOURCE: power light comes on and clicking is heard but no
your problem is more a defective y board with y buffer boards one of them is short
Posted on Oct 26, 2010
diodeic
  • 1622 Answers
SOURCE: tv light flashed and cut
Your power supply board is not yet dead, u know basic electronics' and soldering? You have to open the back cover of the television check for dry soldering on the printed circuit board , if found resolder but if not Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem...
Posted on Nov 29, 2010
budmrtn
  • 11361 Answers
SOURCE: When plugged in, the logo flashes white.
The 5vdc standby is working but not the 12 or 24v?
You need to find out if the power supply board is getting PS_ON signal from the main board to turn on the 12/24vdc power supply section.
Please read my guide to get some understanding first.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c rating such as PANASONIC FM or FC series.
Please post back what you find.
Posted on Dec 06, 2010
Furnace fails to light after. 3 attempts then LOCKS out, will come back on after 1, hour.....only does it once in a,while... One,blink. Goodman dependable ninety two
What is the blinking code ,check on your door cover and you will see code and fault.This should lead you to the problem
Feb 08, 2018 | Goodman Heating & Cooling
47LG70 won't stay on
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 16, 2013 | LG 47LG70 42 in. LCD TV
Engine quit wont restart just whirls over no attempt to start
If the engine light is on.You will need to have the ECM scanned for the trouble code
Oct 21, 2012 | 2002 Kia Sportage
I have a craftsman 1/2 HP door opener. When I attempt to open the motor clicks but there is no movement. I have tried reprogramming but the issue continued. The indicator on the back is blinking, the light...
Check your door springs. Could have a broken one. Also remove the cover from the motor unit and check the drive gear. It could be stripped. If the light on the back is blinking randomly that is normal. It can also send a code. See if it blinks a number of times, pauses and then repeats.
Aug 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
Compaq 6735s notebook pc goes to HP screen, but wont boot
First you need to determine how many blinks you are getting when you try to power on the laptop.
Check the blinking codes below and reason behind that for HP Compaq laptops
Blinking battery power LED Battery Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock - System board General system board failure
Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure
Plz get back so I can suggest you the steps to resolve the issue.
Dreamkam
May 24, 2010 | HP Compaq 6735s Notebook
Intermittent pefrormance of GDT070-3A
It probably went thru the 3 cycles and shut downed. To reset it you have to kill power and restart it, sound like loose connection .
Dec 19, 2009 | Heating & Cooling
Paper light continually flashes won't print
when you lift the cover on the back of the printer there is a thin plastic sensor very delicate normally black in colour which detects whether there is paper in the tray or not.that sensor is slightly moved from its orignal position or broken , so this problem is coming.
thanks.
Sep 18, 2008 | HP LaserJet 4L Printer
Printer is on but cannot print
if your power light is off and the paper and ink lights are flashing try this.
1. remove all the paper,
2. open the cover and check for paper jam
3. make sure the ink cartridge lid is securley in place by opening and re closing the ink cartridge lid
reclose the lid, disconnect the power supply and hold the power button for 30 seconds. reinstall the power plug and turn the printer back on.
hope this helps
May 12, 2008 | Epson Stylus® Photo R2400 InkJet Printer
Change Image Drum light blinking
You have to reset the drum counter. Leave the front cover open Press and hold the "cancel" button until all the lights flash in sequence Close the front cover You should be good fro another 30 - 40 thousand copies. Hope it helps Ed
May 22, 2007 | Dell 1710n Laser Printer
Televison & Video Logo
61 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
