Question about Home
How to replace an old emco shower diverter - Home
  • 35 Answers
SOURCE: Shower diverter problem
It is very possible that a piece of rubber from the old washer or some debris has found its way into the shower diverter or the showerhead. The first thing to try, is to take off the showerhead and see if you get water without it. If you get water then your problem is solved!!! Puchase a new showerhead or take apart the old one and soak it in CLR or Lime-Away to clean it. If that doesn't do the trick than, Turn off your water supply to hot and cold. Remove the diverter (if possible) and inspect for debris. If you want you can also take out the hot and cold stems for a total inspection of the inside of the faucet. You can then flush out the inside of the faucet cavity with a Turkey Baster or something to that effect. Put it all back together ( use a bit of vasaline on all the rubber washers so they do not get stressed when re-installing) and you should be able to take a shower.....Also, if it was a cartridge you replaced, you may have inserted it 180 degrees opposite......Hope this helps.....Joe
Posted on Jan 12, 2009
jonbrown725
  • 73 Answers
SOURCE: Kohler K-9511-BN MasterShower Shower Arm & Diverter Doesn't Work
As a helpful hint , on these models, When installed some plumbers or home owners use plumbers putty to seal the threads and in some cases tape.
Most of the time the putty or tape gets pushed through the system if too much was used.
Check by removing the shower head and testing the pressure and blowing anything else through, then checking the head itself for foreign objects.
Kohler has a cleaning and care page on thier web site if it needs cleaned.
Posted on Jan 17, 2009
  • 10865 Answers
SOURCE: I'm trying to replace my
use a crescent wrench on the shower head. If the head alone won't budge, the entire head plus arm will unscrew. Then just pick up a new arm and some teflon tape and reattach both. good luck
Posted on Jan 18, 2009
  • 35 Answers
SOURCE: shower diverter push handle is squirting water out
If you are handy, the best solution is to call delta and have them send you a new diverter. They will need the model of your faucet. The new diverter will come with instructions on the install process. As far as fixing it without the new diverter, I don't believe you will be able to.
Posted on Nov 18, 2009
agent91
  • 2100 Answers
SOURCE: replaced shower valve. still drips from tub spout
The cartridge has 2 or 3 o-ring type seals around it that feed the water through, it picks up both hot and cold and mixes them. Some cartridges are replaced as one, some you have to replace the seals, just take the faucet info to the hardware store and match it up. I think the diverter is for the shower. It sends the water up instead of out.
Posted on Feb 28, 2010
Old Moen shower diverter
You will have to replace the shower diverter button. Remove the handle, remove the faceplate, and the diverter will screw out. Any plumbing supply that carries Moen products will have a replacement button for your valve
Feb 23, 2014 | Moen Home
Danze opulence diverter handle does not work
you have to replace diverter....if its in the tub spout unscrew and go to lowes or plumbing supply and match up style and replace...use pipe dope and screw back on tight...good luck
May 01, 2012 | Danze & Single Handle Tub And Shower...
Kohler shower diverter leaks (behind the wall)
if you have a closet behind the shower or a wall you may be able to get to the diverter without damage to the tile ,are you sure you can't just change the cartridge? most times this is all that is needed to fix a problem like yours.
Jul 22, 2009 | Plumbing
Delta 134900 handle Water coming out faucet and shower both
well the Diverter is not working it dose not matter the distance. when applied it should shoot the water to shower or tub if not working will come both.
Jun 15, 2009 | Delta & Single Handle Shower Faucet
Water sprays out the diverter
Remove hot/cold button in handle, remove screw/pull off handle. Remove the two screws in the wall plate/remove plate. Use a wrench to remove the diverter assembly. Get new diverter assy and reinstall eveything. You don't need to turn off the water.
Jun 09, 2009 | Delta Faucet #RP320 Divert Assembly
My 3 handle bathtub fauset [price pfisher] cycles hot and cold
You will need to either replace center "shower diverter"assembly or a quicker fix would be to remove old tub water fill spout and replace with a "pull up diverter knob" type water spout. Cost about 10 dollars Hdepot Pull Knob to divert water to shower when showering.
jthomefix
Mar 15, 2009 | Price Pfister Ashfield Widespread Bathroom...
I'm trying to replace my shower head and am unable to remove the old one from the shower arm diverter, any help would be appreciated
Jan 18, 2009 | American Standard 1/2in NPT Shower Arm...
Jan 12, 2009 | Ace Hardware BRASSCRAFT 45458 "ACE"...
Water runs out out both places for spout and shower head in tub!!
try replacing spout, sounds like the old one is a lil bit worn
Oct 26, 2008 | Home
Home Logo
198 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
