Question about Air Tools & Compressors
`we have 3 GA37FF workplace air system that power 2 of our press lines. one is a back up and we only have to power 2 at a time. when running, they're supposed to turn off at 125psi and then power back up at 111 psi. The problem is all of them keep peaking at 150psi and blowing the relief valve on the tank. I imagine there's some sort of pressure switch in the units themselves, but what are the odds of all 3 going bad at once. Please help. Thanks Jon
    Novelist:
  • 205 Answers
There are several designs of a ga37ff. To help I will need serial # and year made. I suspect inlet valve unloader failure.
Posted on Oct 16, 2013
SOURCE: My EC12 builds up pressure, but then releases all but about 10 psi.
The non-return valve is sticking and it's an easy fix. First, for safety, unplug the electric power to the unit and release any pressure in the tanks. Then unscrew the cap of the non-return valve (between the compressor and the tanks). Inside you should find a tapered rubber plug which is probably sticking in the valve housing. Sand down the diameter of the large end of the plug, being careful not to damage the flat face at the narrow end (which is the sealing surface). For sanding try 400 or 600 grade wet-or-dry paper and sand until the plug just moves freely in the housing. Reassemble and the compressor should work. Incidentally it's an oil-type unit, and quite durable. Make sure it has enough oil.
Posted on Nov 14, 2008
  • 65 Answers
SOURCE: Twin tank air compressor does not pressurize past 65 to 80 psi.
machine inlet valve not sealing in cylinder head valves need to be removed for assesment
Posted on Dec 03, 2008
  • 1383 Answers
SOURCE: No air pressure past 60PSI on a 125PSI Campbell Hausfield WL61110
Your comperssor is oilless type and suffers from short cylinder / piston life. When the compressor no longer reaches cycle pressure the cylinder / piston should be replaced. These parts are available at www.chpower.com I believe that the part number is wl210300aj. Not expensive, enjoy.
Posted on Dec 13, 2008
ollie reece
  • 1167 Answers
SOURCE: i have sears craftsman 22gal 5 hp air compressor not enough press
hi buddy strip the end off the check valve out and inside is a rubber turn this rubber around and try this if it still downt work it sounds like the pressure switch faulty get back to me
Posted on Oct 05, 2009
Testimonial: "thanks i took out the check valve i see the rubber but the valve is 1 piece should i just get a new one"
wiringlunati
  • 576 Answers
SOURCE: Air pressure does not go over 25 psi I have taken
Does it shut off at 25 psi or just keep running and never build more pressure than that? Also, did this come on gradually or suddenly? Also, was it being used regularly when it happened or had it been sitting for a while?
Posted on Mar 07, 2010
I bought my HP Photosmart 3210 in The Netherlands in 2005. The ink cartridges it required were number 363. I returned to Australia in 2007 and promptly ran into a problem. The 363 cartridges are not...
HP Photosmarts:
C3210, C3310, C5180, C5183, C6150, C6180, C6188, C6288, C6288, C7160, C7180, C7268, C7280, C7360, C8250, D7460 and all other Photosmart fixed inkjet head printers
This printer has six colors and no less than 12 inkjets, two for every color. A Fine inkjet for printing fonts and a wide inkjet for larger areas such as pictures and graphics. Each inkjet is made up of several lines or vents.
Note, Black Fonts use only black ink, Black graphics use a conbination of magenta, blue, yellow and black.
Troubleshooting:
1. Press * and # at the same time, and then release both keys. This will open the Mfg Commands Menu and say; "Enter Special Key Combo".
2. Press 123. "Support R00xx" will apear.
3. Press Right Arrow Cursor button: (uiaux Menu)
Once for: Information Menu > Info menu
Twice for: FAX Diag Menu > Run FAX Test > Reset FAX Params > Change FAX Params > FAX Param Report > FAX Trace Report > Speaker Mode > Ring Monitor > CNG Monitor > Signal Monitor.... Repeat.
Three Times: Print Tests Menu > Nozzle Test. Pressing OK gets you this:
http://forum.naddabiz.com/viewtopic.php?f=17&t=269
4. Press OK on one of the three Service Menus.
5. Press CANCEL several times to back your way out as needed or until the normal screen appear.
LCD Screen & Cursor Test
Play Pong Game:
2. The display should read "Enter Special Key Combo". Press 7664.
3. A yellow paddle appears. It moves only Horizontally using the right & Left Cursor Keys.
4. Press OK to pitch ball.
5. Press Cancel to exit.
Extended Self Diagnostic Test
1. Press OK & Cancel Button simultanously
Semi-full reset
This will reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer while the printer is powered on.
2. Press and hold Plus (#)[next to zero] and 6 while plugging in the power cord.
3. Repeat steps one and Two, Two more times for a total of three times.
This will perform a maintenance cycle upon the third restart.
Now you may want to print a self test report by pressing "Setup" and then 1, then 1 again. or Clean the heads by Pressing Setup > 5 > 2
OOB NVRAM RESET (Remove Air in Hydrolic lines)
1. Turn Power off using power button.
2. Hold down the CANCEL & OK buttons & keep them held while powering on the printer.
Keep them held till the printer shuts itself back off. (It will shut off without you hitting the on/off button.)
3. Then power it back up normally by hitting the on/off button. It will warm up normally except it will display a message "OOB NVRAM RESET" & it will then do about 3 minutes of priming & pumping up the ink in the tubes that run from the cartridges to the print head.
