Question about KitchenAid Dryers
My kitchen aid gas dryer timer isn't working. The clothes dry when I run it but the timer doesn't work - Model #KGYE670BWH0. Where can I pick up this part relatively cheaply?
  • KitchenAid Master
  • 3,051 Answers
Hello there and welcome to fixya
This is a really easy part to replace and it is rather cheap you can purchase it online at repair clinic.com
My kitchen aid gas dryer timer isn't working. The - e550cf42-48af-4b3c-a299-cfd9809bb7e7.jpg
Timer
RepairClinic Item # 528733
Timer assembly for dryer
Manufacturer Number 3405331
More
Skill Level Skill Level
$118.30
Quantity:
Posted on Oct 14, 2013
SOURCE: Gas dryer does not dry clothes
try replacing the solenoids/coils.
Posted on Jan 10, 2008
SOURCE: Doesn't heat to dry clothes.
i have the same problem and am looking for a solution too so i will write back and let you know
Posted on Mar 27, 2009
  • 67 Answers
SOURCE: Ignitor will light but will not fire the gas.
bad gas valve coil
Posted on May 18, 2009
  • 336 Answers
SOURCE: Kitchen aid dryer Partial drying the cloth
First you should make sure the exhaust vent and ducting and lint trap is not clogged or restricted, birds/insect nests, or lint build up. If the dryer is heating up it is most likely an airflow issue.
Posted on Jun 05, 2010
Testimonial: "Cleaned the vent, ducting and lint trap, the dryer is working. Thank you very much."
heatman101
  • 43501 Answers
SOURCE: Our Kitchen Aid Gas dryer
If your
dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about
Dryer Maintenance
heatman101
Posted on Jan 19, 2011
Kenmore 400 series gas dryer doesnt dry clothes
Replace timer, if you are sure that it is not working.
Do an internet search for kenmore driver parts and get dozens of hits.
Aug 03, 2014 | Kenmore Dryers
The dryer works fine in TimeDry mode, but in Intellidry mode it dries very slowly. The "Moisture Moniture" indicator lights start and stay at "Less Dry". I have replaced the moisture...
you could have bad gas coils.if the timer doesn't advance in auto dry most likely you're having heat problems,when the dryer heats and then the heat shuts off then the timer will advance,when the heat comes back on the timer stops,it does this until the clothes are dry.gas coils when starting to fail will work normally until they get hot and then no heat until the coils cool down then they will work again,on time dry the timer just keeps counting down until the time runs out no matter what's happening to the dryer.i've seen the coils fail after the first 10 minutes and other times for 20 to 30 minutes but usually if the load is big and in time dry the clothes will feel warm and you'll need to dry them a second time to get them fully dry,also while you're in ther you should clean out the dryer at least once a year,clean out the duct that the lint filter slides into,vacuum out the cabinet where the motor is and blow out the vent line,if it's a long run i use a leaf blower to blow out the line,remove it from the back of the dryer,stick the leaf blower into the vent line and blow it out,i've blown out birds nest out of some lines, your clothes will dry on time,you won't go through so many parts and you won't have to worry about a dryer fire,the gas coils are on top of the gas valve,remove the two phillips screws,lift off the cover and change out the coils.next time you use the dryer keep an eye on it,after it runs for 20 minutws start checking it,you'll hear a click,then another click and the flame will lite,look into the gas tube and if the flame isn't liting then you have bad gas coils.
Sep 10, 2011 | Maytag MDG7600AW Gas Dryer
The dryer isn't drying. The dryer is a kitchen aid the model is kgye777bwh2. Also this is a gas model. I noticed that the pilot isn't lighting when I turn on the dryer. With the dryer running i...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;
Jul 22, 2011 | Dryers
Clothes take long to dry on Kitchen Aid Model - KEYE660WWHO
First thing to do is vacuum out all lint from dryer, unplug, remove back and vacuum all lint out of it, also where vent hooks up. Then clean out duct work from inside of home to where it exits. Excess lint holds moister and causes dryer not to dry.
Sep 27, 2010 | KitchenAid KEYS850LQ Electric Dryer
Jun 05, 2010 | KitchenAid KGYS850LT Gas Dryer
Whirlpool dryer gold not drying clothes
  • Check for proper air flow
  • Check the ignitor
  • Check gas jet
  • Test the gas valve coils
  • Check the flame sensor
  • Test the safety fuse
  • Test the thermostats
  • Test the centrifugal switch
  • Test the timer motor
  • Test the temperature selector switch
  • Here is a website to aid with these tests
    http://www.acmehowto.com/howto/appliance/dryer/diaggdryer.php
    Nov 11, 2009 | Whirlpool GEW9250 Electric Dryer
    I am trying to figure out the capacity on my Kitchen Aid dryer, model KEYS677EQ1.
    dear customer the capacity for a dryer is mostly comen sense for example if you dry blankets they are farly heavy you can put as much as you like in your dryer but dont forget that wet cloth is heavy on your dryer or wet jeans it will work no problem but on the long run your dryer will wear out faster because of the weight normal clothe what goes in the washing machine goes in the dryer thankyou have a great day from gilles
    Mar 15, 2009 | Dryers
    KITCH AID DRYER
    It sounds like the timer motor isn't advancing. You will have to replace the timer.
    Oct 15, 2008 | Whirlpool GGQ8831L Gas Dryer
    Gas clothes dryer not drying clothes
    could be an ignightor problem reply and we can talk
    Jan 03, 2008 | Dryers
    Open Questions:
    Dryers Logo
    Top KitchenAid Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Virgil Watts
    Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
