Question about Refrigerators
I need the part between the reservoir and cooler because it is broke
    Master:
  • 359 Answers
What model refrigerator do you have?
Posted on Oct 14, 2013
How to properly clean my pelonis water cooler
not sure if this will help you out but have a read up.
To clean the cooler:
  1. Unplug the cooler.
  2. Check to see if your cooler is equipped with a water guard. ...
  3. If you do have a waterguard you need to remove it. ...
  4. Rinse the reservoir out with a baking soda and water solution, use approximately 1 cup of water and 2 tbsp of baking soda. ...
  5. Replace the water guard kit.
The Water Express :: How to Clean Your Cooler.
or go to this link.
How to properly clean my pelonis water cooler Google Search
Oct 30, 2017 | Pelonis Heating & Cooling
Oil appears in the coolant reservoir bottle
To my knowledge, most oil coolers would be In Front Right Fender for 1995-1998 Porsche 911 Carrera 2 and would look something like the image below.
Although I have strong doubts that your seals are needing replacement. Should they be worn out, defective oil seals would exhibit leaks that would be noticeable. Nonetheless, if you would follow the two hoses connected to the oil cooler, they would lead you right back to their entrance and exit points in the engine.
Oil mixing with the coolant and visible in the coolant reservoir indicates another problem, most probably head gasket.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 12, 2008 | 1998 Porsche 911 Carrera
Leaking large amounts of transmission fluid on to driveway. Does the car have a resevior that could be broken? Or could it be a line?
No reservoir. You did one of the following. Broke a line, damaged the transmission pan, damaged transmission cooler,
May 05, 2016 | 2006 Dodge Caravan SXT
Hi, i have automatic passat 1999 model and recently water happens to get into the gear box and it control board, i experiences a boom sound anytime the gear is changed, the oil has been changed by the...
If no external leak and the transmission fluid colour looks white, the problem belongs to the automatic gearbox oil cooler. The oil cooler has broke mixing the gearbox oil and coolant causing this milkshake. It's a small radiator core type oil / water heat exchanger. It is cracked inside and transmission oil is mixed with engine coolant. Because the transmission oil pressure is greater than engine coolant pressure, the transmission fluid level drops. See also the coolant colour inside recovery coolant reservoir inder bonnet! It could be like this:
The automatic gearbox oil cooler type oil / water heat exchanger (oil cooler):
In the picture above the transmission oil pan was removed for oil filter replacement.
May 05, 2011 | 1999 Volkswagen Passat
Transmission fluid level need regular top up and there is no external leak.Fluid color looks white.
(In the picture above the transmission oil pan was removed for oil filter replacement).
Oct 29, 2010 | 2005 Audi A4
GE Water Cooler Reservoir overflows.
There should be no crack or pin hole in your water bottle.
Water bottle should be air-tight to make proper pressure inside bottle.
Whenever lose pressure, water overflow with no bubble.
Just replace water bottle with no crack or pin hole.
Good luck.
leey05
Jan 07, 2010 | GE Refrigerators
PUR 200 Water Cooler leaking from the back (under the reservoir)!
I had a similar problem. My PUR 200 water cooler was also leaking from back. The reservoir had crack in it. Since replacement part is not available. I used Super Glue and it is working fine now.
Aug 11, 2009 | Kitchen Appliances - Others
Have oil in my radiator fluid reservoir tank (1996 v6 3.8)
Twice in two years now my Saab 9-5 has had a pin-hole in the oil cooler, which has caused oil to flow into the reservoir. A way to tell is if coolant/oil is coming out of the reservoir cap. The reservoir cap is rated for the pressure of the coolant system, which is significantly lower than the oil pressure. When there is a hole in the oil cooler, oil will be forced out at relatively high pressures, causing the reservoir to fill and then over pressurize and spill out of the cap.
Mar 10, 2009 | 1993 Ford Mustang
Refrigerators Logo
14 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
