Question about Stihl Chainsaw Throttle Trigger 012 O12 Chain Saw
I have a stihi ts400 disc cutter which will not switch off on the off position when the button is push forward , any solutions welcomed !!
  • 64 Answers
Strip off the case check the contacts from the switch follow the wire back to the coil check to see it's connected. Usually it's the contacts
Posted on Oct 16, 2013
20822 Department shredder
The motor has a feature to go forward and reverse and thus the forward (paper in) control has been compromised. The problem can be the switches. A rocker switch when in one position may control the forward motion or backward motion, therefore if the switch fails only one side is working. Then there may be two small switches on the so called rollers (Cutters) that sense the input of paper into the cutters thereby starting the motion and shredding procedure. If a sensing device is broken, only the unaffected switch works. Repair is usually expensive, thus a replacement is in order.
Dec 18, 2013 | Dahle Office Equipment & Supplies
Wot is the fuel mix for a partner k 750 disc cutter
50-1 with Husqvarna two stroke oil, but 25-1 with other two stroke oil as the quaility is unknown, always try to use Husqvarna two stroke oil
Mar 09, 2013 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Need to know what oil goes in the crank of a stihl ts400 disc cutter and the amount
The oil is mixed with the fuel to lubricate all internal components, i would run it at a 25-1 fuel oil mix with good two stroke oil.
Sep 06, 2011 | Garden
Cuts off after a couple of minutes with error mesage of E68
Hello,welcome to FixYa.
The E68 is indicating a push button is stuck, refer to this chart below for explanation and potential remedy.
The reason this is happening can be for a couple of reasons. When a button is pushed, the contact inside the control is sticking in the "closed" position, or the plastic button which activates the switch, is binding on the console and not allowed to return via the small spring which insures it does under normal conditions.
Let me know how you make out or if anything is not clear and I'll help in whatever manner I can going forward. Good luck.
Regards,
Macmarkus :)
Aug 14, 2011 | Frigidaire Electric Dryer
I have a stihl st400 disc cutter & I think the pull start needs cleaning, any advice?
compressed air works well. you really need a gun with a long skinny nozzle. for example
Jan 26, 2011 | Stihl Concrete Cutoff Chop Saw Clutch...
Dyer will not rotate just clicks
Welcome to FixYa.
I know I responded to your other post as well, but I just wanted to make sure you got my reply.
It sounds like the kill/emergency shut switch is in the "off" position.
  • If you notice a switch ( white in color ) next to the belt pulley has a black push button on it, that is the interrupt switch that shuts it down should the belt break.
  • Push in the black button from the left ( from the back ) until you hear it "click" and you should be good to go.
Let me know how you make out.
Thanks for choosing FixYa. I hope you will take a second to rate my solution/assistance positively.
Good luck.
Macmarkus :)
Aug 27, 2010 | Bosch Nexxt WTMC 6300 Electric Dryer
Stihl saw TS400 will not get fuel through,NON START
how much fuel can be put into a stihl saw ts 400 and how long will the fuel last while in constant use
Mar 24, 2010 | Oregon Scientific Complete Carburetor for...
How to set up the carburator on ts400 disc cutter sthil saw
turn the idle screw all the way in and turn out 1 and 1/2 turns the air mixture screw the same then adjust the air mixture to get best running performance at lowest RPM.
Jun 10, 2009 | Saws
Stihl Chainsaw Throttle Trigger 012 O12 Chain Saw Logo
44 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
