Konica minolta bizhub 203 - Office Equipment & Supplies
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
Posted on Nov 19, 2007
  • 8 Answers
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Posted on Feb 02, 2008
Nitrotrike
  • 589 Answers
SOURCE: copier malfunction
Code C0F36 is a low toner density error on the black developing unit.
Was it asking for black toner before this code appeared?
Posted on Feb 10, 2008
  • 10 Answers
SOURCE: service manual for KONICA MINOLTA Bizhub 210/162
Swithc off the machine Press stop button and hold switch on the machine. problem will go.
Good Luck
Posted on Jan 07, 2009
xeerie
  • 347 Answers
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Posted on Jun 19, 2010
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
Where can this part for the printer be purchsed ? konica minolta bizhub 160
Except you don't say what 'this part' is :>)
Never mind. Here you go. Or look in Yellow Pages for a technician.
  • Konica Minolta bizhub 160 Supplies and Parts (All) www.precisionroller.com > ... > Konica Minolta > bizhub 160 Konica Minolta bizhub 160 Supplies and Parts (All) for less. Free shipping on orders over $75.00!
  • Konica Minolta Bizhub 160 Toner, Parts, Supplies, and ... www.arcservicesco.com/1016/konica-minolta-bizhub-160-i-toner-parts... Additional Info Konica Minolta Bizhub 160 is a Digital Printer and Copier which was introduced February 10, 2012. Suggested Retail Price:$1,029
  • images of konica minolta bizhub 160 parts bing.com/images th?id=oip.mcd31c057681b6e2e393bc136df5885ddo0&w=140&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.m850c92a4f48e9107608f3f81e06b2feeo0&w=99&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.mdb0ced5306197a197806530dbb355967o0&w=74&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.mb7d2a296bf50d1a0bb42098505ce2c61o0&w=133&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.maedc8ec17eba695445679a648922e7e3o0&w=70&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2 See more images of konica minolta bizhub 160 parts
  • Konica-Minolta bizhub 160 160f 161 161f Parts Manual www.qmanual.com/printer/konica-minolta-1/bizhub/konica-minolta... BRAND: KONICA-MINOLTA: BRANDSKU: No: TYPES: Parts_Manual: SIZE: 1.49M: PAGES: 35: FORMAT: PDF: LANGUAGE: English: QUALITY: High resolution: ...
  • Konica Minolta Bizhub 160 Printer / Copier Parts & Supplies https://discountcopiercenter.com/konica-minolta/bizhub-160.html Save big on Bizhub 160. We offer the lowest prices and highest quality, with free shipping on any orders over $100!
  • Konica Minolta bizhub 160 Parts Guide (160_PARTS) www.atec.ro/parts.../konica-minolta-mfps/konica-minolta-bizhub-160... Konica Minolta bizhub 160 Parts Guide; PN: 160_PARTS
  • Apr 01, 2016 | Konica Minolta Office Equipment & Supplies
    Konica Minolta BizHub C252 - pale colors on the long side
    Konica Minolta BizHub C252 Repair Questions,... - Fixya
    www.fixya.com > Forum > Printers & Copiers > Konica Minolta
    Konica Minolta BizHub C252 - pale colors on the long side · Konica Minolta. ... I have a Konica C250 machine which cannot print red color at all. I had changed ...
    Konica Questions answered here ' FixYourOwnPrinter
    www.fixyourownprinter.com/posts/40820
    Aug 22, 2008 - On the right hand side of the drum (the part that has the large green handle) that easily slides out. There is a ..... I have konica minolta bizhub c252 colour printer. ... The K light came on a long time ago and is constant on now.
    How to clean the drums/i units on the konica minolta number ...
    ? 0:28
    https://www.youtube.com/watch?v=eD8HdNq0MlE
    Nov 23, 2011 - Uploaded by Tennants Nottingham
    How to clean the drums/i units on the konica minolta number plate printer ... Fix or repair color laser printer with fading, lightprint, or lines samsung clp 300 ... Imaging Unit Reset for Konica Minolta Bizhub C203 / C253 / C353
    Dec 14, 2015 | Konica Minolta BizHub C252
    C550 cooling fan not functioning, what can i do to make work?
    Konica Minolta bizhub cooling fan not working Questions ...
    www.fixya.com/tags/cooling_fan_not_working/printers/konica.../bizhub
    Konica Minolta bizhub printers & copiers cooling fan not working related questions and answers. Ask your Konica ... Question about Bizhub C550. 1 Answer ...
    Konica Minolta Bizhub C550 Cooling fan power - Questions ...
    www.fixya.com > ... > bizhub > Konica Minolta Bizhub C550
    konica minolta bizhub c252 error c-5351 C - 5351 Is power cooling fan problem.Verify the cooling fan connectors and clean.For reset open/close the front door.
    cooling fan not operating properly - HP Support Forum
    Nov 29, 2015 | Cars & Trucks
    Konica minolta c203 network connection ip fails
    net wook cable ok, how about the nic connnection on the copier control board, have tech come out and look at it, mite need anew image control board,
    Feb 17, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
    Cual es la cinta de transferencia que tengo que quitar para limpiar los sensores de control de densidad de una bizhub 203
    replace the black image unit and clean the transfer belt sensors located under the transfer belt
    Nov 23, 2013 | Konica Minolta Bizhub c203 Copier
    15 people viewed this question
    k24674
    jasbo
    jasbo
