Question about Garden
John Deere 624
I have a John Deere rototiller that starts and immediately dies with 4 to 5 seconds. I've checked; The spark plug The gas The fuel line The gas filter etc. It will not start. Any ideas?
  • 110 Answers
First make sure your float bowl does not have water in it. make sure the needle attached to the float is not stuck in the needle seat.clean and blow out the carb.
Posted on Oct 15, 2013
4 Suggested Answers
  • 86 Answers
SOURCE: lawn tractor shuts off after 20 minutes of running
How old is your ? Sounds like ignition problem,If your engine is older you would have points when the points are bad they can stick together and will result in shutdown after unit cools a little it will restart !
Posted on May 09, 2009
SOURCE: John Deere 6420 shutting off
My JD 6420 stops after about 20 mins and will not move. The motor will still run but transmission will not go into Amy gear. The forward and reverse lever will not ingauge.
Posted on May 25, 2012
dumpfixxer
SOURCE: I have a John Deere 116 not getting gas to the filter or carb
it has a vacuume operated pump under the battery, by the steering column .it operates inconjunction with the pump screwed to front of the carb. id check the diphram in both, they dry rot and stop pumping if they sit
Posted on Sep 26, 2013
My John Deere 145 won't crank. it acts as if it is not getting gas to the carburetor. we have changed the modulator, checked the fuel lines and fuel filter. the gas is clean. can you help?
put a little gas in the carb and try it. if it starts for a few seconds and dies it is starving for fuel. be sure fuel is going through the fuel lines to the carb. if so the carb itself may just need cleaned.
Apr 15, 2017 | John Deere Garden
Engine starts easy and immediately dies. Fuel supply is ok. Seems to be ignition/ interlock issue but i need some guidance.
Have you checked the fuel supply first. Its possible your jet valve may be plugged or dirt in the fuel bowl. One quick way of checking this is take the spark plug out and put a little shot of gas in the spark plug hole then reinstall the spark plug and put wire back in place and try to start engine. If it start and revs up for a few seconds till the gas is burnt up then stalls it is pretty certain its a dirty fuel jet or dirt in the fuel bowl. This quite often a real cheap fix .
Jul 30, 2015 | Garden
What replacement engine would I need for my John Deere 624 Rototiller?
I have had a great experience with Green Dealer Customer Service
888-473-6357.
They have had most everything
Apr 25, 2014 | Garden
I go with the same motor. I wound try e-bay.
John Deere L120 runs for 15 minutes, bogs down and dies. A few minutes later starts right up, runs for a few minutes and dies again. I have changed the fuel filter, all fuel lines, air filter, cleaned the...
Is this an older machine ? If so try finding the points its usualy on the front lower part of the engine behind the cover, if you see that then it needs its condensor replaced, lookes like a round battery.
If this is newer or you can also try changing the spark plug sometimes they heat up and fail.
Sep 17, 2012 | John Deere Garden
John deere 425 mower won't start
The ignition switch module is likely to be the problem,they seem to quit for no good reason.The safety relays and fuses are built into the board that comes with the switch and will most likely fix your problem.
Apr 19, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 445 Garden Tractor, starts immediately,
could be bad gas, but it sounds like a choke problem. did it sit over the winter with less than a half tank of gas in it. try putting some rubbing alcohol in the fuel or draining the tank and disconnecting the gas line so you can drain the gas out of the carb. also check the gap of the spark plug and make sure that is correct. when was the last time there was fresh oil put in. also check the air filter, it could be full of dirt.
Apr 18, 2010 | John Deere 420,1020,2010,2020,2510,2520...
The mower starts, buts runs sluggishly, and dies
Most common is a dirty air filter, followed by a plugged vent hole in the filler cap on the gas tank. Next would be fuel issues either in the supply line or in the carburetor.
Hope this helps, --W/D--
Jul 19, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
John deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
May 19, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
