Question about Sony VAIO Computers & Internet
How to reinstall window 7 for sony vaio VGN-NR430E?
    Problem Solver:
  • 8 Answers
Having the system restore disk is the optimum way to reinstall Windows 7. Otherwise you will need to buy an OEM version and burn it to a CDRom disc and install from there.
Also, this is the link to your laptops driver download page for post installation. http://esupport.sony.com/US/p/model-home.pl?mdl=VGNNR430E&template_id=1&region_id=1&tab=download#/downloadTab
Posted on Oct 14, 2013
4 Suggested Answers
asingh1225
  • 122 Answers
SOURCE: Sony Vaio VGN-FE770G windows 7 upgrade problems
hello, try the link below;
ftp://download.sony.com/US/pc/TIDMSC-01424702-US.EXE
the driver above is for vista and should work with windows 7.
I hope this helps.
Kind regards,
Amar Sondhi
Posted on Dec 14, 2009
SOURCE: Where is the hard drive located in sony vaio vgn-nr430e/s
You Do have to take the machine apart I have the same computer and there are about 15 or so screws on bottem and be gentle when taking apart the hard drive will be in the inside to the left you have to unscrew a little sound bourd at verry end of hard drive to be able to slide it out and on the other end there are two more screws holding it in as well Good luck.
Posted on Aug 28, 2010
SOURCE: Driver motion eye camera sony vaio vgn ar31sr
Sony has not released the Windows 7 Driver for this Computer model. However, you can try installing the original Windows Vista Driver to resolve the issue.
Please download the Driver from the below link
Download the Driver
Please click the "Accept" button on the page to download the Driver.
Then, please unzip the file and double click on the "DPInst32.exe" file to begin the installation.
After installing the Driver, please restart the Computer for the settings to take the effect.
Camera should work correctly after installing this Driver.
However, you may need to download and install the Camera Application to use the Camera. You may also use the Camera with any messenger Application like Skype or Windows Live Messenger.
You can download the Windows 7 Compatible "ArcSoft WebCam Companion Software from the below link.
Download the Software
Please click on the "Download Now"option on the page.
Then, please double click on the file to begin the installation.
After that restart the Computer for the settings to take the effect.
Then, the Camera should work correctly with the WebCam Companion Software.
Posted on Sep 18, 2010
Reinstall window 7 for sony vaio VGN-NR430E
Instead of trying to reinstall try a Repair. When windows boots up hit the F8 key and select the option you want.
Sometimes just going into SAFE mode and doing repair options (like anti virus and Malware scanning) can help.
Suggest Malwarebytes be installed on EVERY computer and do monthly scans.
Oct 14, 2013 | Sony VAIO VGN-BX540B Notebook
Viao vgn-nr430e/p just died
remove battery and retry with only ac power connected ..if that works then the battery is bad...if that doesnt work then it could many other things like bios battery, power connector, mobo...
Apr 15, 2013 | SONY VAIO NR Series VGN-NR430E/P NoteBook...
My sony vaio VGN-NR430E will not start up i just did a system recovery and now it wont load windows unless in safe mode
If you can switch on your laptop in Safe mood then i will suggest you to remove recently installed application from your laptop. or you can try system restore oprtion to restore your laptop to earlier date when it was working. you can find system restore option in Start menu- Accessories and system tools.
Jul 22, 2012 | Sony VAIO VGN-NR430E/S NoteBook
My computer wont boot. It says "BOOTMGR is
You will need:
  • Windows 7 OS installation disc
  • Computer with "BOOTMGR is compressed" error
Please note that the following steps require you to have your computer to be able to boot the CD-Drive first.
Steps:
1.Insert the Windows 7 OS disc into your CD-drive and restart the computer.
2.Wait for the setup window to appear
3.Press Shift+F10 simultaneously to bring up Command Prompt
4.Type in Code:bootrec/fixbootthen press enter
5.Last but not least type in Code:bootrec/fixmbrthen press enter
6.There you have it, all fixed
Oct 19, 2011 | Sony VGN-NR430E/L PC Notebook
I have a sony vaio vgn nr430e laptop the display goes off as soon as the cpu fan starts rotating
That could be a problem with the heatsink/fan assembly on the processor. It sounds like the processor is starting up, getting warm as they do, the fan starts up but does not cool efficiently enough and forces a shut down due to heat.
Clean out the fan assembly and replace the old heatsink compound on the processor heat sink.
Hope that helps.
Dec 09, 2010 | Sony VAIO VGN-NR430E/S NoteBook
VGN-NR430E the fan doesn't seem to be working does it come on at power on
i have the same problem pulled it apart a few times and it started to work againg am still watching it to see what will happen planning to buy a cooling mat.
Jul 14, 2010 | Sony VAIO VGN-NR430E/S NoteBook
My sony vaio vgn-nr32s has got problem right from the start of vaio screen with many thick blue stripes and the second loading page with many 'a'.Window is not loading even after trying to restore to...
if you already performed a recovery and you have the same problem, then it is a hardware problem. it could be a video card or memory card problem. if that is the case, your computer needs service. you can call sony for assistance
888 476 6972 or 239 768 7669
Mar 16, 2010 | Sony VAIO VGN-NR430E/S NoteBook
Lap wifi
try reinstalling the wireless lan driver of the the computer from esupport.sony.com
Feb 14, 2010 | Sony VAIO VGN-NR430E/S NoteBook
MY VGAIO NR JUST SHUT DOWN. THEY SAID THE
before u much check ram, and try install again ur windows
Jan 14, 2010 | Sony VAIO VGN-NR430E/S NoteBook
Open Questions:
Computers & Internet Logo
37 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
