Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Flooded engine - John Deere 420,1020,2010,2020,2510,2520 Tractor Float
  • 38 Answers
Bad carb
Posted on Oct 15, 2013
What could make my 1993 geo tracker flood 1.6
the G16 engine, floods.
there are 2 engines, G16a and b.
8valve TBI and the 16v MPI engine.
(EFI on both are radically different.)
this pages shows all 3 levels of diagnosis
3 causes. physics.
14 causes.
and then the full list.
http://www.fixkick.com/flooding.html
to find the cause takes tools.
got tools?, what to buy them.?
or just guess.?
here ill guess (useless)
1: the FPR reg is stuck closed, and fuel pressures 2x normal an it floods.
got 50 more...
post a photo of your engine and WIN>
get the first of millions, to do it.
amazing at it seems...
learn that almost all cars have
engine options
and transmissions.
May 05, 2016 | Geo Cars & Trucks
Will not start when engine is warm sounds like it is flooded cold engine OK
Bad coolant temp sensor--makes ECU think engine is still cold so sends too long injector pulse flooding engine. Very common, and easy fix.
Apr 02, 2016 | Cars & Trucks
Hard stating flooding
Search Results
    Rider mower carburetor flooding - help ! - YouTube
    ? 1:30
    https://www.youtube.com/watch?v=ZYqtKvLXYtY
    Sep 29, 2010 - Uploaded by Joyce Boncal
    It won't start. ... Rider mower carburetor flooding - help ! .... ( HOW TO ADJUST VALVES) FIX HARD TO START Lawn Tractorwith OHV Briggs ...
    How to stop a Briggs crankcase from flooding with gas Order ...
    ? 11:34
    https://www.youtube.com/watch?v=VhEiLMtPR5M
    Aug 5, 2013 - Uploaded by doublewide6
    If your tractor keeps leaking gas into the crankcase see how you can fix the problem by ... The hard starting is caused by fuel filling the cylinder.
    Basic Troubleshooting - Lawn & Garden Tractors - Cub Cadet
    cubcadet.custhelp.com/.../basic-troubleshooting---lawn-%26-garden-tract...
    Sep 13, 2002 - Engine fails to start, Engine flooded, Crank engine with throttle in FAST... Engine runs erratic or stalls, Tractor running with CHOKE activated ...
Jan 25, 2016 | Garden
Have a 2004 nissan altima plugs getting wet with gas take them out and dry car starts but same problem after 5 6 hrs won't start again what's the problem
Your engine is flooding with fuel which is why you have wet plugs and why you are having problems starting the car. A flooded engine will not start.
It sounds like a recurring flooding problem rather than a one off and the injectors may be leaking. One way or another too much fuel is being delivered by the injectors.
Get the car into Nissan Service and have them check it over and identify the cause.
Here is some information on the flooding problem prepared by a professional master mechanic.
Flooded Engine
Jan 25, 2016 | Nissan Cars & Trucks
Engine flooding
Check the fuel pressure. The pressure regulator may have gone bad and is delivering too much pressure to the fuel rail, thereby flooding the engine.
Dec 07, 2013 | Cars & Trucks
Borsche boxster 2002 water flooded . failure indicator
This could be bad. Was the engine running when the car flooded? If so, and water made it into the engine you may have blown the engine.
Feb 02, 2013 | 2002 Porsche Boxster
Flooded 3.7 dodge dakota engine
To start any flooded engine is to allow full air into the engine while cranking. IE with a carby hold the acceleratot flat to the floor until the excess fuel is removed from the cylinders. (make sure that the choke is not stuck closed) Do not pump the pedal as this only makes the problem worse. With efi it should not flood but if you feel that it is flooding check for faulty injectors then again hold the pedal to the floor while cranking
Jan 23, 2013 | 2004 Dodge Dakota
Floods when cold
Define flooding.
  1. Black smoke out of the tail pipe?
If the fuel return line is plugged,it will flood.If the fuel pressure regulator has lost its vacuum signal ,it will flood.
If there is a large vacuum leak,the O2 will see a lean condition and cause the rich condition.gas mileage will suck,big time.
This "flooding" happens when the engine is cold? ONLY?
Be sure the air filter is not clogged and the PCV is not plugged up solid.
Also,there are a few tubes from the valve cover that vents oil vapors into the air filter housing.
During this flood mode,hold the pedal to the floor and shut the engine OFF-it should NOT keep running.(Leaky injectors)...
Do this when engine is hot and cold.
Dec 25, 2012 | 1990 Volvo 740
Trys to flood on cold start
what vechicle type model and the year.older cars carb type if automatic choke not working or vacuum pull off not working carb will flood out engine.for cold start up engine need good spark and fuel.if engine flooding could have weak spark due to worn out spark plugs and wires.could have vacuum leak or bad engine coolant temperature sensor.dirty air filter.dirty fuel injectors.
Dec 20, 2012 | Cars & Trucks
98 RAM 1500 WONT START
Replace the coolant sensor NOW!? Its causing a flooding condition as evidenced by wet plugs that short out when flooded. Blip the starter and see if raw fuel is blown out as another indication of a flooded condition. In cases of flooded engines, holding the gas pedal to the floor shuts off the injectors during starting to clear out the cylinders.
The brass replacement sensor will cure flooding and many other engine/transmission issues.
Nov 18, 2011 | Cars & Trucks
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
