Dishwashers Logo
S
Susan Bailey Posted on Oct 14, 2013
Need a manual for neff s4n14f not sure what the different settings are for.
I have a new neff built in oven. I turned it off over an hour ago and the fan is still running. Surely this is not right. Any suggestions.
Hello, Sylvia -
Since your Neff oven is new, I hope I am correct in thinking you have the owner's instruction manual for the oven and you already checked there to see if there were any troubleshooting tips regarding the fan still running after turning the over off over an hour prior.
If you do not have the instructions for the new oven, check here:
http://www.neff-home.com/uk/service/manual
Note: You will need to supply the E-Nr number for the oven. If you do not know where to find the E-Nr number, on the web page cited above, click or tap on the link for the rating plate finder.
After checking the owner's instructions for the oven, the next thing I would suggest is contacting Neff Specialist. See the information here:
http://www.neff-home.com/uk/service/support
Talk to a Neff Specialist.
You new Neff oven is most likely still under warranty.
Best wishes.
May 01, 2018 • Neff Ovens
I have a Neff dishwasher s5443x2gb/42. I don't know the sizes for this machine ? how many placings does this hold
The number of place-settings a dishwasher holds is irrelevant. Different manufacturers quote different place-settings. Some manufacturers might include a soup bowl, still others could include a fish plate.
Neff manual
1997 model.....their were 6 different models brought out in 1997
Sep 05, 2014 • Neff Ovens
I need instruction manual for Neff microwave oven model 5969
Use link, enter full ENr from rating plate and you can download PDF of manual
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
I have no main heat on neff oven and i think it
Make sure the oven is set for 'manual' start cooking as opposed to 'automatic'. Usually you have to press a button on the timer.
Dec 24, 2009 • Ovens
In Greece on holiday, want to circo roast chicken in Neff oven and enerything is in greek. How do I set oven to roast?
Hi, Welcome to FixYa.
The help from Neff can be from:
http://www.neff.co.uk/files/gettingstarted.pdf
Also you can find the manual from:
https://portal.bsh-partner.com/portal(bD1lbiZjPTAwOQ==)/PORTALFRAME.HTM
Please give your model number and get the manual from there.
Our site need your feed back for improvement.
If the post helped you, please select 'YES'
Jul 09, 2009 • Ovens
2answers
Neff w4380x1gb
We have had the same problem - £208 for a new power board - IT DID NOT FIX THE PROBLEM
Top Neff Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Tracy
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
