Wd elements light blinks
Hard drive feels and sounds like it won't spin up to speed, kind of gets going and then a whirring sound and it slows down. Won't show up on my computer.
    Novelist:
  • 222 Answers
It sounds like you just need some mortar and a few more dead hard drives to start building your dream home. ...
Why we make backups (unless the data is important and irreplaceable). There are some FAQs around that tell you to hit it with a hammer and make an immediate backup if that helps.
Posted on Oct 17, 2013
    Master:
  • 359 Answers
Sounds like the disk reader might be broken. Is the drive old or new?
Posted on Oct 14, 2013
4 Suggested Answers
  • 10406 Answers
SOURCE: WD elements SE 1TB Portable hard drive will power
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Note that W.D. has a "Customer Loyalty" program. Buy a new W.D. disk-drive through the W.D. web-site, and you'll get a significant discount.
Posted on Nov 04, 2010
  • 10406 Answers
SOURCE: my wd elements hard drive
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Posted on Dec 31, 2010
  • 212 Answers
SOURCE: My WD element extrenal hard drive won't open. i can see it in my devices, and the blue light stays on. it also makes the sound saying it's connected but I can't see the device in my comput
First thing, try to change the cable, try a different one, then if it does not work, try to connect the hard drive on another computer, and changing cables as well. This will help you to narrow down the problem to find out exactly what the matter is. If the Hard drive spins properly and it does not produce any click-click sound then it is fine. If all the above fail, then you have to slave the hard drive using its internal SATA connection. You have to open up the hard drive and remove the pin that connects the hard drive to the cable. This will enable you to see the SATA connection. Slave the Hard drive on a desktop computer and see if you can gain access to it. If you can, then consider replacing both the cable and the pin that connects the cable to the hard drive. If your hard drive just spins and you can not access it while its a slave to another computer, then the hard drive has a problem.... Try the methods above, i believe your hard drive did not go this bad...
Posted on Mar 26, 2012
Mar 26, 2012 | Western Digital Elements powered by WD 320...
Hi, I have a WD external HD (my book essential) that doesnt seems to be read by any of the pcs I've tried to plug it on. It doesnt make a sound or even blinks that blues light. I tried to change...
This unit requires separate AC power. If the blue light is not on to begin with - indicating power, no PC will be able to read the USB. There is a hard disc in the unit that needs to spin...it is not solid state like a thumb drive.
Jun 13, 2011 | Western Digital My Book Essential...
Mitsubishi WD-82738 has no picture, makes short whirring sounds but won't turn on. Flashes 6 red lights then 1 yellow light and repeats sequence. Tried system reset but to no avail, light turns green...
After rereading the symptoms you descibe what you describe might be a faulty colorwheel. When the set is first plug up there is a small mechanal motor that has to reach certain speed. if this does not reach that speed the set will not allow the lamp to fire. The whirring sound could be the colorwheel trying to spin up. these break all the time. (its a motor and anything that moves eventally will not.) it a fairly simple rep;air thatn most quilfied techs can repair. Such a repair generally should take more than a hour to do
May 28, 2011 | Televison & Video
My WD element desktop was working properly but now when i connect to my laptop it is not recognizing not even on the bottom left corner of the desktop even sound is not there when connecting. My harddrive...
First things first. When you plug the drive in and power it on....does the drive spin up? If so, if you place your ear near the drive, you should hear a whirring sound of the drive platter spinning and the slight clicks of the drive arm moving.
If you don't hear this, it could be a power problem with the drive or the drive itself may be done.
If you hear the drive spinning, then most likely your data is safe. From there I would suggest trying to plug the drive into another USB port on your laptop, or even into another computer altogether. If it works there, then you most likely are having a driver issue, or perhaps a drive letter conflict.
(For instruction on how to resolve a drive letter conflict, see my response to this post: http://www.fixya.com/support/t8601787-need_driver_8gb_sandisk_cruzer)
Otherwise check the device manager in the control panel to see if you show a "USB Mass Storage Device" show up under your USB device drivers in the list. You may want to right click and uninstall it if you do see it.
If you DON'T hear the drive spinning, I would check the power first. Make sure it's receiving power (look for indicator lights etc) you might be able to remove the drive from the plastic enclosure and use a USB Drive adapter (Like one of these ) to recover data from your drive
(http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2329300&CatId=3770)
If the drive is not spinning and the power or drive adapter doesn't work, you may have a bad hard drive.
Good Luck
Mar 08, 2011 | Western Digital WD Elements Desktop...
My hard-disk is on-Warrenty basis.On hardisk light is blinking but unable to detect on pc ,So Please tell me the procedure how to recover my data. P/N-WDBAAA5000ABK-00 S/N-WXM1A80N4025N
Can you hear the drive spinning when you connect it to your computer? A spinning sound means your external drive is being powered by the USB from your computer - there are several reasons the drive is not being recognized.
If you are not hearing any spinning sound the drive could be damaged.
Does the drive get recognized by any another computer? If yes - check disk management and see if security is enabled on the drive. Also - check to see if there is a drive letter assigned to your external hard drive.
Link
Feb 28, 2011 | Western Digital WD Passport 250GB Portable...
Dropped it from a few inches. Computer wont recognize it. Tried hooking to my laptop, it loaded the drivers but still wont show up in My Computer.
try taking it apart making sure that the connections are plugged in
good and tight , also reboot the computer while its plugged in , if
still nothing listen for a spin up and spin down sound or a clicking
sound , the spinning up and down sound means the motor is
malfunctioning , a clicking sound means the units heads are
malfunctioning , if any of these problems exist let me know
my name is David or user name terminalcon just add attention
to; and I will help you further .
Jan 28, 2010 | Western Digital Elements powered by WD 320...
Hard drive will not turn on, light blinks
sounds like the powerboard bit is knackered on the case try taking the drive out the case and buying a hd caddy sata 2 usb
Jan 01, 2010 | Western Digital 500GB ELEMENTS 500 GB USB...
Computers & Internet Logo
David Payne
David Payne
