Question about Transmission & Drivetrain for Ford Transit Connect
2003 crown vic when shifting from 2nd to 3rd it drops back down in low
    New Friend:
  • 100 Answers
If the computer is commanding 3rd, and it's not going into 3rd, then there may be an internal trans problem. Are there any codes (usually a check eng light will come on)? It could be helpful in diagnosis.
Posted on Oct 14, 2013
  • Chris Vittitoe Oct 15, 2013
    no codes, hesitates slightly going into reverse
Heater in 2003 crown vic stays on always , can't shut down or control
Heater in 2003 crown vic stays on always ???? Blower motor ? Air blowing out vent's all the time ? Blower motor speed control module .maybe ! If that is what your taking about . Can't turn blower motor off .
Dec 14, 2017 | 2003 Ford Crown Victoria
My 1999 ford ranger shifts hard from 2nd to 3rd gear what is the problem I recently changed fluid and filter but shifts hard !
Auto Trans not shifting correctly from 2nd to 3rd - Ford Explorer ...
www.explorerforum.com > ... > Under the Hood
May 8, 2004 - 19 posts - ‎9 authors
Auto Trans not shifting correctly from 2nd to 3rd Under the Hood. ... Become an EliteExplorer. Lithuania. 1999 5.0. Join Date: Jun 2003. Posts: 107 ... When this happens, the transmission will skip to the next gear like you said.
Transmission Harsh shifting - YouTube
? 3:59
https://www.youtube.com/watch?v=aAoiL4vR8Qw
Jan 13, 2013 - Uploaded by James Burns
... Doctor, explores the causes of harsh shifting in automatic transmissions. ... Early diagnosis is important to ...
Hard Tranny Shift between 2nd & 3rd - Ford Truck Enthusiasts Forums
www.ford-trucks.com > ... > Super Duty & Heavy Duty
Feb 24, 2012 - Hard Tranny Shift between 2nd & 3rd Super Duty & Heavy Duty. ... I just got a new to me 99 f250 5.4 V8 SD XLT 4x4 Auto Trans longbox 118k miles. ... it out and said it was solid except for a hard shift between 2nd and 3rd gears. ..... Hard shift between 2nd and 3rd, Brenda Lamka, Explorer, Sport Trac, ... hard shift 2nd to third gear only 4r100
Dec 26, 2012
hard shift into 3rd
Nov 4, 2009
4r55e 5r55e Ranger / Explorer Transmission Problems - CLICK ...
Mar 15, 2007
00 Expedition trans shifts late and hard
Jan 01, 2016 | Ford Cars & Trucks
2000 yz250 shift to bottom (neutral) won't drop into 1st
check your shifting drum.may have left a pin out of the shifting drum.
Apr 01, 2014 | 2003 Yamaha YZ 250
2003 Crown Vic drops to 1st gear instead of shifting into 3rd
run diagnostic or replace transmission computer sounds like tranny computer or shifter module on transmission
Oct 14, 2013 | Transmission & Drivetrain for Ford Transit...
98 crown vic transmission slipping
Change the filter and fluid. This car if the transmission is original should have a torque converter drain. Drain the torque converter also,it gets almost all the fluid out of the transmission. Doing this the car will require almost 12 quarts of fluid. Worth a shot. I change mine at 25000 mile intervals.
Oct 31, 2012 | 1998 Ford Crown Victoria
Transmission will not shift to 2nd or 3rd gear
the 2nd and 3rd gear solenoid needs to be replaced inside the trans pan
May 24, 2011 | 2003 Chevrolet Suburban 1500
Transmission jerks on 1985 Crown Vic when cold. Doesn't want to shift, and transmission jerks violently when cold. Also, automatic transmission doesn't like to shift into 3rd gear, unless you exceed 45...
Unless you are low on fluid, I suspect you are in need of a rebuild. I have had similar problems before. Any shop will tell you to try a fluid and filter change. It has never brought one of mine back. I would suggest adding fluid to the top of the 'add fluid' area of the dipstick and no more. It can foam if it is to full, causing similar problems as being to low. I would add that if you have to replace the transmission - you need to consider that the car may not be worth the cost.
Good Luck.
Nov 25, 2010 | 1985 Ford Crown Victoria
1985 Ford Crown Vic won't shift sometimes. Seems
Have he transmission drained and the screens cleaned
Jun 05, 2009 | 1995 Ford Crown Victoria
Transmission & Drivetrain for Ford Transit Connect Logo
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
