Question about Tecumseh Snowblower Snow Blower Starter Handle (Tecumseh)
Huskee snowblower help
MY HUSKEE WILL IDLE OK BUT WHEN IT NEEDS POWER TO BLOW SNOW IT HAS NO GET UP AND GO DOES IT HAVE A GOVERNOR OR WHAT.?
    Sergeant:
  • 459 Answers
So you only have idle speed ?
it must start hard
there is a governor but not normal to go out of adjustment
check carb linkage and springs
does your thottle lever move anything when you move it ( as far as throttle plate or any linkage?
Posted on Oct 17, 2013
Troy Bilt 3090 snowblower surges off choke, doesnt surge on choke, cleaned the carb, jets, float, drained tank, cleaned fuel filter, fresh gas, still surges. Could it be the governor or idle jet?l
you could try opening up the idle/mixture screw another turn to make the transmission from idle to throttle better
governors just open the throttle butterfly according to the spring tension setting from the throttle lever
Dec 16, 2016 | Troy-Bilt Storm 2840 277cc 28-in Two-Stage...
Governor linkage need to see cannot get it set
Check out CHAPTER 4 GOVERNORS AND LINKAGE it shows the different governor systems used on Tecumseh engines.
http://www.barrettsmallengine.com/manual/tecumsehlheadmanual.pdf
Feb 06, 2016 | Tecumseh Snowblower Snow Blower Starter...
My huskee snowblower 31-a , engine runs fine, it won't blow snow,, plugs up all the time. Please help
guessing the shear pin is broke replace it and be forewarned it is not a fun or easy task
Feb 28, 2015 | Garden
I need to know how to adjust the governor on my MTD model 31A-62EE729 snowblower with a 179cc motor
lossen the nut on the governor shaft, and move the arm toward the carb while holding the arm in this position turn the shaft counter clock wise and tighten the nut. and you are done. GOOD LUCK
Sep 03, 2013 | Tecumseh Snowblower Snow Blower Starter...
Snowblower will not throw snow as far as before.
two things to do. One, get the carb service and have them check the governor.
Two, have the auger belt replaced.
Dec 27, 2012 | Garden
208cc b&g craftsman snowblower governor settings
sounds like last years ethanol gas messed up your carburetor.
Probably have to drop the carburetor Bowl and clean the Jet
Nov 22, 2012 | Craftsman Snow Blower / Snowblower Bottom...
Huskee Snowblower has to be constantly at high RPM to throw snow
It sounds like the sping that goes from the throttle lever to the govonor arm is either streched or broken.
Jan 20, 2009 | Toro Blowers Rake and Vac - Electric...
Tecumseh Snowblower Snow Blower Starter Handle (Tecumseh) Logo
114 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
Jim Parker
Jim Parker
lnbn1975
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