4. You then can run a test print in the tools section.
YOU MAY HAVE TO DO THIS PROCEEDURE AS MANY AS 6 TIMES. IT WILL EVENTUALLY GET ALL AIR BUBBLES OUT OF THE SYSTEM.
Semi NVM Reset
2. Press and hold the (#)[next to zero] and 6 buttons while plugging in the power cord and keep both buttons depressed for at least five seconds.
3. Printer will shut off
4. Press Power on and unit will begin the Semi NVM reset.
The unit will clean its heads and the pump will cycle several times to prime the hydrilic lines and purge out any air.
Then a Maintaince cycle will begin.
There are more codes like 124, 127 you can enter. But be carefull to use.
In one case you can enter new ID's MAC adresses, and parameters for the printer. But i don't now wich parameters will change so i did not changed them at all.
Jan 14, 2011 | HP Photosmart 3210 Printer
Dear, i have a problem with brakes. When i do press pedal on first pressing car is stopping, but if i do press pedal several time quickly pedal is becoming hard after pressing, and take 1-2 seconds pedal...
The problem you are describing sounds like the master cylinder. Usually the brake pedal is hard when the vacuum booster goes bad. It would feel the same whether the engine is running or not since there would be a vacuum problem and vacuum is provided by the engine. When the pedal is fading it's usually a problem with a seal inside of the master cylinder. When you replace it, save yourself some time and bench bleed it. Fill it with fluid, and if equipped, which rebuilt ones usually are, screw in the plastic fitting lines and run the open ends back into the reservoir and pump the actuator until the bubbles stop. Bolt it to the vehicle and start the lines. Have someone press the pedal, and while all the way down hold it there. Snug the lines up and have them release the pedal. Have them press it to the floor again and hold it there. Loosen the lines slowly to let what little air remains out, tighten them, and then have them release the pedal. That will rhymes with duck but starts with "s" (avoiding censorship) the remaining air out the top instead of bleeding the entire system from the wheels and pushing the air all the way through them. Please rate my assistance and leave a testimonial.
Dec 28, 2010 | 2003 Jaguar X-Type
#1...Help Please, I just got this truck a couple of weeks ago, my first 6.5, my 1993 6.5 turbo Cranks fine in the morning, but today, a warm day when I crank it, the starter just turns over and over for a...
It sounds like there is a problem in your glow plug circuit. A copy of Haynes Diesel Engine Repair Manual, part # 10330, has easy step by step diagnosis and repair for this engine complete with diagrams and pictures. It's only $20 at the autoparts store.
Make sure the fuel and air filters have been changed recently or do it yourself. Inspect the entire air breathing system for blockages, including mouse nests in the tubes. Replace, or splice into the fuel return line ( on the top of the injctor pump) with a piece of clear line. Star the engine and watch for bubbles. That is air in the fuel system and it shouldn't be there.Trace fuel lines back to find the leak and fix it. If all of this is good then check out the diagnostic section in the Haynes manual. Page 2-94 will tell you how to check for codes and what they are. This may help too.
Hope this helps.
Apr 02, 2010 | 1993 Chevrolet C/K 3500
1987 FORD FULL SIZE BRONCO FUEL PROBLEM, SHUTS DOWN
The only way air can get in the fuel line is if you have a hole in it! Problem of course is were? I would run the fuel line from back to front and back again. Look for any wet spot that you can find. You may even have to drop the tank to ba able to look on top. I would suspect the problem is in the line before the high preasure pump, being as you are pulling air into the system. I have seen leaky lines allow air in, but not let fuel out.
Sep 12, 2009 | 1987 Ford Bronco
Retrieving messages over phone
when your greeting answers, punch in your code, usually a 4 digit code, each manufacturer has their own default code that it comes with.. check the manual or website
Apr 14, 2009 | Lands Phones
1990 Ford F150 won't start after running out of gas
sounds like fuel pump is dead check for fuel at injectors
Dec 19, 2008 | 1990 Ford F150
My RM 2652 when dry camping it uses the 2 batteries overnight ?
OPERATING MODES
AUTO MODE
Press the AUTO/MANUAL mode selector button (2) to the DOWN position. The AUTO mode indicator lamp
(A) will illuminate.
When operating in the AUTO mode, the AUTO mode indicator lamp (A) will illuminate. The control system
will automatically select between AC and GAS operation with AC having priority over GAS. If the control
system is operating on AC energy and it then becomes unavailable, the system will automatically switch to
GAS. As soon as AC becomes available again the control will switch back to AC operation.
If 120 volts AC is not available, the control system will automatically switch to GAS operation. Within 45
seconds the burner should be ignited and operating normally. If unsuccessful, the CHECK indicator lamp (B)
will illuminate.
To restart an ignition attempt with the CHECK lamp illuminated or to clear (turn off) the CHECK lamp, press
the main power ON/OFF button to the OFF and then to the ON position. The control system will attempt a
new 45 second ignition sequence.
On the initial refrigerator start-up on gas (120 volts AC is not available), it may take longer than 45 seconds
to allow air to be purged from the gas line. If the refrigerator has not been used for a long time or the LP tanks
have just been refilled, air may be trapped in the supply lines. To purge the air from the lines may require
resetting the main power ON/OFF button (1) three of four times. If repeated attempts fail to start the LP gas
operation, check to make sure that the LP gas supply tanks are not empty and all manual shutoff valves in
the lines are open.
NOTE: DO NOT continue to reset GAS operation if the CHECK indicator lamp continues to be illuminated
after 3 or 4 tries.
Nov 18, 2008 | Dometic RM2652 Refrigerator
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
