Question about Hamilton Beach 70570 Food Processor
Food processor stopped working - Hamilton Beach 70570 Food Processor
Hamliton mini foodprocessor stopped working
Possibly the micro switch which is activated when the lid is turned into position. Sometimes a particle of food gets lodged in the opening and prevents the lid from engaging the switch.
Or maybe the wires in the plug have come loose.
Nov 16, 2013 | Cuisinart DLC-10S Pro Classic Food...
The food processor stops working after use. I know there is a reset "hole" to make it start again. I can't see where it is and cannot find it in the manual. Please tell me where it is so I can...
Not all food processor have a reset button, some don't have. You have to be make sure that the unit is in fit, suited because it will on the interlock switch (the safety switch) before it operates normally.
I hope I give you idea regarding your food processor problem.
Mar 27, 2011 | Cuisinart DFP-14BC Custom Food Processor
Food processor not working
check cover safety tab possible broken or faulty switch
Aug 29, 2017 | KitchenAid KFP740 Food Processor
I have a small Cuisinart food processor and I cannot figure out how to turn it on. It has two levers low and high. I have it plugged in and the lid on? Please help. Fiona Slattery 858-752-8591
Your PowerBlend Duet™ comes with a food processor button. This button is the perfect speed for all your food processing tasks. Always use this speed when using the food processor. You may also use the Pulse button with this function for pulse-chopping.
To use your food processor, make sure that the bowl is assembled properly and the blade or slicing/shredding disc and the cover are locked into place.
When you use the control panel, the LED will light next to each button you press.
Press the On button. For continuous operation, press the Food Processor button. Motor will start if you have followed assembly instructions.
To turn motor off, press the Food Processor button again or the Off button.
For on/off operation, called pulse-chopping or pulsing, press the On button, press the Pulse button, and then press and release the
Food Processor button the desired number of times. Motor runs as long as you hold the Food Processor button down. The motor stops when you release control switch. Try it a few times.
You control the duration and frequency of pulses by the length of time you hold the Food Processor button down and the rate at which you press it. Pulses should be short bursts. Allow enough time between pulses to let food in work bowl fall to bottom.
Always use the Food Processor button for pulse/chopping. Never turn cover back and forth to start and stop processor.
You can download manual from the below link
http://www.cuisinart.com/share/pdf/manuals/bfp-10ch.pdf
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 12, 2009 | Cuisinart Food Processors
I own a bravetti e109fs food processor. It just
you can get bravetti food processors at OVERSTOCK and their shipping costs are VERY low. Or, check the prices on ebay and Amazon (I just did)
(if this has been helpful, please give me positive feedback)
Aug 19, 2009 | Bravetti E109FS Food Processor
It just stopped working
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the hollow feed tube facing the back of the processor.
Put the pusher sleeve in the lid, with the sliding lock switch facing the front of the processor.
Your processor should now turn on.
If your food processor still does not turn on, call Cuisinart and see if you are eligible for an in-warranty repair - it has a 3-year warranty.
-Tha Mp3 Doctor (also loves Cuisinart)
Oct 29, 2007 | Cuisinart DLC-10S Pro Classic Food...
My food processor just stopped working?
A Cuisinart food processor doesn't start before the top is assembled properly, that is a safety feature. Their strong motors can withstand also hard to cut ingredients.
Aug 27, 2007 | Cuisinart DFP-14BC Custom Food Processor
User Manual
Here is the direct link to your food processor user guide: http://useandcares.hamiltonbeach.com/files/840150200.pdf Enjoy Lolita
May 18, 2007 | Hamilton Beach Big Mouth 70590 Food...
Hamilton Beach 70570 Food Processor Logo
46 people viewed this question
Top Hamilton Beach Food Processors Experts
Jim Thurston
Robert Plante
Oloyede Monsuru
Are you a Hamilton Beach Food Processor Expert? Answer questions, earn points and help others
