Question about Curt Mercedes Sprinter 3500 2007-2009 Splice-in Converter
My Mercedes sprinter is 2007 model I have power loss and MIL light the error code is P1955and P0101 P1955 can not exist what is the solution?
  • fassildd
    fassildd Oct 16, 2013
    Hi tank you I have power loss after limp mode then the management light became on by launchi scan tool I take P1955 and p0101 error cod I am going to clean the diesel particulate filter but how can I exist the error code?
P1954 + P1955 2007 merc sprinter what do they mean
P1954 automatic glow time control module 2 electric circuit malfunction. P1955. Glow plug control module 2, to pcm circuit range/ performance. You have to replace the the glow plug module and maybe glow plug also
Mar 12, 2016 | Cars & Trucks
Two OBDII codes. How to fix?
P0101, mass air flow circuit range, P242F appears to be a non code , may mean don't forget to repair previous code. Check and repair mass air flow problem . then delete code, code will reappear if fault not fixed.
Jul 09, 2015 | 2009 Dodge Sprinter 2500
Mercedes Benz R 350, 2008 error P0411
Error Code: P0411
Description:
Secondary Air Injection (AIR) System - Incorrect Flow Detected
Indication:
Malfunction Indicator Lamp (MIL) ON.
Reasons:
Secondary air injection (AIR) pump.
Secondary air injection (AIR) valve.
Secondary air injection (AIR) hose(s).
Feb 21, 2014 | 2007 Mercedes-Benz C230 Sedan
`CODE P1954 P1955
what is p 1954 and p1955
Sep 09, 2013 | 2010 Mercedes-Benz Sprinter
Fault code p1955
I used a generic scan tool on a v6 sprinter and it gave me fault code p1955 as a current code. I hooked up the factory scan tool (star diagnosis) and had no fault codes. Looked up the mercedes benz obd codes and this code does not exist. What symptoms do you have with your sprinter?
Aug 11, 2011 | 2010 Mercedes-Benz Sprinter
I need the radio code for mercedes sprinter modell 2006
I need radio code for Mercedes sprinter 2004 plis help me
Nov 04, 2010 | 2006 Dodge Sprinter
Fuse location on Mercedes Sprinter 312D 1999
Mercedes Benz S550 problem with taking park and wont turn on
Apr 26, 2010 | 2007 Mercedes-Benz S550 Sedan
Curt Mercedes Sprinter 3500 2007-2009 Splice-in Converter Logo
289 people viewed this question
Top Curt Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Curt Office Equipment and Supply Expert? Answer questions, earn points and help others
